Question about GALAXY Microsystems 63702 Top Freezer Refrigerator
Freezer is not defrosting how do you fix it - GALAXY Microsystems 63702 Top Freezer Refrigerator
    President:
  • 1,218 Answers
Good day,
The automatic defrost system is made up of 3 components. The main defrost heater, mounted to the bottom of the cooling coil,
and a defrost thermostat which is mounted to the top of that same coil but clipped to the top. It is a round disk approx 1" in diameter.
You can access both by removing the back panel in the freezer compartment. The thermostat can be checked with a vom meter but must be below 25 degrees to test properly. It should read zero ohms of resistance. The main heater can be tested the same way and should have a resistance reading of less than 35 ohms.
Here are 2 examples of both. Yours may appear different.
The last item is the defrost control itself. It may be a mechanical timer or an electronic defrost control. It is located in the roof of the fresh food compartment behind the main controls.
Here is an excellent tutorial on defrost systems.
http://www.appliance411.com/faq/howdefrostworks.shtml
Posted on May 05, 2010
Testimonial: "Thanks for the info. Might make me dangerous in knowledge area"
Freezer working fine but refrigerator not cooling
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail how to dx and fix: Refrigerator Defrost Parts .
Mar 06, 2016 | Refrigerators
I have a whirlpool refrigerator model m#EB9FVBRWS05 and the water leaks from freezer, freezer not defrosting and frost buildup . How do I fix this problem?
There are three main components in a defrost circuit, the heater, the thermostat and the control device(either a timer or and ADC board). One of these are not working.
Dec 24, 2015 | Whirlpool Refrigerators
The freezer is working but the other side is not working
Sep 07, 2014 | Refrigerators
Freezer will not deforst
Contact the service number. They have great customer service. At least they used to have great customer service hotline.
Cheers
Aug 18, 2014 | Viking Refrigerators
Freezer works but not blowing cold air in the fridge
Aug 03, 2014 | Refrigerators
What could the problem be; my refrigerator not cold but the freezer is freezing?
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail with illustrations how to dx and fix: Refrigerator Defrost Parts
Jul 31, 2014 | Emerson Cr500 Refrigerators & Freezers
This is the second time the freezer accumulates water and freezers at the bottom of the freezer section of the Admiral HMG67158, 26.6 cu ft freez/refrig. The coils behind the panel were completely frozen...
unplug unit, remove back panel inside freezer and manually defrost with hair dryer, sounds like you have a defrost problem, check defrost thermostat, defrost heater or defrost timer, defrosting with hair dryer will fix until it freezes up again
Sep 30, 2010 | Admiral Refrigerators
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Whirlpool French Door Freezer on the bottom not cooling and freezer freezing up
You have a dfrost problem if at all possible remove food from refrigerator and unplug it, leave the doors open. By morning the freezer should be defrosted and that will buy you time to fix or call someone. defrosting can be quickened with use of a hair dryer. This is only a TEMPORARY fix and freezer will need to be defrosted again after 4-5 days.
Jun 18, 2009 | Whirlpool Freezers
GALAXY Microsystems 63702 Top Freezer Refrigerator Logo
229 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
