My 2 wire router is working, but we re installed windows and now we cannot connect, we are being asked to insert the 2 wire disk, which we do not have, it is saying we do not have the drivers installed
    Guru:
  • 257 Answers
Then reload your system and start from scratch it might be seeing a lot of virus problem or better still something is going wrong. so do so....
rate this solution.......
Posted on May 05, 2010
  • 4,281 Answers
First make sure wireless network adapter driver is installed and wporking fine.
then if you are not able to see your wi fi network with laptop then you need to check wireless option in router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on wireless and reenable it again then save settings and restart router.
then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Cannot format portable hdd
Step 1:
When you connect an external hard drive or USB flash drive to your PC computer, the drive should appear in the "Computer" window. However, if the data on the drive is corrupted, you may receive an error saying that the disk is not accessible. In order to get the removable disk working again, you will need to boot up your computer using the Windows installation disk and then format the corrupted drive.
Connect the removable disk to your computer. Insert the Windows installation disk into your optical drive and reboot the system. Press any key on the keyboard when you see the prompt asking if you want to boot to the CD. Press "Next" and then click on the "I accept the license terms" button. Click "Custom" when the program asks you what type of installation you want to perform. Click on the "Drive options (advanced)" button. The next window will display a list of all the hard drives connected to your computer. The removable disk will appear, even if its data is inaccessible. Highlight the removable disk that you want to format and then choose the "NTFS" option. Click "OK" to clear the data and format the hard drive.
Feb 23, 2013 | Imation Apollo Computers & Internet
How do I change from wired hookup to wireless? Bob
Instructions
Things You'll Need
Broadband modem
Router compatible with modem
Internal or external wireless network adapter
Phillips screwdriver
Suggest Edits
  1. Prepare the Network
  • Purchase and setup a wireless broadband router by interfacing it with your wired computer. Choose a router that is compatible with your broadband modem and that supports the wireless network type you desire.
  • Enable WPA or WPA-2 security, and change your router's default password. Give your SSID or wireless network a memorable name.
  • Connect your modem to the WAN (wide area network) port on your router.
  1. Install an Internal Card
  • Purchase a wireless network card that is compatible with the router you purchased and with your computer. For example, if you bought a 802.11 b/g router, do not purchase an 802.11 n adapter.
  • Shut down your computer. Remove all cables and peripheral devices.
  • Remove the left side panel while facing the front of the case. You may need to remove screws or to manipulate latches and notches. Consult your case or computer manufacturer's documentation if you are unsure of how to remove the panel.
  • Clip the metal part of the anti-static wrist bracelet to a metal object, and ******** the bracelet.
  • Locate an available PCI or PCI-Express slot. Unscrew the screw that secures the slot cover that corresponds with the slot, then remove the slot cover.
  • Line up the wireless adapter's pins with the slot. Insert the card until it clicks into place. Do not force the card into the slot, or you may damage the card's connectors. If you feel resistance, remove the card, line up the card with the slot again, and reinsert.
  • Secure the card with the slot cover screw. Reattach the side panel, and replace any screws you removed earlier.
  • Reinsert all cables, and plug in all peripherals. Boot the computer.
  • Allow Windows the opportunity to detect the card. It should automatically install the drivers for the card. If you have updated drivers, insert the disk and install according to on-screen instructions.
  1. Install an External Card
  • Boot up your computer.
  • Insert your external wireless adapter into the appropriate slot. For example, if you purchased a USB slot, insert it into a USB port.
  • Complete Setup
  • Double-click the network icon in the task bar.
  • Highlight your wireless network. Windows will display the name you entered when setting up your router
  • Click the "Connect" button.
  • Enter and verify the security key you created when setting up the router. Click on "Connect."
If you have further query then try to let me know. Thanks for using FixYa.
Aug 27, 2011 | Cisco Linksys Wirelessn Router Black...
Trying to re set up belkin router. could not get internet earlier, time warner instructed to disconnect router and only use modem
Uninstall the router...Shut Down...Re-insert the disk and when asked let windows find the software to install....Choose Custom.
Windows will find the router and it should work.
Oct 28, 2010 | Computers & Internet
Trying to set up the E1000 using a motorola modem - insert disk, follow instruction, then it says you have successfully connected to the router, but you're not connected to the internet, and then windows...
You are getting the pop up asking for Internet access server drivers.
actually that is a bug in the Cisco connect server.
You can uninstall the cisco connect from that computer and reinstall the CD.
OR go to the device manager on that computer.
Under other devices you will find that internet access server with the yellow exclaimation mark.
Right click on it and disable it.
You can also setup E1000 router without CD or Cisco connect software.
Click here for more information
Jun 10, 2010 | Cisco Linksys E1000 WirelessN Broadband...
I have DI-604 in line between Windows Vista computer and cable modem. Works fine. Bought DIR-615 (wireless). Several places instructions say, ""Insert the DIR-615 CD into computer and click Install Router....
Contrary to the many warnings not to install the router before starting the installation with the CD, I got the installation to complete only AFTER I installed the router inline thusly:
1. Power everything off.
2. Remove DI-604.
2. Install and connect 615 router to computer and to modem.
3. Apply power to router and modem.
4. Apply power to computer and wait until Windows loads.
5. Insert 615 installation CD.
6. Follow the directions.
Nov 22, 2009 | D-Link DIR-615 Wireless Router
Pen-drive not recognized
shutdown your computer, totaly turn it off in 1min. then turn it on. I f asking you to insert disk, you have to insert the disk because it needs the driver for the pen-drive to recognize it, do not select to go to online, just let your software to do it not online ok
Sep 02, 2009 | Electronics - Others
Computer crashed
It should not be necessary to have the installation disk - you can configure the router for wireless use by going into your browser and typing into address bar 192.168.1.254 (I think this is right from memory) - the username & password for accessing the router utilities is by default "admin" (without the quotes) - you will need a wired connection to accomplish this.
Otherwise, if you are using a wired connection, it will connect automatically. Good luck!
Feb 14, 2009 | 2wire (1000-400108-001) Router
Magix Music Manager
Is it really asking you for ur software installation CD?
Most probably it may be asking you for your Operating System Installation CD. Please insert the Windows 2000 SP4 CD into the drive and try continuing with the installation
Best of luck
Have a nice day
Feb 01, 2008 | Computers & Internet
Ftp
Do you have IIS installed on your xp machine? If not , go to add/remove programs, click add /remove windows components, and select Internet Information Service, and click apply/ok. You may be asked for your XP disk , if so, insert the disk into the drive requested to procede. Once IIS is installed on the machine, Set the router up for port forwarding on ports 24, and 25.
Nov 30, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Setting up a wireless connection between my linlsys pcmcia card and my 2 wire gatway
first insert your pcmci linksys card into the laptop, you would find a found new hard ware screen, insert the setup disk, and then follow the steps, automatically your card would be installed, once the installation is done, the wireless adapter , would detect wireless signal, try connecting to the wireless network.. if it asks for any key, look at the bottom of your 2 wire router you would find a 10 digit number, enter the number as the number as key code or password, automatically you would get connected.. if case if you have any problem , revert back ..
Nov 19, 2007 | 2wire HomePortal® 1800HW Router...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
