New HDD. I just replaced new HDD in Laptop, but can not boot OS from CD. Not matter where I try to boot from HDD or DVD. Getting a message: PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM. No bootable device -- insert boot disk and press any key
  • 6 more comments
  • mctros May 06, 2010
    When I said "Not matter where I try to boot from HDD or DVD" I obvieusly been in bios setings and tried to boot from HDD and also from DVD, with the same effect. I did download BIOS and recorded on DVD, but how can I update BIOS if still the same: "PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM. No bootable device -- insert boot disk and press any key" ?
    1. There is only 1 HDD
    2. I did explain already - I tried to boot from CD as well... (by change the setting on BIOS) and does not get "...press any key to boot from CD"
    ...and this is SATA
    You guys never read comments? I have done this before I did ask for help, and all of you say the same - but this is the first step and do not help
    Who told you I can not see CD/DVD drive?
    Toshiba Satellite L300
    Sorry, that was the other guy saing I don't see CD/DVD drive
  • mctros May 10, 2010
    this is laptop
    just replaced DVD drive and nothing happened
  • 493 Answers
You may need to enter the BIOS and change the boot order to CD/DVD first.
Do you have a copy of windows or any other bootable CD/DVD?
Check the cables on the hard drive, Data cable on both ends.
If you enter the Bios does it report all the drives you have installed?
Waiting your comments.
Hope this helps.
Posted on May 10, 2010
  • Ibrahim OKTAY
    Ibrahim OKTAY May 10, 2010
    Hi again,
    When we click on your question, we can not able to see your previous comments. Sorry for the same advices.
    If your new HDD has previously installed operating system on it you can do followings.
    Sometimes bootable CD/DVD may not work. You can try this:
    1. Allow Hard disk boot
    2. Press F8 on startup
    3. Select Safe Mode with command prompt
    4. Select CD drive ":"
    5. type "Setup"
    6. Press Enter key
    You can try to login as below:
    - Try to log in Safe Mode (one of the selections). Press F8 during startup, Select "Last Known Good Configuration" option ( This option starts Windows by using the previous good configuration.)
    - Then install your new device driver. (You can use control panel menu, Adding device drivers)
    Hope this helps.
  • Ibrahim OKTAY
    Hi again,
    If your new HDD has operating system on it you can do followings.
    2. Press F8 on start up
    5. type "Setup"
    6. Press Enter key
    You can try to log in as below:
    - Try to log in Safe Mode (one of the selections). Press F8 during start up, Select "Last Known Good Configuration" option ( This option starts Windows by using the previous good configuration.)
    Hope this helps.
    Sergeant:
    Novelist:
  • 172 Answers
Hello. That error means is trying to boot from any device and then it ends with ethernet because the hard drive is new.
Depending on the model of your laptop you either have to press F12 or F10 as soon as you turn your laptop on to get the boot menu. Or press DEL or F2 to go to the SETUP. Under Advance Settings you will see (or if you have a boot menu) the boot order. Select the CD/DVD to boot first THEN the Hard drive.
If you give me the model of your laptop, I can tell you which key to press so you can accomplish that.
Posted on May 06, 2010
  • Leonardo Garcia
    Leonardo Garcia May 06, 2010
    well "obvieusly" either your CD Rom or CD is bad! try an external optical drive.
  • Leonardo Garcia
    Who said anything about you not seeing the CD/DVD drive. I´m not going to argue with you. I´m trying to help you!. Maybe there could be a problem with the optical drive. The fact that the controller is good (that´s why you see it on the BIOS) it doesnt mean the laser is good, that´s you dont get the ¨Press any key .... ¨ If you are certain you have a good Windows CD Try an external USB optical drive and boot from it and see if it works.
    President:
  • 4,070 Answers
Hi! You may have a faulty dvd drive. Try cleaning the optical lens for it may be dirty thats why the bootable cd cant be read and gives you an error message. Try using a cd lens cleaner to clean the optical lens. If no luck, I would suggest that you replace the dvd rom to read your bootable cd. Once replaced I believe that you'll be good. HOpe this helps and have a good one!
    President:
  • 1,619 Answers
Sounds like cable select option the the HDD is wrong or the cable for the DVD rom/cd rom is not connected.
    President:
  • 1,851 Answers
Have you check at the bios settings the boot order? Also check if your cd / dvd rom is active and regognized thourgh bios.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "flags".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
  • 1 more comment
  • Stelios
    Stelios May 06, 2010
    Now I read your full story with the posts and I see what you have done. First of all in order to update the bios try to boot from USB. If succeed, update your bios and try to boot from the cd again.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
  • Stelios
    Another issue that I thought for your case:
    PXE is a setting that allows you
    to boot from network. In the bios turn OFF the built in LAN setting.
