Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
20 hp kohler leaking gas out front right side of motor
It will start and then die out before you take off. seems that gas is not getting to engine. Today I noticed gas leaking out the fron right side of the engine after trying to start it...
    President:
  • 1,902 Answers
Check all your fuel hoses make sure they are not broken or any holes are in the lines themselves. Also clean out the Carb and all the ports leading to the engine with some carb cleaner. If you still have raw fuel leaking then you are going to have to replace the top gasket on the motor where your cylinders are located.
Posted on May 05, 2010
Float stuck, gas pouring out when i try to start, continues to leak out afterwards, Carb located on front of motor?
pull the carby and recondition it with a new kit including new needle and seat assy
put a small in line fuel filter in the hose to stop dirt/ straw getting into needle /seat and not allowing it to shut off
Nov 11, 2015 | Mtd Cub Cadet 46 In 20 HP Kohler...
Kohler engine troubleshooting
Sounds like you got some dirt or rust in gas tank
try emptying the tank and cleaning it out. also check you bottom of you gas can too it could be souse of dirt in you tank.
Just remember to put fresh clean gas in mower gas tank after you clean it.
Aug 18, 2014 | Toro Garden
Do you hear the fuel pump running? Is there gas coming out of the pump? Could be a bad wire connection to the fuel pump or bad ground connection.
Aug 03, 2014 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
What causes Kohler 20 HP engine to smoke off exhaust after start up?
Have you tried pulling the hood off cleaning any oil contamination off the suspected area then start it and watch while it's clean. It seems weird that a valve cover gasket would be the failure after two repair shops looked at it. You may need to look close at the head gasket could possibly being blown forward. I know you said it leaks so I'm assuming there is nothing actually coming from within the motor being blown through the muffler I have seen these motors burn oil heavy on startup than clean up after warm.
Jun 11, 2013 | Husqvarna 23 Hp 48" Deck Yard Tractor
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
"Stability Control Fail" light on.
first job is to check the part load and main beather hoses are ok the stability system light may be a false indicator if the engine has stalled best is to get fault codes out of the ecm with a code reader to help but air leaks on the engine inlet side can cause strange/seeming unrelated symptoms
Aug 22, 2017 | 1997 Jaguar XK8
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
541 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
