Question about Maytag MAV8600 Top Load Washer
Maytag mav3700aaw Wont Spin and then defaults back to rinse
I have a Maytag mav3700aaw. The problems r ...loud "clunk" sound between different cycles. and will not spin...seems to go out of balance immediately, then another loud clunk and it defaults back to the rinse cylce. Then continually repeats all of the above.
  • 12 more comments
  • grazza720 May 05, 2010
    Have checked, and all 4 seem to be in place. However I can push the bowl with ease to touch the sides of the machine. Is this the norm?
  • grazza720 May 06, 2010
    R we talking abt the same machine? mine is the mav3700aaw and has 4 rods (springs?) basically at each corner of the tub. cheers, and thanx! grahame
    Can't submit photo. Even with the camera in basic mode the pic is inexcess of the 150...what now? by the way I can't see any "springs". ta,
    g.
    PS
    Hey there John...should the springs be clearly visible when looking thru from the rear panel?
    How big r they...app length? And do all Maytag washing machines have them?
    I relation to the visible pully where should a spring be?
    Cool, it has none! ??? Do they clip into plastic holes/brackets or metal brackets. I can see 6 plastic lugs/holes (3 either side) that could poss. have a bracket screwed into them but nothing 2 obvious at the base of the machine. Is there a link where I can view a detail of this?
    Does this help u to identify the model?
    One more... let me know if these pics r ok at your end, ta!
    Is this OK?
    Australia
    Melbourne, Australia...u know the Land Down Under!!!
    view is from back panel LHS
    I'm able to push the whole tub (with ease) against the walls...is that the norm?
    your right it is frustrating not being able to find out any info on this machine. I'ce "googled" but with no real success.
    Is there someway I or u can contract Maytag?
    President:
  • 1,554 Answers
Remove the rear access cover and check if any of the suspension springs is detached from the tub braces and the suspension housing. The suspension springs make the drum centered and prevent an off balance situation that results in vibration and banging of the drum into the outer tub. Reinstall any detached spring then run a cycle to verify the operation of the washer.
Posted on May 05, 2010
  • 10 more comments
  • Jahn27
    Jahn27 May 06, 2010
    Recheck the suspension spring because there are suppose to be six of them as it is sold as a set of six. Three are attached to the three tub braces and three in between the braces spaced equally. Run the washer and observe how it behaves and where the clank is coming from.
  • Jahn27
    Jahn27 May 06, 2010
    You might be referring to dampers or shock absorbers that are attached to the outer tub. The springs are attached to the suspension housing and the tub braces directly below the tub. If possible, please post a photo of the transmission assembly as I cannot find your model in my list of Maytag washers. The parts I'm referring are based on a Maytag model nearest to the model number of your washer.
  • Jahn27
    Jahn27 May 06, 2010
    Reduce the image size by right-clicking on the image then select Open With and select Paint. In the Paint window, press Ctrl + W then under Stretch reduce the horizontal and vertical dimensions until the image size is enough to be posted.
  • Jahn27
    Jahn27 May 06, 2010
    Yes, the springs are directly visible from the rear directly below the tub.
  • Jahn27
    Jahn27 May 06, 2010
    These spring are about 7 inches total length and about 1 inch in diameter. All Maytag MAV are top load models and have the suspension springs. Check this link to see what it looks like.
  • Jahn27
    Jahn27 May 06, 2010
    Here is the service manual; download and save it immediately because the link will be deactivated in the next few hours. The spring are shown on pages 22 and 24.
  • Jahn27
    Jahn27 May 06, 2010
    Please post a close-up photo of the console including the model number plate.
  • Jahn27
    Jahn27 May 06, 2010
    Are you in the US or somewhere in Europe?
  • Jahn27
    Jahn27 May 06, 2010
    Also include the serial number of the washer.
  • Jahn27
    Jahn27 May 06, 2010
    Looks like the model of your is new and it is frustrating to know that very limited information about the model of you washer is available besides the fact that it is Korean made. I cannot even find parts for the said model to check if it has suspension springs or dampers/shock absorbers instead.
  • Jahn27
    Jahn27 May 06, 2010
    Can you post a photo of the 4 rods you stated previously?
  • Jahn27
    Jahn27 May 06, 2010
    Those are indeed the outer tub suspension rods and may be worn causing the whole tub to be pushed easily against the walls and most likely the reason why the tub goes off balance easily. Contact Maytag Australia.
Clunking/thumping with spin cycle, reduces as spin speed increase
It's hard to tell without looking at the washer. But my first response would be that the transmission is wearing out. Inside the plastic cover for the adgitator is a metal drive stem. This assembly has a pulley on the bottom where your motor attaches to; inside the bottom of your washer. It is quite common after many years that these go bad. Have you ever noticed unexplained grease or other stains on your clothes after they came out of the wash?
Apr 22, 2010 | Maytag Washing Machines
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
MAYTAG WASHER THAT WAS IN MID CYCLE AND STOPPED AT THE RINSE AND SPIN PART. TURNED OFF THE WASHER AND TURNED ON BUT MAKES A CLICKING NOISE. ALSO LOUD WHEN ITS IN THE SPIN CYCLE. HELP!!!
Sounds like the clutch spring is broken. You should have a UC or DC error code showing on the display. Only fix is to replace the clutch assembly.
Oct 22, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
As soon as the final spin cycle concludes..there is a loud clunk
make sure your laundry is evenly spread around tub when loading; most portables don't have self leveling features
Sep 07, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
I own a Maytag Performa 4 Speed/24 cycle Washing machine. it is 4 years old. Problem: A very LOUD grinding sound when washer engages into wash, rinse, spin cycles. The Tub does agitate - but I don't...
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Jul 11, 2008 | Maytag Washing Machines
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
Open Questions:
Maytag MAV8600 Top Load Washer Logo
311 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
