Question about Logitech Cordless Mouse
Cordless logitech mice interference
Two cordless logitech mice, each connected to base station without problems and separtely. Once used in same office area using 1 mouse causes the other one to stop responding (not move in the same fasion as might be expected) any simple cheap solutions for this?
Batteries have been checked and replaced, each mouse is fine when used on it's own.
  • 249 Answers
Hi!
I think what happens there is that both mice is running on the same frequency. What you need to do is to restart the wireless of just one of the mice by pressing the connect button on the usb reciever and on the mouse. That way it would try a different frequency.
I hope this helps.
Posted on May 05, 2010
Testimonial: "A lot better functionality than it was now. Not perfect so likely to be some other source of interference in the room, this will be checked out. Thank you for the speedy response."
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
The compatability of the driver on different board matters here. Multiple mouse used on same station at times shows this issue. Dont worry download the exact driver for both and try reinstall and this should work. Also try if these mouses work together in safe mode. Good Luck
I cannot remove batteries from Logitech cordless optical mouse EX100
Possible that the batteries have leaked and stuck , if so use some degreasing spray like WD40 on the base of the terminal connection , let it soak a bit and then try to pull off the battery use a bend flat rod or screwdriver.
Once removed you must clean the surface and see if there is damage on the unit. If so clean and wash before new battery is replaced.
Oct 17, 2011 | Logitech Cordless Desktop EX110
Cordless Keybaord - Some keys not functioning
Could be interference from a wireless device using the same frequency. Locate any other wireless keyboard/mice from the vacinity and try it again. Also, push the connect button on the bottom of the keyboard and see if that helps. Also make sure the base station of the keyboard is close enough to the keyboard/mouse.
Jun 25, 2010 | Logitech Wireless Access Duo Optical...
I changed batteries and forgot how to reconnect. It is plugged in via USB, batteries are birght. I have pressed the connect button on the base. It flashes but the mouse does not work. I have pressed the...
This is from the manual for the Logitech MX700 cordless optical mouse.
1. Press connect button on Base Station.
Its LED blinks green. 2. Press connect
button on mouse bottom. Base Station LED
turns solid green, and then off.
I hope this helps
Mar 07, 2010 | Logitech MX 700 Mouse
The batteries died on my cordless mouse. My
Make sure that the switch is turned ON after replacing the battery. If it's ON, try holding down the connect button on the USB receiver (that's connected to the computer) and then hold down the connect button underneath the mouse AT THE SAME TIME for 5 seconds and release them both.
If same problem occurs, make sure that there are no possible wireless interference near the mouse. Example, base of a cordless phone or a mobile phones. These devices' signal might interfere with the wireless signal of your mouse.
Thank you!
Dec 09, 2009 | Logitech S 510 (967555) (DH967555)...
Have to constantly reconnect mouse to base station
Definitely clean the connection, in both the mouse and the computer. Blow gently in them first, and try it. If you still have problems, I would take a Q-tip and lightly moisten it with rubbing alcohol (because it evaporates very quickly), and run it inside the connections of both! Let dry, and try again. If you still have problems, consider purchasing a new mouse.
Sep 08, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
My Logitech LX5 wireless optical mouse has never worked properly
hi im josh in cebu phils.may i help you? Friend try my gathered solutions. This problem has a simple solution—replace your batteries! Low batteries in a wireless device will cause all sorts of problems. In a mouse, this typically means that the cursor slows down, jerks around, or seems to hit an invisible wall. Fresh batteries should fix things right up.
If new batteries don't fix the problem, you have some sort of wireless interference. Try moving the wireless receiver to a new position—preferably away from other wireless devices (wireless network adapters/base stations, cordless phones, baby monitors, and the like). If interference continues, see if you can change transmitting/receiving channels on one of the devices, or consider turning off the interfering device while you're computing. Good luck friend hope i helped you.
Mar 04, 2009 | Logitech LX5 Cordless Optical Mouse
Lose connectivity betw Logitech Cordl and base
You probably have a cordless telephone or wireless network connection that is periodically blasting the frequency band that your trackman uses.  The only solution is switching to different frequency bands on these devices.  If you can simply unplug these gadgets for a few hours you can identify the culprit.
Feb 10, 2009 | Logitech Trackman Cordless FX...
I got 2 logitech wireless mice in same desk, because I dont have anywhere else to place them, and they interference with each other...How can I change frequencies? Please help Thanks
This is in the logitech knowledge base.
Question: ''When I move my cordless mouse, it moves the cursor on the system next to me. What should I do?''
Answer: ''This is called ''Cross talk'' and is characterized by one cordless device controlling the cursor or keyboard input of another device connected to a different computer. To avoid possible interference, try to keep the distance between systems at least 10 feet. Also, moving the mouse closer or further away to the receiver can also improve transmission and performance. If the above fails, try pressing and holding the ''Connect'' button on the receiver for 10 seconds. This will reset the receiver's connection information and allow you to do a first time connection with the receiver and mouse or keyboard. After holding the Connect button for 10 seconds, then press the Connect/Channel button on the bottom of the mouse to synchronize it with the receiver. If you have a cordless keyboard instead of, or in addition to, a cordless mouse, press the ''Connect'' button of the receiver again, then press the ''Connect/Channel'' button on the Keyboard. Perform these same steps on any other Logitech cordless devices in the area that are experiencing cross talk. Another step that can be tried is to remove the batteries for 15 minutes. Then re-insert them and boot the computer up. It is important that during this time, you do not press the connect button on the receiver or keyboard of the other cordless desktop system.
I could not find anything on mouse crosstalk in the Microsoft knowledge base. Perhaps the problem is not so common for MS mice because of their more limited range.
Buying a new mouse was suggested. This may or may not work if you bought a new Logitech mouse, as it could wind up on the same troublesome frequency. Of course, if you replaced the Logitech mouse with a Microsoft mouse, their limited ranges might eleminate the problem, even if they used the same frequency.
Apr 22, 2008 | Computers & Internet
Cordless MX DUO charger
try removing the batteries from the mouse and place it in the cradle. If the light lights up or flashes, there can't be a problem with the base station contacts. I have the same problem, but I think the problem is inside the mouse.
Jan 10, 2007 | Logitech Cordless MX Duo 967300-0403...
Logitech Cordless Mouse Logo
602 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
