Question about Nikon D90 Digital Camera with 18-105mm lens
Nikon d90. would a nikon sb25 flashgun work fully with the d90 camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Not fully. It will work in non-TTL and manual modes, but it will not work in TTL mode. That is, it will work but not in fully automatic like the newer flash units.
Posted on May 05, 2010
Testimonial: "Thank you very much for the advice. I now know that I will need to buy a new flashgun more suitable for a digital camera. Thanks again."
Nikon D90 live view not working
The manual only gives the obvious things.
Is your battery fully charged.
You can select the time the monitor stays on c2. You even can select Monitor out c4. Check you did not select one of those.
The last thing you could try if nothing of the above works, is remove the battery and after a few seconds put it in again.
Last option, I'm sorry, but you should visit the dealer or Nikon suport center if nothing of this helps.
Nov 06, 2013 | Nikon D90 Digital Camera with 18-105mm...
Cobra MD210 flashgun on Nikon D90
Take care. Nikon does warn every user of the modern DSLR's not to use old flash guns. Old camera's were fitted with mechanical switches. In those days nobody cared about 5, 12 or even 100 volt on a flash gun. Modern camera's use electronic switches (transistor) and they only can survive when hooked up to modern flash guns, because these guns block high (above 5 Volt) voltages.
Nov 04, 2013 | Nikon Cameras
How much is nikon d90 in the philippines price
Hi alvinearlaca,
Nikon D90 DSLR Camera Price and Features:
The Nikon D90 is a 12.3 megapixel digital single-lens reflex (DSLR) camera that offers live view capability and automatic correction of lateral chromatic aberration.
It is known as the first DSLR to feature HD 720p video recording with mono sound at 24 frames per second. It replaces the Nikon D80 and positions itself between the company's entry-level and professional DSLR models.
We have here the price (in Philippine peso) of Nikon D90 digital camera.
Nikon D90 Digital Camera Price (body only) in the Philippines: Around Php 36,000 - Php 37,000.
Nikon D90 Digital Camera Price (with Nikkor AF-S DX 18-105mm f/3.5-5.6G ED VR lens) in the Philippines: Around Php 52,000 - Php 53,000
Hope it helps.
Thank You for using Fixya.
Sep 09, 2011 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 flashed CHR and next time using camera LCD was black/grey with stripes and no pics HELP!!!
The CRH error message means that the lock tab on your memory card is in the locked position. The purpose for the lock switch is to allow you to set your SD card so that you cannot accidently erase your valuable pictures. Remove your SD flash memory card from the camera and hold it in your hand with the label toward you and the angled corner to the upper right. Look on the left edge of the card and you will see a very small slider switch. Make sure the switch is in the fully up position then reinsert it in the D90. If the camera is not generating a false error, your camera should work correctly.
Jun 19, 2011 | Nikon D90 Digital Camera with 18-105mm...
My NIkon SB600 is stuck on my hotshoe-I can not remove it fromt the camera (d80) help
I had a similar problem with my SB25 when I tried to use it on a D90. I took the camera into the Nikon USA Repair Depot in Los Angeles where they took it into the back shop and removed it while I waited without charge. If the SB600 is like my SB700 and SB900's, there is a spring loaded dimple in the camera's hot shoe that clicks into a hole in the SB flash hot shoe. I think if you can slide a thin piece of metal such as a machinists shim, you may be able to depress the dimple and release the SB600. Let me know if it works.
Mar 15, 2011 | Nikon Sb600 Sb-600
I have D90 dslr camera last few months was working very fine but last days its shutter not opening propely after click only half image show
Your mirror is not fully opening, make sure you have no dust or object jamming the mirror. Do a cleaning with the mirror locked up in the raised position.
Mar 23, 2010 | Nikon D90 Digital Camera with 18-105mm...
Does not have a flash shoe but has a red M snd a
The M is for flashbulbs, the X is for electronic flash. Sorry, but it won't sync with flash powder :-)
I don't see a manual for the FT, but I found manuals for the FTN and the FT2 at http://www.butkus.org/chinon/nikon.htm
Feb 18, 2010 | Nikon Nikomat FT 35mm SLR Camera
Hahnel 280 nikon d90
Make sure you're using the right connector and have it plugged into the bottom port of the D90. Make sure the D90 is NOT set to one of the remote shooting modes.
Nov 15, 2009 | Nikon D90 Digital Camera with 18-200mm...
Can you use nikon sb25 flash with d40 dslr?
You can but with limitations;
Save me explaining,please read this http://forums.steves-digicams.com/nikon-dslr/137618-sb-25-d40-non-ttl-auto-mode.html
Apr 14, 2009 | Nikon D40 Digital Camera with 18-135mm...
Vivitar 636 and Nikon D200
You won't be able to use older TTL flashguns with the D200. Since the D70, all nikon cameras have used "iTTL", and earlier DSLRs (eg D100) have used "D-TTL". Neither of these are compatible with the older TTL system used on film cameras. The newer SB-400/600/800 flashguns are all ok, and Sigma and Metz both produce iTTL compatible flashguns. The new flashguns will work on old cameras but not vice versa.
I know this is annoying, but there were good technical reasons why Nikon changed the TTL standards.
If the 636 has an A mode (non TTL) this should work ok, otherwise it will only work in manual (if it has a manual mode).
Oct 25, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon D90 Digital Camera with 18-105mm lens Logo
286 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
