Question about Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
Camera does not recognice that memory card is unlocked
    President:
  • 1,902 Answers
There are two things
1. you need to clean out the internal case of your camera
2. Your memory card is no good anymore, and you need to replace it.
Most of the time, the card is not any good and you need to replace the card.
Posted on May 05, 2010
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
My canon digital camera ixus 75 card is locked how to procedure to unlock
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 18, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
How to unlocked memory card?
A locked memory card will not allow you to write to the card; however, you will be able to read from it. Unlocking the card will allow you to delete files and write to the card. You will want to unlock it before inserting into the camera since this will allow you to store folders or files as well as take pictures with your camera.
first you need Look at the sides of your memory card for a tab in a slot.And then Move this tab up or down to put it in line with the icon that is on the card of an unlocked padlock. This unlocks your memory card. You will want to make sure it is always unlocked before using it in your digital camera; otherwise, it will not save your photos.Then you need to Insert the memory card back into your camera after unlocking to start using it to store pictures.Take the memory card out when done.
Move the tab on the memory card back to the closed padlock to re-lock it. This is not mandatory; however, it will ensure that your photos do not get deleted if other people have access to your camera. You can store the card in the camera or the case that came with the memory card.
That it!
Apr 17, 2011 | Cameras
Not recognice in any computer device
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Nov 08, 2010 | Canon PowerShot G2 Digital Camera
Digital card
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Apr 11, 2010 | Pentax Optio 60 Digital Camera
How do you unlock the camera?
It is not the camera it self you need to unlock but it is the SD memory card.To unlock a SD memory card switch off the camera and remove the card. You will find a slide switch on the side of the card that needs to be slid to unlock the card..
Apr 04, 2010 | Vivitar ViviCam 5385 Digital Camera
Memory card lock
So you're having problem in your memory card?
Try this:
1. Take out your memory card from the camera.
2. There's switch to lock and unlock on the memory card.
3. Just unlock it, and put back your memory card.
Hope this help! PM me if you have another questions.
Jun 11, 2009 | Canon PowerShot A460 Digital Camera
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Mar 07, 2008 | Canon PowerShot A530 Digital Camera
Locked memory card
hi
the unlocking is due to digital camera and not due to card. card do not have any locking feature. checkup on camera password
or alternately ask replacement fm company as this as 5 yrs warranty
Jan 20, 2008 | SanDisk Memory Media
Memory card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Jan 01, 2008 | Samsung Digimax S630 Digital Camera
Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
