Question about Philips Televison & Video
Tr hv short circuit no numper found - Philips Televison & Video
  • eytchliaouta May 06, 2010
    i meen the transistor hv near the transormer hv
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, postback with the model number / screen size, something like 13MDTD20 / 13".
Good luck and thank you for asking FixYa.
Posted on May 05, 2010
  • Louie  Role
    Louie Role May 06, 2010
    Yes, that would be the HOT for horizontal output transistor and the transformer would be the flyback or FBT. The HOT differs from model to model hence the initial request for the model number of the TV.
Every time I start my 06 equinox the 10 amp backup fuse blows. When I try to restart the car its no crank no start. When I replace fuse it starts fine again. Why is 10amp backup fuse blowing?
A short circuit in the wiring . Do you you know how to test automotive electrical circuits ?
10 amp backup fuse ?????? back up lights ? Video's on youtube showing how to find an fix a short . Park neutral safety switch
The transaxle control module (TCM) primarily controls shift points and lockup engagement.
The transaxle is controlled by an electronic shift system. The TCM processes input signals. From the information received, the TCM controls the transaxle hydraulic system.
The electronic shift system consists of the following components:
• TCM
• Shift Solenoid (SS1 and SS2)
• Pressure Control Solenoid (PSC)
• Lockup Solenoid
• Input Shaft Speed (ISS) Sensor
• Output Shaft Speed (OSS) Sensor
• Transmission Fluid Temperature (TFT) Sensor
• Park/Neutral Position (PNP) Switch
Have the vehicle checked for DTC'S - diagnostic trouble codes
When the TCM detects an invalid combination of TR switch signals, then DTC P0705 sets. DTC P0705 is a type A DTC.
BACKUP Fuse
10A
PNP Switch
The transmission range (TR) switch is part of the park/neutral position and back-up lamp switch assembly and is mounted on the transmission manual shaft. The TR switch is a multi-signal switch. The transmission control module (TCM) supplies voltage to the TR switch. Each gear selector lever position grounds one or more of the signal circuits in a unique pattern. In order to determine the gear range selected by the driver, the TCM compares the voltage combination on the signal circuits to a TR switch combination table stored in memory. Refer to Transmission Range Switch Logic .
Sep 02, 2017 | Cars & Trucks
CS Code
Inspect foil side of HV board for burned tracks toward lower side of board. If burned, check HV capacitors (High Voltage Capacitor Test Procedure) and HV transformers (High Voltage Transformer Test) for a short. Otherwise test other components as outlined above.
Solution: Replace defective components as necessary. If applicable, repair foil trace on HV board.
Hope that helps.........
Aug 29, 2008 | Amana RC17 Microwave Oven
Whats does the code p1702 mean on a 2001 mercury grand Marquis
Possible causes
- Faulty Transmission Range (TR) sensor
- Transmission Range (TR) sensor harness is open or shorted
- Transmission Range (TR) sensor circuit poor electrical connection
Feb 18, 2015 | 2001 Mercury Grand Marquis
Cant find simpel answer code po708
Trouble Code: P0708
Transmission Range Switch Circuit Malfunction (Shorted)
Possible Causes:
TR sensor signal circuit is shorted to ground.TR sensor is damaged or has failed..TCM has failed.TSB 01-40-020 (7/01) contains information about this code.Here is what is listed for this code.
Dec 29, 2012 | Hyundai Cars & Trucks
I have a panasonic microwave with convection oven, grill and steamer. When I switch on the microwave, the house fuse (16 amp) cuts out. With the other functions of the oven, it works fine. Do I need a new...
you have a short circuit.
test the a) HV rectifier b) Capacitor HV c) HV transformer d) Magnetron e) test the swich for door for short.f) circuit board main is short.
see the diagrams and proceed.
10_2_2012_12_41_44_pm.jpg10_2_2012_12_42_15_pm.gif10_2_2012_12_42_35_pm.gif10_2_2012_12_43_09_pm.jpg
Oct 01, 2012 | Panasonic NN-C994S Convection/Microwave...
Want to locate censor p0705 on a 2006 suzuki forenza
DTC P0705 - Transmission Range (TR) switch circuit malfunction (short to power supply)
DETECTION CONDITION
• Two or more range signals are input from the TR switch for 12 s or more.
