Question about Maytag LAT3600A Top Load Washer
Water does not fill the machine
When we set the unit for the proper water quatity and then pull out the selector knob, the water does not discharge. Can you help?
Note: The water works everywhere else in the house.
  • Maytag Master
  • 43,501 Answers
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Posted on May 05, 2010
Water is not coming in to washing machine when Start knob is pulled. When I disconnect both hoses, water is coming through faucets. Spin cycle is working fine.
ok
Two things control the fill. The fill "solonoids " ,hot and cold, via the temp selector
and the water level switch.Check cold only. If you get cold then your problem is definitely hot solonoid or temp select switch.If you get no water of any temp
then suspect water level switch and or temp select.Water level switch is behind console.Sometimes just turning level knob will get it to work . In any case, remove console and find the large switch with the small tube attached to it. If that tube gets kinked or clogged the machine won't stop filling.Your problem is the opposite. The switch thinks the tub is full. To test the swich, pull start knob.Put a volt meter or simple test light to one side of switch and ground, Then do same test on other side of switch.
There should be voltage available on both sides .If voltage on one side. replace switch.If voltage on no sides, the problem is the timer.(Not likely)Remember ,this test there is live electricity use extreme caution please!
Hope this helps
Sep 15, 2011 | Washing Machines
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
Washer won't act right
Most likely this is a problem with the main cycle knob, if for some reason the knob is not fully pulled
out, it just won't work, only fills with water, and the timer is the responsible one for the draining, but
the timer itself is not at fault, have your main knob selector switch checked.
Nov 02, 2008 | Maytag Performa PAV2200
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
Jul 24, 2008 | Miele Coffee System
Washing machine trouble
You need to replace the water level selector switch. You can check the part at repairclinic.com
Jun 27, 2008 | Washing Machines
Washing Machine won't stop filling up
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
May 20, 2008 | Maytag Performa PAV2200
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore 70 Series heavy duty washing machine
Kenmore
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Mar 01, 2008 | Kenmore 22422 Top Load Washer
WATER WILL NOT FILL
if no voltage at water valve when unit is set to fill and timer knob is in its correct position ie pulled out then you probally have a bad water level switch or a bad timer
Oct 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag LAT3600A Top Load Washer Logo
135 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
