Question about Delta 2 Handle Lavatory With Metal Pop Up Less Handle - 2583-LHP - Chrome
Hot water: Pipes make a banging noise when turned on full force.
Other Facuets do not make this noise. The Condo is only 3 years old.
Only the master bath is making the noise. (Only at full force...is OK when hot water is turned on half way or less.)
Bath tub is fine also.
All facuets are Delta.
    Guru:
  • 351 Answers
Hi, That banging is sometimes called a water hammer. It is made when the water hits an elbow in the piping with a force and bangs into the pipe itself. It is more likely to occur in a long run of pipe. This can be reduced or eliminated by installing an empty tube verticle in the piping near where the hammer is occuring. This tube can be found at most building supply stores. The tube is a pocket of air that acts to absorbe the extra pressure from the piping and stops it from hammering.
Posted on May 05, 2010
Saunier Duval ISOFAST F35E on hot water only makes a noise like a motor bike that vibrates through the pipework, this does not happen when the central heating is on, any ideas as to the cause.
The water pipes (steel) are probably full of rust. The noise is air in the pipes.
Use the pressure relief valve to let air escape.
The risk is if the relief valve is old it may not shut off.
Also air will build up again
Nov 05, 2014 | Water Heaters
Changes in amount of water flow from shower head
when he soldered the connections on these pipes.. he may have partially blocked the flow with solder inside..if its restricted up to 50% then its a hell of a pressure loss..hot water is always lower in pressure anyway..also take the shower head and dunk in a clr solution it may have calcium deposits inside the small plastic orafices in it..
Jan 12, 2014 | Water Heaters
Baxi banging noise
noise in water pipes is called water hammer and is when the water flow pulsates from an inconsistent flow. Water has mass and when stopped suddenly there is a pressure build up which moves any loose pipes. It can be fixed by putting more securing or mounting saddles on the pipe to hold it steady or you can get a pressure accumulator and it takes up the pressure build up and stops the noise. It is most prevalent when sudden stop taps are used such as ceramic taps or stop cocks and less so when you have to screw down the tap to shut off the water.
Jun 24, 2013 | Heating & Cooling
After changing my Delta shower cartridge i hear a whining noise when i run hot water in the shower. If I also turn on hot water in the bathroom sink (at same time) I get a banging noise from the pipes. ...
the banging noise is called water hammer and there are devices that can be added to your water lines to absorb the shock.
As for the noise, when you had the old cart out, did you flush out the faucet by turning in the water for a few seconds after removing the old one? This is a four hand job, one to control the water gushing out of the faucet and the other to conrol the shutoffs.
check seat and spring for correct assembly, the whine is caused by water pressure and flow obstruction.
Jun 20, 2013 | Home
Noisy water pipes when neighbours use water
Install air chamber to cushion sudden-stop of flowing water.
Water flow coming to sudden stop is called water hammer, and will bang pipes, but also loosen plumbing joints, causing leaks.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#bang
http://waterheatertimer.org/images/Flow-rates-water-hammer-600.jpg
Air chamber has to be vertical, and about 18" long, with cap on top.
By code each Hot and Cold line at each tap will have air chamber located behind the wall. So there are two air chambers at each tap.
In your case, you can probably add air chamber to your Hot and Cold lines and solve problem for both dwellings.
Water hammer is caused because water does not compress like air.
So when long column of water suddenly stops... the whole pipe-full of water comes to sudden halt... and that water could weigh 1-1/2 pounds ... and just like a hammer head moving, the weight of water bangs the pipes to dissipate energy, causing noise.
Apr 21, 2013 | Water Heaters
Banging noise when hot water is turned off
plenty of water pipes particularly in older houses where pipes may not be fastened tightly or at all to the frame of the house suffer from what plumbers refer to as waterhammer. This can be fixed by installing a small device inline from your local plumbing shop. It can also often be solved ( I have found) by fastening you water pipes at closer intivals/more securely to your house frame. Hope this helps. Mine stopped doing it once the pipes were locked in place.
