Question about Sirius Boombox for Select Satellite Radio Receivers
Won't turn on
While playing and attached to an electrical outlet, plug was accidentally pulled out - now it won't turn on at all. all connections are completed, already tried messing with the antenna - please help!
  • 55 Answers
Try to replace the ac cord it maybe damaged when it was accidentally pulled out
Posted on May 06, 2010
How do I fix the electrical outlets in our family room? The room has 5 outlets, one of which works. The other four have no electricity. I replaced one outlet but that did not correct the problem
Check for any tripped breakers. Make sure a wall switch is not controlling any of them or that they are not on a GFCI circuit. If all OK, turn power off to outlet that works. Remove the covers from each outlet, and pull the outlets out of each box as far as you can, but leave the wires attached to the plug, making sure none of the wires contact any part of the box if its metal. Look at the wires attached at each outlet if they are not attached to the side screw terminals, but rather pushed into the back instead, note the way each is attached, then either cut them off as close to the plug as you can or pull them out of the back. Now reattach them in the correct place but put them on the screw terminals instead. Make sure all wires are secure. Turn on the power and carefully test each outlet for power. If they all work, turn off power, replace everything and your good. If still no power at any of them determine which outlet(s) have only one cable entering the box. The boxes with one cable will either be on its own circuit, or the last one in the run. The boxes with 2 at least 2 cables will be the middle of the run and one of those will be the one with the power supply for all of the others. If you don't have a signal tracer try locating tracing the wires from the 2 wired boxes in the basement, one of those wires is the feed and could be disconnected at a junction box or at the service panel.
Mar 21, 2015 | RCA 6 Conductor Modular Wall Outlet
I got this computer from my sons coach but it has a password on it how do i get pass that
Is it power on (BIOS password or Windows Password?
Clearing Forgotten BIOS Passwords (from Owners Manual Page 109)
CAUTION: To guard against electrical shock, always unplug your computer from
the electrical outlet before opening the cover.
Shut down the computer through the
Start
menu (see page 27).
NOTICE:
To disconnect a network cable, first unplug the cable from your computer and then
unplug it from the network wall jack.
Turn off any attached devices and disconnect them from their electrical outlets.
Disconnect the computer power cable from the wall outlet, and then press the power
button to ground the system board.
Remove the computer cover (see page 74).
5
Locate the 3-pin password jumper (see page 77) on the system board, and then attach
the jumper to both pins.
When you receive your computer, the jumper is attached to only one pin.
6
Replace the computer cover (see page 99).
NOTICE:
To connect a network cable, first plug the cable into the network wall jack and then
plug it into the computer.
7
Connect your computer and devices to electrical outlets, and then turn them on.
8
If you are prompted to press <F1> to continue, press <F1>.
9
After the Microsoft Windows desktop appears on your computer, shut down the
Start
menu (see page 27).
NOTICE:
10
11
12
13
Remove the password jumper.
Attach the jumper to only one pin so that you do not lose it.
Aug 05, 2014 | Dell Dimension 4600 PC Desktop
My headlight switch on the dash panel broke and I can't turn on the headlights. Is there a way I can replace the switch?
  1. Disarm airbag Failure to do so may result in accidental deployment of airbag, possibly causing personal injury.
  2. Turn ignition switch to the Off position.
  3. Remove two upper panel cluster attaching screws, then pull trim plate out of lower retaining clips.
  4. Remove two switch attaching screws, then switch assembly, Fig. 11.
  5. Disconnect electrical connectors.
  6. Reverse procedure to install noting the following:
After all work has been completed, rearm airbag
Aug 15, 2013 | 1990 Buick Riviera
Need layout of the C521 motherboard where is the BIOS password reset
Hello Brenda,
Click the link below to download the Dimension C521 Service Manual.
C521 Service Manual Clearing Password Settings
  1. Turn off the computer.
  2. Disconnect any telephone or telecommunication lines from the computer.
  3. Disconnect the computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
    To guard against electrical shock, always unplug the computer from the electrical outlet before removing the cover.
  4. Remove the computer cover.
  5. Locate the 2-pin password jumper (PSWD) on the system board and attach it to pins 1 and 2 to clear the password.
    When the computer ships from the factory, the jumper plug is attached to pin 1.
