Is there a reset for trans belt in a lexmark 920
Is there a reset for transfer belt
  • Akili Brown May 05, 2010
    Thank you for your help. i appreciate your prompt response. have a good day
  • 6,993 Answers
there is no reset for transfer belt. Transfer belt for printers can only be replaced if bad or faulty but not reset. From my experience on printers, I have never heard of resetting transfer belt for/on printers.
I hope you understand that it is not possible. or are you referring to tranfer belt replacement?
Good luck.
Posted on May 05, 2010
Reset transfer belt error x658
We would like to know more about your issue with your Lexmark X658. Please feel free to contact us on LxkListens@Lexmark.com.
Aug 06, 2012 | Lexmark X658DE All-In-One Laser Printer
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
My lexmark is giving oerro 83 it is a C522
Error 83 indicates a problem referring to the transferbelt. Order a replacement transfer belt. When print quality is reduced, installthe new transfer belt using the instruction sheet that comes with the replacementtransfer belt. For further assistance, please contact LexmarkTechnical Support.
May 10, 2011 | Lexmark C522n Laser Printer
I have replaced my Lexmark X500 transfer belt but I cannot reset it to get the replacement message to go away and the maintenance page still shows the transfer belt as out.
Please try to check if the transfer belt is properly installed. Turn off the printer for at least about 30 seconds.
If you need further assistance please contact Lexmark Technical Support Center.
Jan 20, 2011 | Lexmark X500n Color Laser All-in-One...
84 TRANSFER BELT EXHAUSTED
84 TRANSFER BELT EXHAUSTED indicates that the transfer belt is exhausted and must be replaced. A new transfer belt must be installed to clear this error message. For assistance, you can contact Lexmark technical support or your authorized service provider. Thank you for choosing Lexmark.
Aug 31, 2010 | Lexmark Optra C710 Laser Printer
What is the lexmark belt, when i get a message the belt close to life , what is that mean
The part you need to get is called a transfer belt. This piece is how the printer transfers the toner from the 4 color cartridges to the paper. The transfer belt is a consumable item that has a life of about 12000 pages. The parts number for the belt is 40X3418
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 28, 2010 | Lexmark X500n Color Laser All-in-One...
Lexmark X500N says replace transfer belt, what is it, and how do I change it?
The transfer belt is located inisde the printer and is what moves the paper back out the printer. You will need to open the back cover of the unit then you will lift the top part of the printer off. This will expose the transfer belt. There is a bracket holding the transfer belt with two screws that will need to be removed. Then two more screws that are holding the belt assembly in place. Once those are removed then you can slide out the transfer belt assembly. The new replacement transfer belt assembly will slide back in replacing the old one. Then repeat the steps opposite to install. Then remove the four spacers on the new belt(on each corner). Then you will reset the counter for the belt and will need to run the printer alignment settings.
Nov 13, 2009 | Lexmark X500n Color Laser All-in-One...
Customer has an Sc-405 code. They reset it by turning off machine then on. The machine only works for part of day then go's back into sc-405 code again.
that is a transfer belt error. transfer belt not moving away from the drum during ID sensor pattern check.possible main motor/ drive malfunction, trans. belt position sensor problem.
Nov 05, 2009 | Ricoh Aficio 450 Copier
Lexmark C522n Laser Printer stating "83 replace transfer belt"
how do you reset the transfer belt of a Lexmark C522 colourlaserjet.
Thanks
Alex
Mar 18, 2009 | Lexmark C522n Laser Printer
Using Windows Media Player 11 or Real Player 10.5 to Transfer Music
I have one of these too and it cannot be used with media player 11 as there are no updated drivers. Use media player 10 and you should have no problems.
Jun 01, 2007 | Samsung Napster YH-920 MP3 Player
55 people viewed this question
jasbo
jasbo
