Question about HP OfficeJet J4580 All-In-One Laser Printer
I can't scan. Iessage saying no scan options. When I click on hp solution center from my desktop it says no hp device detected. The machine prints, fax, copy, but does not scan.
  • Gail Walker May 05, 2010
    still having problem--unable to scan
  • 4,281 Answers
Make sure your usb cable is connected properly IF you get print then it is connected properly.
This errors come when scan driver corrupt so you need to uninstall it and reinstall it.
It is better to uninstall your all hp driver then reinstall then it works fine.
If you don't have hp disk then download driver and patch update from below link.
Click chere
Let me know if you need further assistance.
thanks for using FixYa.
Posted on May 05, 2010
How to scan using hp j4580. Booklet only tells how to fax!!!!
  1. Open HP Solution Center with one of the following methods:
    • Click the Windows icon c01319360.gif , click All Programs , click the HP folder, and then click HP Solution Center.
    • Double-click the HP Solution Center icon on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
    • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
    Important : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings.
Jul 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
I have ininstalled and reinstalled software for my hp officejet all-in-one but it will do everything but scan. When I click the scan button it says no scan options. Hp Solution icon says no hp device...
I have the same printer and there seemed to be three plus ways to scan from it. The easiest I have found was having a shortcut on the desktop and right click it, then click scan. Too, I dropped the factory cd install and went to HP website to get the latest and greatest software.
If you are still having issue, let me know a bit more on what type of computer and operating system you have.
Hope this helps.
May 12, 2010 | HP OfficeJet J4580 All-In-One Laser...
"no scan options"
" no scan options refer to device documentation for trouble shooting"
you need to open up either solution center or hp director, go to settings, scan settings, then scan to set up and look for the option front panel destination a window should open to reveal scan short cuts and one titled front panel list. you need to select the shortcuts click add and once satisfied click on "update device".
Mar 27, 2010 | HP Photosmart C6280 Printer
When go to the scan to button it says no scan options officejet 6210
Mar 27, 2010 | HP OfficeJet 6210 All-In-One InkJet...
No scan options say refer to device documention to trouble shoot
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Mar 02, 2009 | HP Officejet 4315 All-in-One Printer
HP Solution Center No HP Devices Detected
Try this
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Jan 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
Can not scan to computer
hi,
below are the steps that i want you to follow. The "NO SCAN OPTIONS" refer to the absence of options when you try to scan using the printer button your printer. However, if you are going to scan from the SOlution center installed in your computer, it will scan without any problem.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab.
    NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, please let me know.
Thank you so much.
adonscott
Jun 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Scanner
First check whether you are able to scan from hp solution center.
then check whether you are able to scan from ms paint.
to check: open paint, click on file-->from scanners and camera.
if it is scanning then proceed to the following steps or else uninstall the software and reinstall it
Step 1:
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Step 2:
    2. On the Windows desktop, double-click the HP Solution Center icon.
    1. If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
    2. Click Settings .
  • If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  • Click each program to include on the Scan To list.
  • Click the Add arrow.
  • Click OK .
  • Scan a document using the Scan To button on the front panel.
  • If the scan fails, try to scan using the HP Solution Center Scan button.
  • If the above steps doesnt solve your problem, please uninstall the software and reinstall it.
    Mar 14, 2008 | HP PSC 1610v All-in-One Printer
    Can't Scan!!
    This is becasue microsoft hasnt gotten enough complaints to make an update yet, and HP cant go messing with windows programming because its not there job to fix Windows, only HP stuff. So bassically you will have to wait for either one to make a patch or fix. Im betting HP will mae one first and Microsoft will include it in ther updates later on.
    This is common with new OS's off the shelf, give it a year.
    Sorry guys.
    Jan 23, 2008 | HP Photosmart 3310 Printer
    Scan to computer
    When you installed your printer, it came with software for your computer. It should have placed HP icons on your desktop. Click the one that says HP Solution Center and then select Scan Document. Follow the steps from there.
    Jan 17, 2008 | HP Photosmart C6100 All-In-One Printer
    HP OfficeJet J4580 All-In-One Laser Printer Logo
    26 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
