Question about Warner Bros. Interactive Lego Batman for DS
How do I delete all the saved data on Lego Batman for Nintendo DS?
  • 2 more comments
  • wittayoo May 05, 2010
    The usual remedy (holding R, L, X, Y, A and B once at the main menu screen) for deleting the saved data does not work. Is there another solution please?
    I am still trying to delete all the saved data from the game. The above solution ( holding ALL the buttons ) does not work. Please, is there another solution?
    I am still trying to delete all the saved data. The above solution just overwrites previous saved data. I would like to delete everything and go back to factory default. Perhaps there is not an answer?
    Can I assume that really there is absolutely no answer to my question. It is impossible to delete all the saved data and start as at factory default?
  • 6,993 Answers
Unlike the home consoles, and the Sony's rival PSP portable gaming system, the Nintendo Dual Screen (DS) does not save game data to the system itself. Instead, game saves are written directly to the game cartridge. This means that when you wish to erase DS game data, you must do so on each cartridge individually. This is usually a fairly simple process, accessible from your game's main options menu. If your game does not have an option to delete data from the main menu, there is a hard-cartridge reset option that works with most titles.
Follow the steps below to delete your saved games:
  1. Power on your DS with the game cartridge (Lego Batman) you wish to delete (data from inserted. Once the game loads, check the main menu for an "Options Screen", if your game features this screen, there should be an available option to "Delete All Game Save Data?" Select this option to delete your game data.
  2. If your title did not have the option to delete game data automatically, power off your DS. Remove any game cartridge inserted into the system, then power it up back on. Once you are at the main system menu for the DS, insert the Lego Batman cartridge that you wish to erase data from. You should see an icon appear that corresponds to the inserted game.
  3. Click the icon for your game cartridge, and quickly press and hold the "A," "B," "Y," "X," "R," and "L" buttons simultaneously. This will perform a hard reset of the cartridge data. Note that there are several game titles where this method will not work.
Good luck.
Posted on May 05, 2010
  • 6,487 Answers
Try doing this steps in deleting save data from your DS, press and hold SELECT, the L Button, and right on the + Control Pad when you touch the Lego Batman panel on the Nintendo DS system menu. You will be given the option to erase all saved data. But if this doesn't work the only way to do that is to overwrite the save data by starting a new game and overwrite the existing save data on your DS.
  • 17,970 Answers
Start a new game, and then save over the other file. I think thats the only way you can get rid of the other files.
  • ZJ Limited
    ZJ Limited May 05, 2010
    Nintendo DS games don’t normally ask for memory cards to save games.
    Perhaps your son hasn’t gotten past certain checkpoints in Lego Batman. I
    had similar problems when I first played the game.
    However, I never encountered any instance when the game asked me to
    provide a memory card to save my progress. In contrast, the PSP does require a memory card for saving games.
    As far as I know, Lego Batman uses an auto-saving system. Once your
    son gets past certain points, the game is saved. In any case, check if
    there’s an option to save during the game. Press Start and look
    around the menus for such an option.
    I think there’s a certain way to erase game data on any game using a
    certain button combination. I’m sure there’s something online that tells
    you how to do it. It’s used a lot on the Pokemon games.
    Here’s a clip I found off the net…
    The very first hit on google for “elite beat agents reset game” has
    this:
    Quote: hold A + B + X + Y + L + R at the Nintendo iNiS screen and you can
    delete your saved data
    You can just overwrite games. Start a new game, then ask it to save it
    over an old one.
    Good luck.
  • ZJ Limited
    I find this, its possible that you can try it... Unlike the home consoles, and the Sony's rival PSP portable gaming system, the Nintendo Dual Screen (DS) does not save game data to the system itself. Instead, game saves are written directly to the game cartridge. This means that when you wish to erase DS game data, you must do so on each cartridge individually. This is usually a fairly simple process, accessible from your game's main options menu. If your game does not have an option to delete data from the main menu, there is a hard-cartridge reset option that works with most titles.