    You may need to turn it on later, but to avoid the PXE error turn it
    off.
    Thanks and regards
    Stelios
  • Stelios
    Stelios May 10, 2010
    Mctros have you tried the solution I suggested:
    Comment posted on May 06, 2010
    Another
    off.
    All the things that you came up till now makes me believe that your system is trying to boot from LAN. So try the if you haven't another better solution, try this one.
    If you are satisfied, rate my solution with the "thumbs".
    Thanks and regards
    Stelios
  • 369 Answers
A. Remove the hard drive and put it back in.
B. Check for correct master slave settings.
C. Check for hdd -ide cable is intact and fine.
D. Check if (male)pin no 18(gnd)-on the hdd side is properly connected to the IDE Cable . switch off the power and check the resistance between the cable.
If it does help, please follow the steps given below:
1.First all of all, shut down your computer. 2.As soon as you restart the computer, press F2(or F1 or Del) keys to go to bios. 3.Now, choose boot sequence. 4.Hit enter. 5.Make the CD/ DVD ROM as the first booting device. Please see on the screen the keys to go and up and use the keys(generally U/D or +/-) 6.Now hit F10. 7.Hit ESC once on the keyboard. 8.Choose Save and Exit. 9.Hit Enter. 10. Now, you will see press any key to boot from the disk.
  • 1 more comment
  • sandeep kumar sharma
    sandeep kumar sharma May 06, 2010
    If you see only HDD and not CD/DVD inside the BIOS, it means CD/DVD ROM is not detected on the computer. You need to check CD/DVD cables. There is an issue with CD/DVD sir.
    Please tell me the make and model of your computer.
    In the BIOS, you see CD/DVD ROM at the top under Boot sequence. Or please tell me all of the devices being show under Boot Sequence in a sequential manner.
  • 4,281 Answers
For that when you power up the computer press F1 or F2 or DEL or ALT+F2 then you can see bios setup.
Then disable the boot from lan and set first boot device as your harddrive.
Then save settings and restart .
Then if still same issue then you need to upgrade your bios.
For that download bios upgrade for your computer from manufacturer sites then upgrade it to newest version.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 05, 2010
How to fix pxe-e61 in lg e310-m.cp6pe1 laptop
It won't boot to network because there are no drivers installed. Use F11 or remove the hdd and copy your data to another drive before recovery.
Dec 23, 2014 | LG Computers & Internet
Toshiba satellite pro l450-13q PXE-E61 media test failure check cable
This indicates hard drive issues, or windows files have been corrupted. If you have a backup disk try and load windows, no change! have the hard drive tested for possible replacement.
Jul 08, 2012 | Toshiba Satellite Computers & Internet
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
I have a Dell vostro 3700 purchased only a few months ago. The hard drive crashed. After replacing the internal hard drive with new seagate, 750GB 7200rpm, how do I reinstall the OS? I turned off the...
Hi.
Pop the install DVD into the drive and restart your laptop. When you see the Dell logo hit the F2 key to get you into the BIOS. Look for boot options in the list and set the DVD/CD drive as the first boot device. Save the changes and exit the BIOS.
The laptop should restart and boot form the DVD/CD drive so you can install the operating system.
Good luck and regards.
Sep 05, 2011 | Dell Vostro 3700 Laptop Computer PC...
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
I have a problem geting my recovery disc to work in my compaq presario 2200 laptop, as i have just installed a new harddrive iam getting a PXE-E61: Media test failure and PXE-M0F Exiting PXE-ROM. ldygolfer
You need to change the boot order in the bios.
When you start the computer screen should prompt you at the bottom with something like:
F2 or F10 to enter setup.
Once you're in the bios, change the boot order to cd / dvd first.
Right now it's trying to boot through the network, that's why you're getting that message.
Let me know if you need any more help.
Best of Luck!
Feb 24, 2009 | HP Compaq Presario 2200 Notebook
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
PXE-E61:Media Test Failure
you got that error message because your harddrive isnot detected so it try to boot from network and you don't have OS in the network.
Most of the time is your hdd is dead. In some cases the motherboard is dead.
You can replace your hdd.
for OS (vista vs XP), if you have enough rams and high cpu, you should install vista, but for me, I prefer XP.
for the price, you should call microsoft seller.
Jul 05, 2008 | Acer Aspire 5050-3242 Notebook
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Computers & Internet Logo
178 people viewed this question
David Payne
David Payne
