Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
B & S 10D902 lack of compression when starting
Caught ant hill when mowing - now when pulling starting handle seems like a lack of compression - engine not even trying to start as though no spark reaching mix.
  • martin wells May 05, 2010
    Took plug out, put finger where suggested, pulled handle, felt compression - replaced plug, pulled handle, engine started - complement you on your genius :)
    P.S. came in to write that it started - went back to cut the lawn...no compression, again ! Help!!!
    Top Expert:
  • Briggs & Str... Master
  • 12,104 Answers
May have broke crank newer mowers are not built as they use to be take out plug and place finger over hole to test for compression if none u broke more than likely the crank
Posted on May 05, 2010
Check the flywheel key ( also referred to as a shear pin). It's an aluminum key that keeps your flywheel in time with your crankshaft. It is designed to shear when the engine is met with a sudden, strong opposed force in order to keep the engine from being damaged. When it shears, it throws the engine out of time, hence it won't run. Good luck.
Posted on Aug 19, 2012
Does start, but lacking any power.
Sounds like either a compression problem or valve adjustment.
If there is no smoke but just no UMMPH then susspect valve adjustment. Also it may get weaker as it gets warmer or just stop altogether once hot and not restart until cold again. That's Typical Valve clearances.
If it's burning oil or smoking then susspect damaged piston rings or a burnt piston.
If the oil dip stick is a push in one, and it gets blown out of it's seating, then it's definitely piston problem, as compression is getting past the piston into the sump. That pressure has to be relieved somewhere and the dip stick is the obvious place.
Oct 22, 2015 | Garden
2001 mazed tribute runs good no power to go up hills ?
Search Results
    Bogging - lack of power going up hills ' SHO Forum
    www.shoforum.com/index.php?threads/bogging-lack...power...up-hills...
    Oct 17, 2006 - I just ran into my first problem - The car runs fantastic on flats, going downhill,... ... No problem pulling up that hill at slow speed - plenty of power. It's only when out on a ... Anyone got a handle on a good used torque converter?
    why do i lose power on hills - CarGurus
    www.cargurus.com > Questions > GMC > Sierra 1500
    CarGurusOct 17, 2013 - I lose power on hills change the fuel pump and checked timing changed catalytic ... The TPS will make the ECU "go nuts" as it says...I'm here. ... has no power going up hill with small boat on, on flat ground runs good 1 answer.
    2000 toyota corolla lx aut. 4cyl. car looses power no power ...
    www.cargurus.com > Questions > Toyota > Corolla
    CarGurus
Mar 28, 2015 | 2001 Mazda Tribute
Craftsman GT6000 54" stalls while mowing
Sounds like you have dulled the blades with your aggressive hill cutting
Aug 12, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Hi, I have a Masport 635 Lawn mower, I think it is 2 stroke, just petrol ( not mixed with oil ). I don't know anything about how to maintain mowers. But today I mowed the back yard, it went fine, then...
If it is two stroke it must have oil mixed in with it. Try pulling the cord and notice if there is any compression if not then it is the pistion and if it doesn't turn then it is seized with lack of oil.Now if it is four stroke take the plug out put it to the head and pull the cord to see if there is any spark if there is it's a fuel problem.
Jan 15, 2011 | Briggs & Stratton Briggs Stratton...
Suddenly no compression on Toro walk behind
yes the shear pin will throw the timing off.check it anyway it might be ok but then again you ever know.check for fire coil should be at 010.from frywheel it might slip check compresstion anyway with gauge then valve gap need manual for this if ohv check pushrods this could make bad compresstion if one is bent.let me know want you find out ok
Jul 24, 2009 | Garden
Which manufacturers make a lawn tractor that uses a drive shaft?
kubota does & i also think john deere does try them
Jun 23, 2009 | Garden
TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
Mar 02, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lack of power
You should try doing a tune up change spark plugs, wires, pcv,and fuel filter.it's reasonable to assume that the rings and
valves (inside the engine) have become worn. Worn rings
and valves will cause the engine to have low compression
and low compression = weak power.
You may be curious as to why the engine's lack of power is
most evident when driving up a hill. Well, when a vehicle is
going up a hill, the engine is under more stress than when
driving on a flat road. Therefore, any wear in the rings/valves
will tend to be revealed - in the form of compression - when
the engine is under stress.
you will need to have a mechanic verify that the rings and/or
valves are indeed worn. Incidentally, this generally involves
what's known as a "wet compression test".
If the mechanic tells you he positively confirmed a worn ring
and/or worn valve condition, don't immediately authorize him
to do the work. Why? Because, this type of work is very
expensive and therefore you'll want to get several opinions
before jumping into anything. By the way, even though this
vehicle's high mileage strongly points to the above diagnosis,
it's possible the cause of this problem is something else.
For example, one of the electronic sensors that controls the
engine may have gone bad. hope this help have a nice day.
Jul 04, 2008 | 1988 Mitsubishi Pickup
Riding lawn mow
give as the model so we can help.
Apr 15, 2008 | Black & Decker 19" Electric Lawnhog...
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
367 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
