Question about Sharp AR-153E Copier
When I turn on the printer H word followed no. 4 will appear
  • 1,110 Answers
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codeswhen I turn on the printer H word followed no. 4 - 2_bing.gif, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print2_bing.gif button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater2_bing.gif lamp or thermal fuse (more common) failure in the fusing area and will need service.
Posted on May 05, 2010
Set up printer.
Step by step set up printer with wireless connection
1. Insert CD Driver came with your printer and run the [Setup]
2. Then klik [Next] to perform the image below
3. Select and Click Wireless LAN Connection, Then Click [Next]
4. Select and Click Acces Point Connection, Then Click [Next]
5. Ensure that your printer is turn on, make sure the white power lamp is on and then click [Next]
6. The sofware will now briefly search your network for any printer already connected. If this is first time you are setting up your printer it will not be found. So please ensure that [setting printer could not be found on the list] is selected, then click [Next].
7. The setup Guide installation will now start
8. Click on [Next]
9. Click on [Cableless setup]
10. When the following screen appears, hold down the [Wi-Fi ] button (A) on the printer until the white power lamp flashes 2 times and release after the second flash, then click [Next].
11. Make sure that the blue Wi-fi lamp flashes quickly and the white power lamp is lit, then click [Next]
12. The following message will be displayed
13. Once the connection to the acces point is completed click [Next]
14. When the following screen appears, select your region and click [Next]
15. When the following screen appears, select your language and then click [Next]
16. When the following screen appears, select the software you wish to install, and then click on [Next]. If you're not sure which software you want to install at this stage, don't worry, as you can always uninstall it at a later stage if you wish.
17. When the following screen appears, click on [Yes] to agree to the end user license agreement.
18. When the following screen appears, click on [Next].
19. The software will now instal
If the following screen is displayed during the installation, click on [Redetect] to search for your printer again.
Depending on your network configuration, it may take a minute or so for the software to detect the printer. This may involve clicking on redetect a number of times.
20. Once the Cableless setup is complete the following screen will be displayed to indicate the model of your printer and the name (or SSID) of your wireless network. Click [Complete].
Mar 24, 2016 | Canon PIXMA Office Equipment & Supplies
It keeps saying "menu disable"
Please try to do the following steps to enable menu
1 Turn the printer off.
2 Press and hold Select and Return and turn the printer on.
3 Release the buttons when you see Performing Self Test.
Config Menu appears on the first line of the display.
4 Press Menu until you see Panel Menus, and then press Select.
Enable appears on the display and press Select.
5 Locking Menus appears briefly.
6 Press Menu until you see Exit Config Menus, and then press Select.
Sep 12, 2011 | Lexmark T630 Laser Printer
Just replaced ink cartriges in printer and followed instructions but still saying i have an alignment problem
Make sure you are inserting genuine Lexmark cartridges. Please follow the steps below to fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power source to reset it.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You could also try inserting a different known working cartridge to determine if the other is faulty.
Jul 26, 2011 | Lexmark X4580 InkJet Printer
I just installed a new photoconductor into my IBM InfoPrint 1622 and I need to reset the page counter and the instructions have been lost. I need instructions on how to reset the counter.
IBM infoprint 1622 - Photoconductor
When replacing a photoconductor on an IBM infoprint 1622 you must follow these following steps to reset the counter.
1. Open up the printer front cover and Install the photoconductor. 2. Close the cover. 3. Turn the printer off. Press and hold the 'Select' and 'Return' buttons, then turn on the printer. 'Config Menu' should appear on the display. 4. Press 'Menu' until 'Reset PC Cnt' appears. Press 'Select'. 5. Press 'Menu' until 'Exit Config Menu' appears. Press 'Select'. 6. Open the front cover. 7. Press and hold the red 'Cancel' button with the triangle on it for 3 seconds. All the lights should then cycle. 8. Close the front cover. The Photoconductor Maintenance counter is now reset.
Feb 21, 2011 | IBM Infoprint 1622 Laser Printer
Need Help on resetting the printer! On the screen it keep showing "Drum" every now & then....we followed the instructions for resetting & the DRUM still appear on the screen of the...
hi,
if you are not buying roiginal drum, please try the following:
1.turn off the mashine
2. open the front cover
3. Turn on the mashine
4. Then on the screen you will be asked: "change drum?" or something like this
5. follow you choice and good luck
pifonski
Feb 18, 2011 | Brother MFC-9840CDW Laser Printer
How do I fix a error 6a80 on a ip4700
Hi Good day!!! That error may cause of a paper jam, check your printer if there is blockage and then remove those blockage if no blockage, and the error still appear try to reset your printer.
To reset follow this:
1. Turn off the printer.
2. Pressed simultaneously for 10 seconds on the following buttons:
3. Release the button "On / Off".
4. After a few seconds release the other buttons.
Thank you for using FixYa
Nov 10, 2010 | Canon iP4700 InkJet Photo Printer
How do i reset the counter for a Lexmark e260d after replacing the photoconductor kit?
After replacing all the items in the photoconductor kit, reset the maintenance counter: 1 Press and hold the Select and Return buttons while you turn the printer on. 2 Release the buttons when Performing Self Test appears on the display. The printer performs its power-on sequence, and then Config Menu appears on the first line of the display. 3 Press Menu until you see Reset Maint Cnt and then press Select. Reset appears on the second line of the display. 4 Press Select. Resetting Maint Cnt Value appears briefly on the display, and then is replaced by Config Menu on the top line and Reset Maint Cnt on the second line. 5 Press Menu until you see Exit Config Menu, and then press Select. Activating Menu Changes appears briefly, followed by Performing Self Test. The printer returns to the Ready state.
Dec 02, 2009 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
1. Press GO. The page containing the error will automatically be reprinted.
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
HP Photosmart 3110 All in One says ink cartdriges missing
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
May 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
Sharp AR-153E Copier Logo
123 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
