Samsung dlp model HL-R5064W about 3 years old im getting greenish white dot lines vertical about every inches to every 6 inches have had one service person in to look at it but said he need it to take it in to find out for sure what it is said it might be dmd board said any where from 800.00 to 1000.00 to fix any ideas if its something else
  • luke25 Mar 26, 2008
    where are they located
  • luke25 Mar 27, 2008
    do you have any pictures
  • 59 Answers
Hi..it is the DMD board (digital mirror display) but IF it can be repaired it would cost around $300.00 to repair and $970.00 to replace. I would tighten the screws that hold the mirror to the board first. All four of them. Sometimes if the screws are loose, you will get the vert. lines too.
Posted on Mar 26, 2008
  • 1 more comment
  • LeAnn Hill
    LeAnn Hill Mar 27, 2008
    The DMD board is encased in a flat metal can. Just wedge the cover off the can. Inside you will see the square metal bracket that covers the DMD mirror (you will not see the mirror just the metal bracket that covers it). Tighten the 4 screws in the bracket (one on each side). If this does not fix it, then your DMD board will need repaired. Good Luck!
  • LeAnn Hill
    Sorry no pictures, but I will work on those pictures for you
  • LeAnn Hill
    LeAnn Hill Mar 29, 2008
    Here is your Samsung light engine. The silver can is your DMD board. Gently take the DMD off your engine (2 screws on your left side, 3 screws with springs attached in the middle and 1 screw on the right lower corner). Gently unplug all wires and ribbon cables. On the back side of the DMD you will see your DMD mirror. Do not touch the mirror with you finger. It will leave a finger print on the picture when you reinstall it. If this happens clean it with a little Windex and let dry before installing. The 3 screws with springs that you took out in the middle, is where the DMD mirror bracket is. Gently pry open the can on the DMD board and then tighten the 4 screws that surround the DMD mirror bracket. Reinstall and plug all wires and ribbon cables in.
I'm looking for that wire harness that your not to pull on when replacing the color wheel ,it plugs into the cn110 socket.
Posted on Sep 22, 2008
SOURCE:
Samsung, DLP TV 50 inches Model # HL-T5075X/XAA
Samsung just told me they wouldn't fix my tv because it was produced in Nov. of '06 and the only ones they would fix were made in August of '06 or earlier. I am way too angry right now to call the service tech number they so very nicely provided.
May 19, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp white dot
If the white dot is on every picture and every input and stays there for a sec. after you press the power button to turn off the tv then suspect a stuck mirror in the DMD.
Sep 29, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots on samsung dlp
HI, these are the signs of a failing light engine. you will need to replace this engine soon. these distortions will worsen over time.
Jul 19, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White lines on Samsung DLP
need the modle number to see if there is a service flash or fix/
Jul 29, 2008 | Samsung DLP HL-P5663W 56" TV
Dlp white vertical lines
YOU NEED CHECK THE 3 CRYSTALS ( RED, GREEN AND BLUE). CLEAN IT WHIT "DUST REMOVER" ( compressed gas duster) AND REPLACE THE COLOR WHEEL.
Jan 17, 2008 | Televison & Video
Samsung dlp
do they look like jail bars ,running from top to bottom.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
1,210 people viewed this question
Top Televison & Video Experts
Ekse
