Question about A.O. Smith SQ1102 Pool Pump Motor
The Pump overheated
I forgot to turn the water on and an hour or so later I realized, I turned the water on restarted it ran few minutes then stopped after overnight cooling it restarted and keeps running but no water is being pumped out, no leaks anywhere in the pump.
  • 1,338 Answers
IS IT'S A STA RITE CHANCES ARE THE PUMP CAN BE SAVED. IT WILL NEED A NEW IMPELLER,SHAFT SEAL AND DIFFUSER. THESE ARE TUFF PUMPS. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY .. USE YOUR ZIP-CODE IN YOUR SEARCH ..PUMP REPAIR IS THE GREEN THING TO DO AND IT SAVES YOU MONEY ! . PLEASE VOTE GUYS-N-GALS
Posted on May 22, 2010
  • 43,501 Answers
You probably melted things internally, like the impeller on the pump. These things need to run a close tolerances to work and pump water. Running it for a long time with no water over heates, melts or warps the internal parts. You need to pull the pump part apart and see if it can be repaired. Quite possibly you have ruined the pump completely...
heatman101
Posted on May 05, 2010
    Guru:
  • 351 Answers
Hello .. when the pump motor got overheated qas much as you said, you may have softened the plastic impellar of the pump. You will have to separate the motor from the pump and see if the impellar is still attached to the motor shaft. You may be able to rescue your oops with buying a new i9mpeller.
Why the intex pool 2500 pump stops water flow after 3 hours
bad pump motor replace pump its overheating
Jun 23, 2014 | Intex Pool & Spa
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
The engine on my 2000 MPV cuts out and dies when I press the accelerator. After it sits for an hour or so, I can travel for 20 min. or so before the problem starts again. HELP!
if its been a while change the fuel filter and then have the fuel pressure and volume checked.these symptoms are very common for a fuel pump problem.
Feb 07, 2012 | 2000 Mazda MPV
Car overheated Iin November of 2010. Turned it off, cooled it down, added coolant - no further problems. Today, May of 2011, red warning light came on 10 minutes into drive. 50's outside temp. ...
Sounds like a bad water pump or radiator. Make sure the radiator fins arent clogged or inside of radiator, water pump not circulating the coolant properly will also cause overheating, old coolant will not properly dissipate heat efficiently and may need flushed. Also make sure the coolant has a 50% mix of water as the water does most of the cooling not the antifreeze. Hope this gives you some good places to start.
May 13, 2011 | BMW 325 Cars & Trucks
Engine shuts off while car is driving. Still have all electrical. Try to restart car and motor will turn over but not crank. Try to restart car a few hours later and car starts and runs for about 10...
Many times a problem like yours can be traced to a failing fuel pump. When it gets hot it binds and stops, later after it cools off it functions normally 'till it gets hot again. Next time is dies, immediately turn the key off, then to the run position and listen for the pump (humming in tank) if you don't hear it, likely that's the problem. Never buy parts without testing though. A pump alone can set you back over $200.!!!
Apr 18, 2011 | 2003 Jeep Grand Cherokee
New onga JS120 pump worked fine for 4 months bringing water from tank up to house then suddenly stopped.We undid the pipe and reconnected it,the pump worked again but stopped again after a few...
a number of possibilities like insufficient pressure in the bell or pressure leak 'or pump motor dying
but i'd be looking at a warranty claim
May 11, 2010 | Plumbing
I recently completely replaced the radiator, hoses, water neck, thermostat, and water pump in my 2001 blazer. The temperature gauge stopped reading correctly, saying my car was overheating, which i...
most likely a blown head gasket between a coolant passage and an oil passage not a cylinder . when coolant gets into a cylinder is when you will see the white smoke and the smell.
Feb 24, 2010 | 2001 Chevrolet Blazer
Swimming pool pump wont drain above ground pool
you are clogging your impeller take a wet vac put hose your using for pump in pool put vac on end of hose to woods and turn on vac long enough to get a water flow and shut of vac it is slower but will save pump
Jul 07, 2009 | AO Smith A.O. Smith Threaded Shaft 1 HP...
A.O. Smith SQ1102 Pool Pump Motor Logo
396 people viewed this question
Top A.O. Smith Plumbing Experts
Donni Steen
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
