Reinstall drivers for konica bizhub 7222
Please give me instructions on how to reinstall the drivers for my bizhub 7222
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    is a bizhub a port device?
I work with Konica
If you need Help Email me and we will work out the details latter for as Phone assistance
Thanks
email me at
redwingfan11cups@gmail.com
Posted on Jun 04, 2009
SOURCE:
Konica Minolta Bizhub 7222 scaner don't working N-37
Does it print?, Can you ping it. Scan to Email or PC? Or SMB/FTP? Check mail server. also try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 14, 2014 | Konica Minolta Office Equipment & Supplies
Please wait message on konica minolta bizhub 164 Machine please give me solution if any one knows
CHECK THE THERMISTOR & THERMOFUSE OF THE FUSER UNIT. CLEAN THEM & TRY. IF NOT SOLVED THEN REMOVE ALL THE CONNECTOR FROM THE MOTHER BOARD & REINSTALL THE CONNECTOR & TRY. GOOD LUCK.
Jan 13, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica monilta 7222 error f-35-4
my machine konica minolta C252 is giving the code 9401 how should I resolve and what is
Jul 19, 2013 | Konica Minolta Minolta 7222 Laser Printer...
Konica Minolta bizhub C250 won't print or scan. Checked IP address on bizhub, and it is as always (192.168.1.100). Reinstalled Print Drivers (PCL6, Ver 2.53) but didn't change. Ping gets no response....
Your first priority should be to put it on the network , for this u should give the printer the IP 192.168.2.XX where XX varies from 4-99 . Please make sure that no other device should have the same IP which u are assigning it to the printer and and try to ping on the network.
Jan 31, 2011 | Konica Minolta bizhub C250 All-In-One...
What are codes F-34 and F-35?
These are heat sensor abnormality error codes in Konica Minolta 7222/7145/7135/7235/7228 models.You did not mention the model.
Oct 04, 2010 | Konica Minolta Bizhub C300 All-In-One...
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
How do you change the time on the bizhub 7222?
Enter in the user tools and setting the value.If don`t work tell me for more information.
Oct 01, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7222 f28-3 code
part # for the t/s unit is 40la-2600. if you need it I can order the part for you
Aug 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Vista download for bizhub c351
All you can do is either wait for someone to create a Vista Driver or revert your system back to XP or other OS that supports your machine.
There are SO many device NOT supported under Vista especially the 64 bit versions.
Dec 01, 2007 | Konica Minolta bizhub C351 All-In-One...
Open Questions:
832 people viewed this question
k24674
Marvin
Marvin
