Question about MSI P965 Platinum Motherboard
My computer is in trouble
I have a MSI P965,I am working with my windows movie maker and then myHDD is 160 gb.have a partition of 80 gb each.my RAM is 1 gb sdram.I can't save my work because it is sayin that the disk is full.tried to save to a CD instead,still the same.want to know if what is the problem.it also hungs everytime I use the probgram and any other games like rpg games.I'm using windows XPsp2.I already tried to change the settings of memory performance.please reply to [email protected]
  • celcirs Mar 27, 2008
    I'm sure that my HDD is not that full.I still have a more than 100 gb of disk space free.is it regarding with the partirtion???I'm thinking of reinstalling everything but the thing is I don't have the drivers at all.
    oh...thanks....but wish you would help me if I got another problem again....
  • 33 Answers
There is nothing wrong with your computer. It's just your hard disk is full. In order for your computer to run smoothly, you need to have at least 30% of your hdd space free. Or else it will slow down your process and eventually hang.
You need to delete all your unwanted files first or you can move to your second partition. Make sure at least you got 10% free space, then save to CD.
Do until you get 30% free space on your C: drive. After that to tuneup your system, do check disk and defragment the drive
Posted on Mar 27, 2008
  • Anonymous Mar 27, 2008
    Correct me if I'm wrong, you said you have 2 partition with 80gb on each one. Then how come you can have 100gb extra space if you only have 80gb each.
    When you do a partition, the disk space is not the combination of both rather you have to look at each individual partition or drive. Now your system drive should be C: drive. This is the important drive that you must have at least 30% free space as I mention in my solution. In order to see how much free space it has, open my computer, right click on c: drive, choose properties. If the free space is less than 30% apply my solution again. Good Luck.
SOURCE:
Ram isssue
Part Number: AspireOneAOA150 Aspire One AOA150
RAM / Max RAM 512 MB onboard DDR2 533 MHz SDRAM single channel with onboard SDRAM and one soDIMM slot, with up to 1 GB/1.5 GB using one 512 MB/1 GB soDIMM module
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope this helps
Sep 06, 2012 | Acer Computers & Internet
Hi can I add 2G ram for this mother board
Yes. When the manual was created 1GB pc133 sdram modules weren't available yet, but they said when they did come out that the bios would support them so the max ram you can have is 3GB.
Here is an excerpt from the manual:
System Memory Type/Speed SDRAM DIMM - PC133 Only
Current Maximum Memory 1.5-GB
Maximum Memory 3-GB (when 1-GB PC133 SDRAM
are available)
Memory Parity Not Supported
ECC Memory Supported (Intel 845 chipset does not support
mixing of Non-ECC and ECC PC133 memory)
Here is the manual:
http://h18000.www1.hp.com/products/quickspecs/10946_div/10946_div.HTML
Aug 15, 2012 | Compaq (252608-001) Motherboard
MSI P965 Pt Continually re-boots on start-up
You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
Dec 31, 2011 | MSI P965 Platinum Motherboard
Can it support windows 7
yes, its supported by windows 7.
but need more setting to make it fast. maybe tune up utility will help increase the performance.
help me by rate my answer.
Mar 06, 2011 | MSI K9MM-V Motherboard
My msi pm8pm mb doesn't accept 1gb memory pc667 its accept only 256mb pc533, what i need to do to accept 1 gb memory, pls help me!!!!!! tnx!!
Your MB can take a max of 2 GB RAM. And it has to be DDR SDRAM. So, please ensure that it is compatible. Then only would it accept the RAM SIMM else it may damage the mother board. or the RAM itself.
Oct 13, 2009 | MSI PM8M-V Motherboard
Pc5300 on pc3200 slot to upgrade msi 845gvm-v
PC5300 or more correctly "PC2-5300" and can work in a system that has "PC2-3200" RAM, and if mixed, they will operate at the speed of the slowest module. "PC-3200" RAM, however, is not compatible. PC-3200 is DDR SDRAM, having 184 pins. PC2-3200, and PC2-5300 are DDR2 SDRAM, having 240 pins. DDR and DDR2 modules are the same length,
but the pins on DDR2 are smaller and the keying notch is in a slightly different position.
You need to get the replacement ram all the same type ie - DDR or DDR2
And yes your motherboard should accept 2GB max
Jun 15, 2009 | MSI 845GVM-V (MS-7057-010) Motherboard
Hanging of laptop, when i open twoor more programs
Well, you need more RAM. 1 GB is not enough for Vista Ultimate. Contact Dell to upgrade and add a 2 GB memory module for a total of 3 GB. Apparently, you have 30 GB disk full with the Vista OS and software programs. At some point, I'd like to see you extend your partition for your 160 GB drive so that "C" is much larger than 40 GB. You'll need one-one assistance via FixYa.
Jun 12, 2009 | Microsoft Windows Vista Ultimate Edition
Open Questions:
AOL MAil PHoNe [email protected]#$%{1^855^536^5666}#[email protected] ^&*_+*/**//*/NuMbER COLORADO This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 19, 2019 | AOL Computers & Internet
See all MSI P965 Platinum Motherboard Questions
MSI P965 Platinum Motherboard Logo
78 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
