Question about Gibson Robot SG Special LTD Ebony
Hello, My robot will not tune. I pull out the knob, 8 red lights come on, strum the strings, nothing happens. It worked the first day, and on the second day, nothing. It's fully charged, tuning knobs are pushed in, worked right the first time, I can dial it to an individual E or D or any other and it will tune all strings to that chord. Also, when it started to tighten the high E string, it broke the string. I also went in and reset it to factory default and nothing changed. I have the purple robot. Thanks.
4 Suggested Answers
SOURCE: blinking peg white when tightening
blinking white indicates that the robot is in "tune up" mode. this is what its SUPPOSED to do when being restrung. This is outlined in the owners manual, which is downloadable from Gibsons tech support site.
Posted on Jul 20, 2009
  • 10 Answers
SOURCE: Both the E and A strings
The neck may require adjustment, but would recommend taking it to a luthier or using a guide like raeguitars to talk you through it. Depending where it is on the fretboard that buzzes, the nut may require replacement/adjustment. I've had all these problems in the past and the above tutorial helped me fix all of them.
Posted on Nov 30, 2009
  • 5603 Answers
SOURCE: I just got this guitar. I pull the tuner control,
Are you sure you are struming the G string at the right point? One might be able to fool the tuner by triggering a harmonic on the strings or being too aggressive in the strum.
I would pull the peg and see if the string CAN be tuned manually. It is possible the G string is bad or somebody put the wrong string on there.
Remember that strings can be within about 10% of the breaking tension when in tune.
Also it appears that the thing can detune itself to nearby keys. Make sure you have the dial set correct when you pull it out to tune.
Posted on Feb 06, 2010
Every time i pull up the MCK to tune it the knob just lifts off the guitar entirely with out ever clicking on the LEDs.
If the knob itself comes off the shaft, you need to secure it to the shaft... maybe a setscrew needs to be tightened. Not sure what type knob you have... some of them have a screw under a cover on the top of the knob that pulls up a chuck to hold onto the shaft.
Mar 07, 2011 | Gibson Robot SG Special LTD Ebony
Tip
How to string an electric guitar
I'm writing this tutorial to help new guitarists string their electric guitars.<br /><br />The first step is to purchase some strings from your nearest music store, depending on the type of music you want to play the string gage will be different. If you want to play heavier music such as metal then I suggest using a heavier gage of string. If you want to play calmer music such as indie, or maybe soft rock I suggest a lighter gage.<br /><br />Next make sure and remove <span style="font-weight: bold;">ALL</span> existing strings. The best way to take off the old strings is to simply loosen them up then cut them right in the middle with wire cutters. Then just pull the left end through the tuning knobs, and the right end through the back of the guitar (Note where the strings come out of the back).<br /><br />After you have removed all the strings its time to put on the new ones. Start with the string closest to the top of the guitar. On your string package you can reference by color which string is which. Find your string then run the sharp end through the back of the guitar in the hole relative to the string you are putting in (These holes in the back are the same holes the old strings came out of). Run the string all the way through so that it is pulled tightly into the back. Now place the sharp end of the string through its relative tuning knob at the top of the guitar. You should pull enough through so that when you pull the string up off the neck there is a gap of about one foot. Now turn the tuning knob clockwise until the string is relatively tight against the neck and it has wrapped around the knob 3-5 times. Now cut the excess string that is coming out of the tuning knob but leave about 1 inch in case you want to lower the tuning. <br /><br />Do the same thing for all your strings, then tune them with either a digital tuner or by ear if you can. You can purchase a cheap digital tuner for around $20 at your nearest music store.<br /><br />Enjoy!!
on May 16, 2011 | Yamaha Electric Guitar
Is he tuner supposed to light up green when the string is correctly tuned?
Before turning the unit on, press and hold down the calib/batt switch to check the condition of the battery on the battery meter.