  6. Replace the computer cover.
  7. Connect the computer and monitor to electrical outlets and then turn them on.
  8. After the Microsoft Windows desktop appears on the computer, shut it down.
  9. Turn off the monitor and disconnect it from the electrical outlet.
  10. Disconnect the computer power cable from the electrical outlet, then press the power button to ground the system board.
  11. Remove the computer cover.
  12. Locate the 2-pin password jumper (PSWD) on the system board and attach it to pin 1 to re-enable the password feature.
  13. Replace the computer cover.
  14. Connect the computer and devices to electrical outlets and then turn them on.
    Thank You,
    Dell-Jesse L
    Dell Social Media and Communities
    Follow Dell on Twitter @dellcares
Mar 28, 2013 | Dell Dimension C521 PC Desktop
Cd payer will not play
Make sure it's plugged into an electrical outlet that works. Is the power cord removable? If so, then make sure it is inserted completely. Again of it is removable, then you might have accidentally gotten the DVD player's power cord mixed up with another removable power cord from something else. Sometimes, the power cord will have the DVD player's name on it.
Nov 17, 2012 | Televison & Video
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
No power , computer will not turn on
Hi, IF the system is not turning on any more, try removing the power cable, then press the power button for 10 seconds. then try to power it on again . If it is still not powering up there could be an issue wiht the power supply of the computer. But if it start to turn on, like showing the Sony logo then windows but not going to the desktop. you can try to log on using safemode. you can go there by pressing F8 on the keyboard after turning on the computer. If it still not turning on even on safe mode. there couldbe an issue with the operating system of the computer and needs to be reinstalled.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Aug 20, 2011 | Sony VAIO V2M (VGCV2M) PC Desktop
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Humming sound,very noisey.
There are usually three reasons for the hum many of us guitarists experience. First, make sure it's not coming from your patch cable you use to connect to your amp. Guitarists who have been playing a while know that these cords need regular replacement.
Another common problem is the electrical outlet it's being plugged into. Often times, if plugged into a different outlet, preferably one that it does not have to share, your amp noise can be reduced.
A great product to have is a line hum reducer, which you plug into the outlet, then plug into that. They are great at reducing line hum, and usually listed on eBay or another retail online establishment dealing with electronics and electrical products. They can range from $7.00 to over $40.00, and in the case of these hum reducers, more expensive does not usually mean better.
Finally, another common and particularly annoying problem with regard to hum, is if your guitar's components are not properly shielded. Even if it comes from a good company adn is a good model, one may have to do some additional work to get it quiet.
Pickups and other electrical equipment inside a guitar pick up and transfer many frequencies of white noise, and it can be a real problem.
Your pickups and your electronics cavity can be completely shielded by using copper tape you can find on the internet. I purchase mine on eBay but you can find it at many places.
The tape is a flat copper strip with adhesive backing. It comes in different widths, even small sheets to cover the inside back of your electronics cover in back of your guitar. The pots should be loosened from the body of the guitar and pulled (gently) enough to work in the cavity (no need usually to remove them - so no cutting of wires and resoldering is necessary in MOST models).
Loosen the screws and pull your pickups and surround them with the tape, and insulate the pickup cavities you pulled them out of as well. Do not remove your pickups completely - just move them out of the way as you work. Be careful not to pull apart any of your solder connections, or you will have to resolder or pay someone to resolder them. More work than necessary.
So these are the big top three. They are all non-complicated fixes, and following the steps I wrote should get you noticed for your guitar playing, and not for your humming.
I hope this helps. Thank you for using FixYa.
Sep 20, 2009 | Dean Dimeblade Tribute Electric Guitar
How do I remove an old dishwsher? The electrical wiring?
Is this wired directly to the Breaker/fuse box?
Or is there an electrical outlet socket under the sink that this plugs into?
Possibly for the former you may need to turn off the breaker, remove the fuse to turn off the power. Unscrew the machine where it is attached to the counter and pull it out from the counter. Where the wire is attached to the machine, unscrew it and remove it from the machine. The machine's drain hose should be removed from the drain where it is attached to the disposal or the drain pipe. Then you can discard the old machine.
If there is an electric socket that the power is plugged into unplug and follow the rest of the procedure. Otherwise after removing the machine, get an electrician to install a plug outlet so that your new machine can be plugged into the wall socket and alleviate this problem in the future.
Dec 30, 2008 | Dishwashers
Sirius Boombox for Select  Satellite Radio Receivers Logo
115 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
