Question about Soundstream Tarantula Car Audio Amplifier
Not powering up no current tried every thing - Soundstream Tarantula Car Audio Amplifier
    Champion:
  • 208 Answers
Hi apart from the + & - connections to the big terminals, the terminal marked "REM" or "REMOTE" needs 12 volts on it too to start the amp up.
If no joys then check the following in this order:-
ensure amp has a good 12v supply & good ground.
remove & inspect the fuses on the amp
disconnect all speakers and retest amp.
if all this stillresults in a dead amp then the only answer from here is service to the amp.
ENSURE THERE ARE NO SHORTS IN THE SPEAKER WIRING TO EACH OTHER OR VEHICLE GROUND - this will kill your amp.
Posted on May 05, 2010
Testimonial: "thank you,apparently the ground wire was hooked up wrong causing the remote ic to blow"
4 YR OLD NETROME CAMERA SYSTEM WILL NOT POWER UP
Check power adapter. These things are prone to failure, particularly if you are approaching their current limitations. It's better to have too many than not enough separate power supply adapters. Splitting the current coming from a single power supply increases the current demand and shortens the life of the adapter.
Oct 10, 2013 | Computers & Internet
My aprilaire won't turn on, no power and it looks like all the conections are good, and power outlet is getting power. Any suggestions?
You need either a sail switch or current sensing relay to turn the humidifier on and off when the blower motor turns on. They both accomplish the same thing but in differant ways, a sail switch senses the airflow in the return air duct and a current sensing relay senses the current from the blower motor.
Dec 20, 2010 | Aprilaire 700 Humidifier
Why does laptop stop working through adaptor after battery flat
Hi There,
Your battery charger/adapter connects to the DC Power Jack to power your laptop and charge the battery. Since the charger/adapter does 2 things, there are 2 "cells" inside it to do those 2 different things. It's not uncommon for one or the other (but not both) to fail. So, often just purchasing a new charger/adapter solves the problem you're having. It appears that yours is continuing to charge but has stopped "adapting" AC current to DC current to power the laptop directly.
Jul 10, 2010 | Computers & Internet
Can't get power to my RoadPro 1500 DC to AC Power Inverter
I have had this same problem with several power inverters over time. The problem is usually one of three things.
Those starting with the simplest.
1. Too much current being drawn on the inverter.
Solution (Check appliances that are plugged in and make sure they are not drawing more than 1200 watts. If they are unplug the appliance that is using the most current and get an inverter that is more suited to your power needs.)
2. Some power inverters have fuses built on to them. Sometimes multiple fuses. Sometimes, one fuse may burn out leaving one intact. When this happens even small items draw too much current and over load the inverter.
Solution (Replace the fuses)
3. Improper installation. Inverters draw a lot of current. You must use the propper wire size for the inverter. I would recomend at least an eight guage wire directly fused and hooked directly to the battery. Of course like with all things the bigger the wire the better the flow of electricity.
If it is not one of those things stop into a truck stop electronics shop and have the person diagnose it.
Hope that helps.
Jan 20, 2009 | RoadPro AC/DC Power Inverter 2000/5000w
Power Failure
Try unplugging the unit for 5 minutes and let the control panel reset.
Nov 20, 2008 | Maytag Dryers
Boot failure
does it beep at all?
take it into a dark room, can you see anything on the screen, even if it's very faint?
take battery off and plug in same thing?
Jan 04, 2008 | Toshiba Satellite A105-S4004 Notebook
Power brick red light
yeah you definitly need to have a uk to usa power converter. you guys run on 220V which would create way more current then needed which is why the power supply blew. I hope you didnt fry any internal parts in the 360. You need to get a power converter that gives you 120V.
Dec 26, 2007 | Microsoft Xbox 360 Console
Lost oem power cord
You need to be sure the actual current supported by the generic universal adapter as some cant fit the requirements of your device so the nintendo will lack of current no matter the voltage you have.
Other thing you must take in consideration is the polarization of the plug as you can put inverse polarization and damage your console. Not like your case as you have a blinking light so looks more like and system error.
Try finding an original data for the current requirements in mA (i.e. 500mA) or the power also works before you make some calculations (i.e. 10w).
Dec 01, 2007 | Video Game Consoles & Games
What is the voltage, current, and polarity of the power supply for the SC-D23?
You should use the original Samsung supply since it is a switching power supply capable of supplying the needed current to operate the onboard charging circuit. Many customers have tried to go with generic supplies and it opens the inline chemical fuse due to the unit drawing heavy current during battery charging. Hope this helps. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Feb 12, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Soundstream Tarantula Car Audio Amplifier Logo
111 people viewed this question
Top Soundstream Car Audio & Video Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
