On a patio heater why is the flame yelow and noisy
On a patio heater why is the flame yellow and noisy
  • 1,476 Answers
Your gas/air mix is not correct. Not enough air. You should be able to adjust the unit and correct this. Read the manual first to find the adjustment and procedure. When properly set the unit should have a blue flame with a white or very small yellow tip. Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 05, 2010
Burner lights and burns yellow flame
Lack of air causes it to burn yellow clean out burner air ports
Oct 11, 2016 | Endless Summer 153100 Open Flame Patio...
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
Pilot light won't stay lit when I let go of the igniter knob. Flame is yellow and long.
Sounds like the Thermocouple has failed and needs to be replaced. It's not difficult to do. But, finding the part may be. Blue Rhino, is the manufacturer for Endless Summer Patio Heaters, so start there.
May 19, 2011 | Endless Summer 2009 Open Flame Patio...
I have an Endless Summer (Blue Rhino) patio heater with model number 153100 and the pilot flame is not strong enough to keep the thermal coupling open. What has to be done to fix that?
The pilot jet may be clogged. If there is a flame, it must be small and blue. A large flame that is orange or yellow tipped means that there is a partial blockage in the pilot assembly which needs to be cleared. The pilot flame must also touch the thermocouple in order to heat it correctly. Make sure that the pilot jet and thermocouple are positioned correctly. If you have an extremely small pilot flame, try repalcing the regulator and hose as the regulator may be failing.
Sep 02, 2010 | Endless Summer 153100 Open Flame Patio...
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
Endless summer patio heater--turn it on full and it just gives a low flame. It is blue , but no orage or yellow tips. I have already cleaned the burner and orfice.
There is probably a pressure regulator somewhere in the gas line... this will need to be adjusted to a higher pressure or it has gone bad...
heatman101
Apr 21, 2010 | Endless Summer (GA200209) Stainless Steel...
Out of the box the patio heater didn't work and I never returned it. The pilot would light then when you move the knob to the on postion the pilot would go out and it wouldn't fire up. I bought a new...
When the pilot flame is tall and yellow it normally means there is a partial blockage in the pilot tube or pilot jet orifice. Try cleaning out the pilot tube and orifice.
Mar 16, 2010 | Ace Hardware Living Accents Patio Heater...
Can you telll me how many BTUs is has?
There is a UL plate on the heater it should strate the BTU's on it I did find this for you Berkeley Forge G-PH001PSS Open Flame Gas Patio Heater. Patio, Alimentation: Gas, Open Flame, 12000 BTU
Oct 12, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
RTA International Patio Heater Won't Burn Properly
I would check the burner is not blocked and check the injector as well.
May 06, 2017 | Rta International Patio Heater With Table
Heating & Cooling Logo
140 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
