Question about Honda Karcher G2400HH-R Pressure Washer
The water pump
As I was washing it made a loud noise, I took the cover off and found parts of what lookes like ceramic, the engine runs but no water comes out. ser # 245122120 Mod # xr2600 also the stainless plates has a **** bind in it. The way I understand it it's 8 years old, he has never had a problem with it . He bought it at home depot.Thanks for any help
Steve
  • 623 Answers
Any possibility the unit froze this past winter? They do have to be winterized.
Posted on May 05, 2010
What could cause a loud clicking noise from engine 2001 volkswagon jetta 2.0 (automatic)
check that a valve rocker has not jumped off a valve end and is pressing down on the valve spring retainer.
Aug 10, 2014 | 2001 Volkswagen Jetta TDI
Hi my name is Mark and i have an auto 2002 mod sante fe. I got my timing belt replaced 2 days later there was a loud screaching noise and smoke. I took the car back and he said it was the belt tensioner so...
Go to a dealer parts desk and ask them to show you an IPB, illustrated parts breakdown, of the engine for your car. Or spend a few bucks and buy one on eBay. Then you will know what parts should be there, what they are called, the part numbers, and the cost. Internal engine parts most likely not parts store items so you will have to get them from a dealer.
Sometimes it can be cheaper in the long run to pay someone who knows what they are doing.
Jul 20, 2011 | Hyundai Santa Fe Cars & Trucks
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
Should I replace the water pump? loud squeeking noise looks like discolored water sparyed around engine compartment
gm,water pumps are a part store super sale item ..if theres water coming out and its rust colored it most likly is bad very much so if it is making loud noises..pretty easy to replace..
May 19, 2010 | 2003 Chevrolet S-10
Theres a loud clicking type noise when washing machine is running
I drained the machine from the filter and then removed the cap and found 2 hair grips and coins at the entrance of pump which was stopping it pumping the water out,cleaned out filter and was sorted,
Dec 22, 2009 | Washing Machines
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fisher-Paykel washer pump noise & some water left in tub
Lube the brass bearings on the motor. For some reason the bearing on the bottom nearest to the cooling fan will start to whine. I would guess because it's kicking dust up around the unit. I used a lube that will hold in place. Lube between the bracket that holds the motor together and by the fan. The noise should stop. I also suggest you lube the top bearing as well. The lube I recommend is a Silicone paste type.
Jan 04, 2009 | Fisher Paykel EcoSmart GWL15
Mine is a FDB635RFS4 model - issue is loud screeching noise
i recently had the same problem of a loud screeching noise. my unit was installed new in 1999 and has worked well up to this point.
when i disassembled the tub water filter i found the filter was heavily clogged (it is supposed to be self cleaning), and i also found glass shards from a broken wine glass. i further disassembled the plastic housing under the filter ( held in place by three torx drive screws ) which covers the pump impeller and holds the lower spray arm. while i did not find any blockage in the pump area, and no abnormal sound when i turned the impeller by hand, i did find that one of the pump impeller vanes has a small chip which probably makes the impeller unbalanced resulting in more than normal vibration. i cleaned the water filter and reassembled the parts and the original screeching noise is now gone.
Sep 03, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Loud noise -- water pump??
Yes you definately need a new pump assembly part number 21001906 $59.95. That is a maytag part number and it is a very common repair. The new pump is a revised design and will look different but will mount the same. Axcess through front panel.
Nov 25, 2007 | Maytag MAV7200 Top Load Washer
Honda Karcher G2400HH-R Pressure Washer Logo
461 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
