Question about Music
I would like a manual for 'Base MK-939 61 key MIDI Keyboard'. Thanks
5 Suggested Answers
  • 1137 Answers
SOURCE: Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Posted on Apr 23, 2009
  • 4 Answers
SOURCE: Yamaha 61 key keyboard midi usb connected but what next
Depending on what you want to do...
If it's only music Mixing, you will have to plug your keyboard via audio jack to the line in of your computer. Then Audacity (free soft) can do the job.
If you want to edit midi file with your keybord you will need midi editor software like Linux-Rosegarden or if under windows try LMMS (all free soft of course).
Good luck
Posted on Apr 27, 2009
  • 5603 Answers
SOURCE: I have just bought a
You must use some form of MIDI sound generator module connected to get sound... It is a standalone capable MIDI generator, but NOT generating audio.
Posted on Mar 01, 2011
SOURCE: BASE MK-939S KEYBOARD speakers issue
Either Speaker is open circuit or the amp is U/S. As this keyboard is Chinese garbage, if it's not the speaker then may the force be with you. Most of the chips in this piece of high tech (not) instrument are embedded in the small pc boards with epoxy coated over to stop moisture ingress.
Posted on Oct 14, 2011
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
Ctk 810in not able to read or play midi files
If you connect to PC using USB interface, then use a commercial midi player - e.g Melody Assistant or Harmony assistant to play MIDI files to it.
Or else download "SMF convertor" to convert midi files and download compatible file to keyboard.
Aug 10, 2013 | Casio CTK810 61 Key Keyboard
Keys working explanation or user guide
You need to load software on your computer that contains midi sounds - sampletank, Reaktor, etc. Make sure everything is set to Midi channel 1.
Jan 20, 2013 | Alesis Q49 USB/MIDI Keyboard Controller
Need user manual for MK-4902 midi keyboard
Use LMMS software on PC. You will need a MIDI to USB cable which you can get on eBay.
The manual can be found at:
webpages.charter.net/rochamalhada/MK-4902.pdf
Sep 20, 2012 | Music
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I have just bought a second hand Evolution MK-161 MIDI controller music keyboard on ebay. It works fine when I play it through my computer using the virtual organ software 'Hauptwerk' (which is the prime...
Mar 01, 2011 | Music
I have yamaha PSR-i425 keyboard.can i conect it with my pc to play midi files stored in computer memory?
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Sep 08, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
SEE, IF ITS SPEAKER BUTTON IS ACTIVATED ON BOTH
Dec 12, 2009 | Yamaha Full-Size Keyboard
Apr 04, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Good luck
Oct 16, 2008 | Yamaha Portable Keyboard
Music Logo
420 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