Diagnostic support note:
• This is a continuous monitor (CCM).
• MIL illuminates if TCM detects the above malfunction condition in two consecutive drive cycles.
• PENDING CODE is available.
• FREEZE FRAME DATA is available.
• AT warning light illuminates.
• DTC is stored in TCM memory.
POSSIBLE CAUSE
• TCM malfunction
• Short to power supply in wiring harness between TR switch terminal A and TCM terminal 1D
• Short to power supply in wiring harness between TR switch terminal E and TCM terminal 2C
• Short to power supply in wiring harness between TR switch terminal D and TCM terminal 2B
• Short to power supply in wiring harness between TR switch terminal G and TCM terminal 2E
• Damaged connector between TR switch and TCM
• TR switch malfunction
Inspect swtich harnesses and test with OBD scanner reader tool.
Sep 30, 2011 | 2006 Suzuki Forenza
Po705 2001 mustang auto
CODE PO705 IS DTR SENSOR TR SENSOR CIRCUIT MALFUNCTION. POSSIBLE CAUSES, DTR OR TR SENSOR CONNECTOR IS DAMAGED OR SHORTED, DTR OR TR SENSOR SIGNAL CIRCUIT IS OPEN OR SHORTED TO GROUND, DTR OR TR SENSOR SIGNAL CIRCUIT IS SHORTED TO VREF 5V, DTR OR TR SENSOR DAMAGED, PCM HAS FAILED.
Jun 24, 2011 | 2001 Ford Mustang
Would the H.V. Capacitor cause my microwave to stop working
If the HV capacitor goes open circuit the voltage doubler circuit will fail and result in no power to the Magnetron.
If the HV capacitor goes short circuit that will result in an extra load on the power transformer eventually failing the mains fuse.
Either way the magnetron will not be able to produce power.
Dec 27, 2010 | Maytag Appliances Over-the-Range Microwave...
Model 721.64282 microwave/convection oven - microwave not heating and making a loud noise. convection oven works
No heat but otherwise normal operationA shorted HV diode, magnetron, or certain parts of the HV wiring would probably result in a loud hum from the HV transformer but will likely not blow the main fuse. (However, the HV fuse - not present on most domestic ovens - might blow.)
If the main power fuse is located in the primary of the high voltage transformer rather then at the line input, the clock and touchpad will work but the fuse will blow upon initiating a cook cycle. Or, if the fuse has already blown there will simply be no heating action once the cook cycle is started. There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse.
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact. See the section: See the section: Testing the magnetron.
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms. See the section: Testing thermal protectors and thermal fuses.
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms.
  • Open HV capacitor - see the section: Testing the high voltage capacitor. A shorted HV capacitor would likely immediately blow the fuse.
  • Open HV diode - see the section: Testing the high voltage diode.
  • Open magnetron filament - This failure may also be due to loose, burnt, or deteriorated press (Fast-on) lugs for the filament connections and not an actual magnetron problem. See the section: Testing the magnetron.
  • Open winding in HV transformer. See the section: Testing the high voltage transformer.
  • Defective HV relay. A few models use a relay in the actual high voltage circuitry (rather than the primary) to regulate cooking power. This may have dirty or burnt contacts, a defective coil, or bad connections
  • Shorted HV diode - see the section: Testing the high voltage diode.
  • Short or other fault in the magnetron - see the section: Testing the magnetron.
  • Short in certain portions of the HV wiring. See the section: Testing and repairing the wiring and connections.
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
If you are interested in doing it yourself the following link will help : Microwave Repair Manual
(**All the above references to tests are found here)
Oct 21, 2010 | Kenmore 63663 Microwave Oven
Check engine light is on. Is it the PO705 vehicle speed sensor A maken it do that?
Yup, if you scanned your engine computer and you got a code P0705, you can bet that's why your Check Engine light is on.
P0705, however, is NOT a Vehicle Speed Sensor code on this vehicle. It is a Digital Transmission Range Sensor code. It is caused by an open or shorted circuit in the TR-1, TR-2, TR-3a or TR-4 circuits. This code CANNOT be set by an incorrectly adjusted TR Sensor.
Oct 18, 2009 | 2000 Ford Crown Victoria
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
