Question about Hoover F7431-900 SteamVac Vacuum
Suction Problem I just borrowed the Hoover Steam Vac Deluxe w/ 5 brush agitator from my neighbor and it worked ok for the first few minutes, although the suction would stop and go. When I had enough water to dump I did it and when I put it back on it no longer sucked the water up from the carpet. She admits to having it for 15 years, but why did it have to break on me. Makes me look as though I did it!
  • 3 more comments
  • jstmylk Mar 27, 2008
    Thank you very much this was sooooo helpful. I wonder if she knows this too. I am sure she must after having it for 15 yrs! Just wished she would have told me if the suction stops...not to panice, this could be the reason. Thanks dragon640! you rock and so does this site!
  • Anonymous Mar 28, 2008
    THE SUCTION WORKRD FINE AT FIRST, THEN WHEN REFILLING...
    THE WATER COMES OUT BUT WILL NOT SUCTION IT BACK UP!
    THIS HAPPENED BEFORE AND A HOOVER MAN SUPPOSEDLY "FIXED" IT...... NOW I NEED TO KNOW WHAT TO DO TODAY.  BEFORE, THE SOLUTION DRIED BEFORE I GOT THE MACHINE BACK, REALLY DOING A NUMBER ON THE CARPET
    IT IS F5815, 059400078217.......MARY CRAWFORD
    1-251-626-7361     thanks, thanks
  • Anonymous Jun 07, 2008
    There is no suction and the carpet is all wet...
    There is no stopper in the way to stop the suction...
    I cleaned the heads and checked the dirty water tank to make sure it was affixed properly. Not sure what to do next. Any ideas?
  • Anonymous Jun 15, 2008
    the vacum won't **** back the water?
  • dw_kb2001 Mar 31, 2009
    used it on upholstery for last two days then tried using it to clean carpet hardly wetting the floor, so i went over it agian and tried to suction up water, its not picking anything up.
  • 25 Answers
Check and make sure the dirt water tank is properly on if it it is chech inside the lide to make sure the red stopper is not stuck to the top this will cut off the suction
Posted on Mar 26, 2008
Hoover carpet cleaner f5915905 the handle release won't lock. what should I do ?
Repairing the Hoover Steam Vac Deluxe - YouTube
? 6:01
https://www.youtube.com/watch?v=QBtWcC4gqjY
Apr 21, 2009 - Uploaded by general0ne
I think Ill make one for the Dual V steam cleaner and provide some tips on maintenance. Good job ... The ...Missing: lock
Dismantling the Hoover Steam Vac Deluxe - YouTube
? 6:16
https://www.youtube.com/watch?v=sul52ULCR90
Jan 12, 2010 - Uploaded by general0ne
Dismantling the Hoover Steam Vac Deluxe. general0ne .... Aftercleaning the screen as shown on the video ...Missing: f5915905 ‎lock
Nov 29, 2015 | Hoover Vacuums
How do you get to the belt on a Hoover steam vac?
I hate to tell you, but there is no belt at all on the steam vac line. they have a suction driven turbine to turn the brushes, and a suction driven pump for the water flow. But definately no belts.
If something is not working on it, describe more in detail what is not working and we can narrow it down better for a proper solution.
Nov 06, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac deluxe - no suction and the scrubbers aren't spinning uless you tilt off the floor.
I would suspect that your turbine assembly bearings need to be replaced. also check for debris inside the brush assembly. check the intake filter under the front clear cover. verify the recovery tank lid is on securely, as well as the foam filter on the tank lid is clean.
Oct 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes on hoover deluxe steam vac cvarpet cleaner are not rotating. Took out the brush assy and drive spins slowly but with little torque. Cannot seem to open the bottom to see if belt or direct...
(1) Assure the brush shut off lever on the hood is not set to the off position.
(2) Is there still a square pin standing up from the one drive brush? It should be 1/4 square, and about two inches tall. That pin is the drive from the transmission to the brushes.
There are no belts. The transmission is air and gear drive mechanism.
Oct 02, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Loss of suction
Make sure the recovery tank lid is on correctly. Also make sure the float on the receovery tank lid is down.
May 24, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Problems with the Hoover Steam vac Heated carpet cleaner
The first thing to check is the filter on the inside of the lid to the recovery tank, if it is all of the way up to the top, it can cause variouys problems, it should have a 1/4 in gap from the top. The other thing is the turbine, that is what drives the brushes. If the brush block is ok, then most likely the turbine is bad and will ahve to be replaced. Part # for the turbine is 43191006 and sells for about $60.
Nov 18, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
273 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