May 11, 2012 | Rinnai Water Heaters
At the startup of every washing cycle the washer slams the water on and off and bangs around our pipes. I called in a plumber who said we could tear into the wall now or wait until a leak appears. No of...
Slamming of the pipes happens because of the water pressure and and the sudden opening of the water solenoid. The solenoid has to open suddenly as it is activated by a magnetic coil that pulls a plunger valve open. There is a spring (return spring) on the back of the plunger that compresses and gives the plunger a return power push to seat the plunger when the power is turned off. In the past few years, plumbers have been loosely connecting pipes in hangers so that they move with the change in water pressure so as not to bang and cause a noise that upsets the home owner. Also many homes are plumbed with plastic pipe that stops a lot of the pipe noise. Most washing machines and refrigerator ice makers that have water solenoids make some noise, but engineering has mitigated a lot of this with the return springs that have the strength to slow the action of the plunger in the solenoid, but yet open wide enough to allow full water inlet.
I suspect that your water pipes are not slung properly to mitigate the bang caused by sudden pressure drop, thus you most likely would get a pipe bang from any washers.You could try changing the solenoid in your washer on the premise that the return spring is weak, but this probably will not solve all of the problem. The banging is just upsetting and does no harm as it is a natural action.
You could test this out by hooking a garden hose to the water outlet at the washing machine and using a trigger release sprayer on the garden hose. When you trigger the garden hose, I suspect that you may hear a pipe bang.
May 19, 2011 | LG Washing Machines
I HAVE A 50 GALLON 5YR OLD RICHMOND HOT WATER TANK SOMETIMES YOU TURN ON HOT WATER AND IT RUNS FINE.THEN ALLOF A SUDDEN THE WATER STOPS AND PIPES BANG.WE HAVE 44PSI COMING IN FROM CITY
What you're describing is "water hammer". This problem, left unchecked, can cause big problems for your home's plumbing. Water hammer is result of quickly shutting off the flow of water in your home. The faster the rate of water flowing when it is rapidly shut off can result in very loud banging. The banging is caused by the pipes shaking in the walls, ceilings and any place they aren't secured. This repeated shaking causes soldered and glued joints to weaken and eventually fail. The most common sources for water hammer are toilets and wash machines, but even quickly shutting off a faucet can cause it too.
An short article about water hammer is here. Below is a link to images of products designed to arrest water hammer and associated noise.
Please rate this reply - I hope this helps!
Dec 06, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Heater making loud noises
I had this problem with mine ( hayward h series abg100 ): exhaust fan turned on, waited approx 15sec, gas turned on, ignition, flame lit (can verify in flame window below knob), stayed lit for ~5-10 seconds (varied), I heard popping, cracking, knocking, banging noises, then gas turned off.
I believe the reason it does this is the bypass/diverter plate in the exchanger (right at the inlet side) is loose; the weld broke loose. They weld this very poorly and is obviously a known issue with the unit. I think storing it outside in the winter doesnt help. Another reason for the noise could be not enough water going through the exchanger because of a problem with the diverter plate, therefore the exchange gets to hot and boils.
I believe the ignition board senses this somehow (not sure how though, only way I can think of is via the ignition sensor), and cuts off the gas. I managed to fix this by putting on a small stainless steel hose clamp around the thermostat forcing the divertor plate tight up against the top so the water flows through the 3 exchange pipes. This was a very difficult maneuver due to working inside the tight pipe, but it worked!
You can check if you have the same problem as me by taking off your hose input to the heater, and removing the outer 2 PVC reducer connectors. Then you'll have access and sight to the exchanger input (3" pipe?) and should see what I'm talking about. If the plate moves (or isn't tight) then you most likely have the same issue. kevin71246@hotmail.com if you have questions.
Jul 06, 2009 | Hayward H Series Induced Draft Abg 100,000...
Delta 2 Handle Lavatory With Metal Pop Up Less Handle - 2583-LHP - Chrome Logo
483 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
