Question about Panasonic NN-SD797S Microwave Oven
I have a Panasonic NN-SD787ST with the sensor cook feature. I can't get it to fully cook more than one meal during a dinner prep because when I put the second item in, it continuously shuts off thinking it's done when the item is still cold/frozen. Can this sensor be disabled?
  • 833 Answers
SOURCE: sanyo microwave EMS667W, diff high power ratings
A couple of things: If the dinner is in an aluminum pan, DON'T put it in your oven. Typically, high power units need about 3-5 minutes to heat a dinner so you should have heated it through. The power default is usually full power. Usually, there is a minutes button that should give you incremental minutes for programming.
Try using a standard nonmetallic cup (beaker) and fill it with water. Heat for 2 minutes. The water should be boiling hot. If not, your oven is not doing it right.
Posted on Mar 10, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave re-started
The Start pad on the keypad may be starting to short. If so, a new keypad (membrane switch) would fix it.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's at
http://www.microwavedisplay.com/keypad_replacement.pdf
We have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The part # needed is A64795790AP "membrane switch" for $46.88 available here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Oven Panasonic NN-5560A
Chances are your Start key on your keypad has failed.
It is part # A64795790AP "MEMBRANE SWITCH", it runs $46.88 and you can find it here:
If you would like to have us do this for you, we do that for $39.95 plus part costs.
woobie dog
  • 1273 Answers
SOURCE: low power
Check the power output. Most are adjustable. With the microwave on, and cooking something, see if it is on 100%. If not, adjust it with the keypad.
Regards, --W/D--
Posted on Aug 01, 2009
fathitkf
  • 1871 Answers
SOURCE: error code h97, on a genius prestige microwave -
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Posted on Apr 13, 2010
How do i unlock my Panasonic NN-SD787ST? All features work but want start and displays locked?
Press function pad then for child lock push pad 5, 1 in on and 2 is off this is from the manuel I have for A NN-S787BAS 787WA, 878WAS, 878LA, 787BA ETC. HOPEFULLY THAT HELPS
Jul 02, 2017 | Panasonic Microwave Ovens
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
Panasonic microwave oven nn h965wfx
either your magnatron is bad or hopely it could be your high or low heat sensor
Oct 13, 2013 | Microwave Ovens
What wattage is genious prestidge NN-SD787ST
Max power consumption: 1460 Watts
Rated cooking power: 1250 Watts
Manual link.
Panasonic NNSD787 Operating Instructions
Page screenshot:
Apr 17, 2013 | Panasonic NN-P794SF Microwave Oven
Tried pressing Buttons but it will not exit Demo Mode.
pull plug let it set couple min. then plug back in and try
Apr 01, 2013 | Panasonic Microwave Ovens
Discussion on the appearance, aesthetics, form and colur
Hello dutch.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts
Microwave Type: Over-the-Range Cooking Power: 1200 Watts Capacity: 2 cu. ft. Convection Cook: Without Convection Cook Dimensions Exterior Depth: 15 in. Exterior Height: 9.5 in. Exterior Width: 23.25 in. Miscellaneous Product ID: 22541798 More Information Details: Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
Dec 08, 2010 | Panasonic NN-S254WF Microwave Oven
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
WARNING :
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Jun 03, 2008 | Microwave Ovens
Panasonic NN-SD797S Microwave Oven Logo
255 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