Then either plug in your electric guitar to the input side of the AG-6 or if tuning an acoustic guitar without electronics placing the AG-6 near the front of the guitar should work. You will not need to press a button to select which string you are about to tune. The AG-6 will detect it and the corresponding light will turn on when it is tuned within range.
Turn on the AG-6 and start by striking the low E (thickest) string while open. This is the number 6 string or 6E. Slowly turn the guitars low E tuning key untill the red LED below the 6E marking on the AG-6 lights up. Continue stricking the open string and turning the key untill the needle centers on zero and the 6E light remains on.
Repeat this for the open A string untill the 5A light turns on and the needle centers on zero.
Repeat for the remaining four strings, 4D 3G 2B and 1E, being careful not to over tighten and break them.
Tip: It may be a good idea once the low E string is tuned, to tune the rest manually, especially new strings or strings way out of tune. Then tune again using the AG-6 tuner.
If installing fresh strings you will probably need to stretch each string and re-tune, possibly several times, before they hold their tuning.
Feb 19, 2011 | Fender AG6 Automatic Guitar Tuner
Variax 600 sound goes out then comes back if i
Check your battery. A weak battery will recover a bit when you power down for a brief period. Strumming hard will overcome the weak amplification when battery is down. Check that your battery is at LEAST 8 volts.
Also verify your plug into the guitar is clean. The barrel of the plug shorts to the ring contact to connect the internal battery. Do NOT use a balanced TRS cable for your intrument as this will lead to a marginal condition.
May 14, 2010 | Line 6 Variax 700 6 String Modeling Guitar...
Have no idea how to use it
I can't find info other than the tuner has three lights for flat on, and sharp.
given that you would plug it in and do a close tune of the guitar by ear.
Then you would strum one string at a time and tweek the peg tighter if it shows flat, looser if it shows sharp, until it shows the light right on.
I would recommend you get a book on guitars to learn how to tune and also check the setup of the guitar.
Also I would recommend you get a Korg tuner... they are about $20 from online sources and they are much easier to use.
Feb 20, 2010 | Music
I just got this guitar. I pull the tuner control, strum the string and after the guitar tune itself, the G string still out of tune??
Feb 05, 2010 | Gibson Robot SG Special LTD Ebony
Both the E and A strings of my Washburn acoustic guitar "BUZZ" even when lightly strummed. The guitar has "light" (.012 - .053) Phosphor Bronze strings.
Buzz usually translates to either inadequate fret clearance or poor quality strings or inadequate pressure holding strings against the fret.
The guitar DESERVES using high quality strings and I would look at the manufacturers recommended string weight or your music store should know what to use. The LIGHT strings MAY be your problem.
Nov 03, 2009 | Washburn D10sbc Acoustic Guitar
Blinking peg white when tightening
idk how i did it. i kinda just clipped the strings a bit more and it worked :)
Apr 02, 2009 | Gibson Robot SG Special LTD Ebony
How do i repair my B.C. Rich guitar??
Guitar manufacturers use generally one of two different knob types: (1) knob has a small set screw of some type holding it on or (2) press fit onto the shaft of the tuneing pot (volume knob in your case).
Now, the problem is if it is NOT a set screw type, it is press fit. You see press fit used most of the time on lower-end instruments (and a few high end). The BEST way to get a stuck volume know off is to get a shoe string, loop part of it under the knob, brace the guitar firmly and PULL SLOWLY WITH FORCE. Realize that it is possible to damage the guitar if you **** on the string too hard.
I have never seen where a stuck know did not come off (or hear of someone breaking their guitar doing it).
I have also resorted to using a small screwdriver: work it way under the know and gently twist it to loosen it so it can be pulled off with a string or your hands.
Be carefull not to scratch your guitar!
Good luck,
-mike
Mar 30, 2009 | B.C. Rich Nt Warlock Electric Guitar
Gibson Robot SG Special LTD Ebony Logo
99 people viewed this question
Top Gibson Music Experts
Michial Gueffroy
Virgil Watts
Are you a Gibson Music Expert? Answer questions, earn points and help others
