Canon 850 E001 Error
When I turn on my Canon 850 copier I get a E 001 error code message and the machine makes a clicking sound and goes off.
The machine worked fine until someone had a paper jam and tugged the papaer out. Upon removing the paper jam we bagan experiencing this E 001 code each time we turn the copier on.
Any tips would be much appreciated.
  • Anonymous Sep 08, 2008
    ok yo tengo el mismo problema de error E001 pero de la canon ir600-550-60 agradecere me proporcionen la ayuda nenesaria para dar solucion
I entered service mode and it fixed itself.
With the front panel open and the copier lid/carriage lifted up, I used a paperclip and stuck it in the small hole on the center of the front grey panel (DC controller) and simultaneously used a pen to hold down the tab in the slot on the lower left edge that makes the copier think the lid is down. I hit the power button and then it worked! A "1" showed on teh LED display. It reset the error code and all is OK now.
Posted on Apr 24, 2008
With the front panel open and the copier lid/carriage lifted up, I used a paperclip and stuck it in the small hole on the center of the front grey panel (the covering of the DC controller) . I simultaneously used a pen to hold down the tab in the slot on the lower left edge that makes the copier think the lid is down...then I hit the power button. It reset the error code and all is OK now.
It goes off within a second when I turn it on. It also doesn't turn on with the door open.
Posted on Mar 29, 2008
  • 4 Answers
This is an problem in fixing heater unit open the door turn it on press 2 and 8 at the same time than press copier then function then clear then error the ok after that all turn it off again if it doesn't work u have a problem maybe a heater lamp a thermistor
Posted on Mar 28, 2008
How can i fix the error code 000001-00002
Assuming you have a copier or laser printer, this site:
Thread Canon IR 2200 error E000001 002
suggests:
Some errors can just come up and you can just clear them and if everything works fine you don't need to worry about calling a tech. However if clearing it doesn't make the error message go away or you have problems emerge with the copier then you do have a problem.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Jan 11, 2016 | Canon Office Equipment & Supplies
Canom imagerunner 2520 error e000001
the e001 is error for the temperature rise detection in fixing unit. There are more sub codes that I need to know for precise troubleshooting. i.e. E001-000 or E001-001 or E001-002
But if there is no fault in components, you can try to reset it in service mode.
Procedure:
additional function, then press 2 and 8 then go in clear by pressing scrolling, then go in engine, then choose ERRCLR and then turn off and on the copier.
If these doesn't helps you need to replace fixing film unit.
Aug 29, 2011 | Canon 0000A011BA Copier
I have an error code E000 on my canon copier what could be the problem
A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Mar 20, 2011 | Office Equipment & Supplies
Canon IR600-550-60. Error code E001.
550 just gave an error code E060, what do I do?
Nov 09, 2009 | Canon imageRUNNER 600 Printer
Error code e0002002-001
E000 mean power supply not active some of components demage such as fuse or traic mosfac or sesistence ,heater lamp cut out or fuse E001 thermistor or thermistator abnormal
please check it then solve your problem
Nov 04, 2009 | Canon Image Runner 3320I Copier
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
Canon PC-850
A E001 code is a fixing error code. It has to do with the heating lamp or the thermister or the thermal fuse or it could be all 3. Dose the fixing lamp turn ON. If no it is the fixing lamp or thermal fuse. If it turns ON and warms up and then codes out then it is the thermister. It could also be the whole fixing unit is bad.
Mar 26, 2008 | Office Equipment & Supplies
853 people viewed this question
k24674
jasbo
jasbo
