Question about Toshiba Satellite A200-0ET00X Notebook
Have Toshiba Satellite a200. Worked fine till recently. Will sometimes not start at all when ac in, or will stall in start-up. the ac will charge the battery when computer off. when ac not in but on battery works fine.
Had this PROBLEM for months now ,done and tried everything ,Solution, jam a toothpick in the power button keeping it depressed
Posted on Feb 14, 2011
    Sniper:
  • 57 Answers
Your computer has a damaged motherboard. Buy new laptop.
Posted on Jul 31, 2010
  • ron olf
    ron olf Feb 03, 2011
    I have this kind of problem also for my toshiba laptop. I went to the service center and they told me that the problem is in the motherboard and they will fix it by buying a brandnew motherboard on an order basis. The price of motherboard according to them is 10-20% less from the original price. They advised me to buy new laptop than invest in new motherboard for practical reasons. Or i may continue using the unstable laptop by using it in battery mode, but of course, it takes a lot of patience, for I noticed that for a prolong use this way, I observed that my laptop always shuts down everytime the battery is in full charge mode but when the battery drains for a couple of minutes, it stabilizes. It takes a lot of patience operating this partly damaged unit.
    Scholar:
  • 145 Answers
Check the cables for your adapter, if they are frayed or damaged then replace the adaptor. If the connectors are dirty clean them with a piece of dry cotton or clean cloth. Make sure they are firmly connected. If a new adaptor still won't boot the computer then visit your dealer as the motherboard connection may be the problem.
The battery has an automatic cut off when charging if the battery becomes too hot or cold. (Whether the computer is on or off). Take the battery out and check the connectors are clean. Also check that the system temperatures are not getting too hot. Speed Fan (http://majorgeeks.com/SpeedFan_d337.html) can help you monitor those. You may need to clean the system fans. Check again if you can charge the battery while the computer is running.
Posted on May 05, 2010
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
Battery not detected on a Toshiba Satellite 305. It runs fine while plugged in and the battery charges when i put it in another laptop.I have done all the quick fix ideas from the net turning off then on...
The Toshiba 305's were first released in 2008/2009. Depending on the age of your machine, the battery may very well just be dead. Typically there are warning signs like slower charging, and less battery life after a charge. New batteries for this laptop are available in many places and cost in the $20 to $30 dollar range.
Jun 08, 2017 | Battery Technology for Toshiba Satellite...
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
I have a toshiba Satellite L305D-S5900, sometimes while i'm using my laptop my screen became white with color stripes, then my laptop restart automatically. this happens when i plug in my cousin's external...
I had experienced similar problems with toshiba satellite pro M200. the problem is on the hardware on the IC chipset. You may consider to immediately send to toshiba for repair.
Usually this happens when a laptop running a pretty heavy process on I/O
Toshiba Contact Information: 800-457-7777
Mar 02, 2010 | Toshiba Satellite A200-19501F Notebook
My Toshiba Satellite Pro A200 works fine if I use a battery charged on an identical machine, with the same mains charger. With the mains charger plugged in it either shows 'plugged in not charging' or...
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Jan 08, 2010 | Toshiba Satellite Pro A200-EZ2204X...
My Laptop Will not sleep on AC Charge
Try using Power Options in the Control Panel. Define exactly how you want laptop to behave with either battery or AC.
May 23, 2009 | Toshiba Satellite A60-S1561 Notebook
Corona\start-bg.bmp error on toshiba sat a200
have you installed any other software recently? you might try system restore and if that didnt work,try uninstalling and reinstalling your webcam driver
Jun 25, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A200-0ET00X Notebook Logo
273 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