    1. Power on your DS with the game cartridge you wish to delete data from inserted. Once the game loads, check the main menu for an "Options Screen", if your game features this screen, there should be an available option to "Delete All Game Save Data?" Select this option to delete your game data.
    2. If your title did not have the option to delete game data automatically, power off your DS. Remove any game cartridge inserted into the system, then power it up back on. Once you are at the main system menu for the DS, insert a cartridge that you wish to erase data from. You should see an icon appear that corresponds to the inserted game.
    Good luck.
  • 4,472 Answers
Have you tried selecting a new game instead of loading the previous ones? This page can help you with everything else in the game:
http://dailynintendo.com/tips-and-tricks-%E2%80%93-lego-batman-ds
Thank you and good luck,
Lee
  • Lee A.
    Lee A. May 05, 2010
    I am not understanding what you are trying to do. There is no defaults you need to change that is what starting a new game does. I hope you will reconsider and accept/rate one of the solutions.
    Good luck,
    Lee
  • Lee A.
    Lee A. May 05, 2010
    http://service.lego.com/en-US/Default.as...
    I would contact the manufacturer then directly as they are the creators of the game. Follow that link to do so. They have the most complete information if your not finding an answer to your satisfaction.
    Thanks,
    Lee
  • 1,170 Answers
Turn on the nintendo ds and hold in "L, R, SELECT, START, A, B, X, Y, and the directional pad and touch the clubhouse games icon on the ds main menu situated above the downloads play and pictochat ect.
it will then give the option "are you sure you want to delete data" obviously select yes
  • Arjun Komath May 05, 2010
    Reset a Nintendo DS Lite
    Step 1. Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
    1. Step2. Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
    2. Step3. Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not cause a reset in the unit.
    3. Step4. Put the battery pack back into the unit. Just line it up in the compartment and push it back into place..
    1. Step5Replace the cover. Secure the cover back into place with the screw.
    2. Step6Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
My son has been playing Lego Batman on his nintendo DS and he had around 15 characters which he has somehow lost. Do you know how this might have happened?
i know how to solve this click on to the suit room and click onto the computer there shud be there if this was no help then just leave a comment
Aug 17, 2010 | Warner Bros. Interactive Lego Batman for...
On nintendo DS what are the control keys for lego batman?
up is up, down is down, etc\ A is action or batarang/ B is jump\ Y is attack or shoot/ L/R is toggle character in freeplay. if you have more questions, go buy hints at the Batcave computer
Aug 15, 2009 | Warner Bros. Interactive Lego Batman for...
REPAIR/REPLACEMENT
try going to a game store and asking or look in the manual
May 29, 2009 | Warner Bros. Interactive Lego Batman for...
Deleting previously stored saved games/profiles on lego batman ds
When on the main menu trey clicking on new game instead of load game and then if a screen appears saying are you sure the you have deleted the previous game save
May 19, 2009 | Warner Bros. Interactive Lego Batman for...
Where has my saved game (batman lego) disappeared to? I'd completed 80.8% and now can't access it.All games appear to be new!
Make sure you are using the same memory card, and the same game cartridge. Check under saved games. And are you sure someone hasn't deleted it!?
Apr 24, 2009 | Nintendo Video Game Consoles & Games
Lost... lego batman nintendo ds
HERE IS THE WALKTHROUGH
http://www.gamefaqs.com/portable/ds/file/943953/55512
Apr 12, 2009 | Warner Bros. Interactive Lego Batman for...
Lost all saved data due to corrupt data
are you using a n5 homebrew card? if so its been corrupted and is irreversable. buy a new card
Mar 28, 2009 | Nintendo Wii Console
Warner Bros. Interactive Lego Batman for DS Logo
1,409 people viewed this question
Top Warner Bros. Interactive Video Game Consoles & Games Experts
James Wishart
Are you a Warner Bros. Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
