Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
14 hp kohler engine (Cv14s 1451) runs good for 5 minutes stalls then won't restart for 1.5 hrs. Took apart carb and cleaned, changed plug (increased power runs smoother but problem persists).
I had this issue on my 14hp kohler and it was the ignition module. Would run until it heated up then shut down.
Posted on May 18, 2010
    Problem Solver:
  • 13 Answers
You have a bad coil
Posted on Nov 18, 2012
Kohler command cv14s rolls over but backfires through carb
Check the resistance (ohms) of your new switch and wiring. Sounds a though you are not getting good voltage, also check battery voltage.
Sep 17, 2015 | Garden
I have a26hp kohler engine on my craftsman riding ractor and it doesn't run after 5 minutes. I have changed the carb, and tune it up with Sears parts and it still does the same thing. How can I te
they make a inline spark tester you can put inline to the plug so the plug fires and you can see but that motor has 2 coils so if 1 cuts out the other cylinder will keep on going so if your loosing spark look at the safety switches the seat the clutch/brake pedal the trans shifter etc if its starving for fuel the gas cap vent could be plugged not allowing the tank to flow fuel
May 08, 2012 | Craftsman Garden
Poping while trying to start
Over time carbon deposits build inside the engine including the valves, seats and spark plug. Easy to change plugs however not so easy to clean carbon. There are products at auto parts store that you can pour into carb and add to fuel that can help to eliminate deposits. Leaking valves can cause poping noise, backfire etc. Easy fix is to try using products mentiond above then new plugs and add several gallons of premium fuel to increase the octane level. If the engine does not run however suspect old fuel or water in fuel bowel. Try spraying carb cleaner into carb little at a time to keep running. If the engine runs with carb cleaner, suspect fuel/carb/pump problem. Good luck
Oct 20, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Engine runs great for 10 minutes and then stalls. Won't start until is sits 3-5 minutes. Replaced fuel lines, filter, cleaned carb., replaced spark plug. What else could be causing this?
Believe it or not, your gas cap is clogged up with dirt and debris. When a carburetor is unable to get a constant flow of air from outside, pressure builds up on the fuel tank. The fastest way to determine whether or not this is the problem is as follows.
As you are using your Mower, at that point when it begins to stall out, loosen the gas cap so that you release the pressure that is built up in the gas tank. If the engine begins to regain power, then you know it is a clogged gas cap. (Simply get a small wire and clear the breathe holes in the cap.) If the engine dies even after loosening the gas cap, then you may want to check to make sure the air breather is clean. ( A dirty air breather can cause the engine to over heat and stall out.)
If none of this seems to help, then it is probably a bad Ignition Coil.
Good Luck!
Jim
Jul 29, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Owners manual for a toro cv14s
go here https://lookup3.toro.com/request/request.cfm they have a link where you can print your own owners manual for free....good luck
Apr 05, 2010 | Toro Lawn Mower With Toro Power Tools
Kohler CH20S losing power, blowing black smoke and oil
Sounds like engine is flodding. Have carb float checked, make sure it is at the correct height
Feb 04, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Small engines
YOU NEED A CARB KIT IN THE CARB IT NEEDS TO BE CLEAND OUT
Sep 25, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,049 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
