Question about Panasonic CT-32SL13 32" TV
My tv acts as though it is not plugged in
One night I turned the TV off, an hour later my kids went to turn it back on and nothing. It acts as if there is no power at all to it. I have checked all the cords and cables and everything looks fine. What do you recommend?
  • 1 more comment
  • Anonymous Apr 15, 2008
    It's like no power getting to set. We have checked outlet, cord, remote etc. and nothing makes it turn on. It was working fine the night before. Any suggestions.
  • officer M Apr 22, 2008
    Was playing x box 360 turned the tv off went to work came back a few hours later and the tv wont come on. unplugged tv cables, and tried new power outlet. what can i do?
  • grave72 Jan 08, 2009
    my tv also acts like it is not plugged in. we went to turn it on, we might have heard a click, but now nothing.
  • 7 Answers
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side at the bottom, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Posted on Jun 18, 2009
Not mutch you can do,savety circuit has tripped the set.
needs a repair person.
horst in wollongong
Posted on Mar 26, 2008
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Televison & Video
Kids were changing from watching DVD to playing video games. Went to change input to appropriate selection. Screen blinked, then turned off, now no power to the TV at all.
Tries tv unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.Now the tv might be working again.If the tv still have no power all,mean the tv power supply board it is dead.That the board where the tv power a/c cord plug into it.Must take the tv aparts.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacemrnt.
Jul 06, 2011 | Sharp LC42SB45U 42 in. LCD TV
I have a Digital Research LCD tv and for some reason the power does not come on anymore. I was watching it one day then turned it off. A couple hours later I went to turn it back on and nothing happened....
Try tv unplug,replug it an hour later.The tv will now resetting back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacenent.
Sep 08, 2010 | Televison & Video
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Panasonic Problem
replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Jul 18, 2008 | Televison & Video
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Tv wont turn on
I had the same problem and took it apart. Before the repair there was no "click" when I pushed the button, a clue to the problem. The on-off button on the front pushes a weakly made angle piece of plastic inside which had broken. The plastic piece in turn is supposed to push an internal switch which is offset to one side.
I used epoxy (Araldite) to repair the broken plastic angle piece, but it still looks weak to me so I switch the tv off at the wall and leave the on-off button alone (though it does work now).
Opening the case requires some knowledge and care, and can be dangerous. It may void the warranty so be careful or give it to a qualified repair person.
Hope this helps!
Dec 12, 2007 | Televison & Video
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Panasonic CT-32SL13 32" TV Logo
111 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
