Question about U-Line Icemaker
No ice I have a U-Line MD# WCM45A ,no ice fan runs not sure about compressor.The red and black wires are hot to the conduit.Do I still have hope?
4 Suggested Answers
  • 531 Answers
SOURCE: u-line ice maker fan runs, but no compressor - clr2060
change the board
Posted on Apr 07, 2009
  • 286 Answers
SOURCE: uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Posted on Jul 07, 2009
  • 93 Answers
SOURCE: My U-line under counter refigerator ice maker evap fan failed
Depends, for the newer models, you can change the evap fan motor thru the front, but if you have the older model, then you have to remove the freezer housing, ice maker assy then the cover to change the evap fan motor.
Posted on Mar 02, 2010
U-Line ice maker compressor won't run
Dose compressor fell too hot ? There could be several things wrong. First you will need to get out your Volt meter to make all test. With unit calling for freeze cycle the condenser fan and compressor should be running. Check at the compressor to make sure your getting power to the over load switch and then through it to compressor. if not then check to see if compressor is to hot and has the switch open> If so then unplug unit to let compressor cool down so switch will close. when switch closes plug unit back up and start up unit check to see it compressor starts if so then you will need to see what is causing compressor to over heat. could be dirty condenser, low charge, fan dropping out, Bad compressor.
Mar 07, 2014 | U-Line Icemaker
Red lite on the straight blade indicator plug (PS5266XGCMCCV4) This is a line that runs under ground to an outdoor chicken coop. I'm sure the wiring is correct, if black plasticed wire to brass screw...
You have the connections correctly done. I hope that you ran the wires through plastic conduit for the under-ground run. What is connected at each end? Is the circuit causing the source breaker/fuse to trip? Are you making direct connection to your house service panel or just plugging the extended wiring into a socket in the house? The hot black wire should go to the breaker/fuse, the white wire should go to the neutral bar, and the ground wire should go to the ground bar. Hope this makes sense and helps!
Nov 06, 2010 | Garden
I am replacing an in-wall timer switch that controls porch lights. Old timer has only two black wires, that were hooked to the 2 black wires in the wall. The new timer (GE 15086) has black, red, white...
Did you get instructions with the switch? Does it say what is line and what is load? You can hook the green and the white to the green, it won't hurt, but I think one of the colored wires is in and one is out, you have to find out which one is hot. Got a tester? The new timer is polarized for modern electricity, which hasn't gone into effect yet, it is coming. Your house wouldn't have it. If it does, you will know by the fuse box being separated by ground and neutral, the old ones were wired together. If it is, the new switch will only work with the white wire to neutral and the green to ground. Now that you are totally confused. try wiring it up with the green to ground, red and black to to the 2 blacks. See what happens. Hope this helps.
Oct 13, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Refridge would cycle on, fan would come on relay would click but no compressor. relay kept clicking no compressor. I changed relay and capacitor on compressor plugged in all went well. after a few hours...
you were lucky . compressor must run with fan or it will get too hot . if comp is running to hot it will not come on and the fan will . . do you have the cardboard back on frig . this helps direct air to cool comp .. reck the wire connections . and last you may have to take a power ( amp ) reading . the compressor may be bad .. mm.. ps do not run on ext cord and make sure the power at wall plug is good power ...
Oct 07, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Motor is hot?
Which motor is hot...compressor or fan?
Also need to know the model number.
Is this a 3-phase or single-phase unit?
Let's assume it is the compressor...Is it so hot that you can't touch it for more than a second or two? Is the compressor shutting down on internal thermal overload?
Compressor body hot can be caused by a number of things:
1. Low charge (the freon acts as a coolant for the compressor).
2. Electrical imbalance (3-phase only). (check line-to-line voltages)
3. Bearings in compressor failing (check amp draw).
4. Condenser dirty or airflow blocked in some way.
5. Condenser fan(s) not running or running backwards.
6. If water cooled condenser then water flow problem.
Hope this helps you get started.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Scotsman Ice Machine, Cuber, 1930 lb....
I have a u-line bi-95 ice maker.the machine will only drop ice once after it is turned on. i also notice it gets very hot near the vent.the machine does get cold enough inside to keep the ice.what should i...
Your unit will only harvest when your thermostat is satisfied. If you have heavy frost you need to defrost the unit. If no frost then make sure the fan is running by the compressor. If the fan isnt running then the compressor is going off on overload. Or it could be the fan running but the compressor is not. If thats the case you will need a service tech.
Aug 03, 2009 | U-Line Icemaker
I have a u-line ULN-WH95TP-03 THAT WILL FREEZE ICE BUT WILL NOT HARVEST THE ICE. I HAVE MOVED THE THERMOSTAT AS WARM AS IT WILL GO AND IT STILL WILL NOT HARVEST. IF I MANUALLY MOVE THE TIMER JUST A LITTLE...
Your thermostat is what advances your icemaker. You have 3 wires. When it calls for freeze then yellow(2) and blue/black(3) is closed. When that is satisfied the compressor and fan cycles off then the yellow(2) and red(1) is closed. This calls for the icemaker to advance. Red goes to icemaker, yellow is common, and blu/black is for the fan and compressor.
Hope this helps you. I would replace the thermostat
Jul 13, 2009 | U-Line Refrigerator Ice Maker
Give-me plis a wiring digram manual of the Ice Maker U-Line BI-95
Your going to call U-line and ask for it. 800-779-2547. Now what are you trying to do? I can give you the wires on the thermostat. Terminal 1 is red(icemaker) Terminal 2 is yellow(common) Terminal 3 is blue/black(compressor and cond fan motor) When yellow and blue or black are closed this will run the compressor and fan.Thermostat is satisfied then the red and yellow are closed and it advances the icemaker. Ejector blade at the 12 oclock calls for freeze cycle. at 2 calls for heater to come on(inside icamaker) at 10 oclock it trios the water switch and calls for water.Then back at 12 oclock calls for freeze cycle. Temps should be 10-15 degrees in the bucket. Warmer the setting the more ice it makes.
Jun 30, 2009 | U-Line BI-95
Frig not cold
ok 1 problem many symptoms :)
First check if freezer is iced up... If so
1 is your freezer fan running? if not possible defective fan, check if it's wired with the defrost thermostat if it is suspect faulty defrost thermostat.
2nd does your defrost heater work? if your handy with an multimeter put it on the audible option check the defrost heater if there's sound it's good if no sound well your defrost element is fried.
3rd is your condenser clean?
if it has a fan, is it running? if not change fan and clean condenser
4th is the compressor running?
touch the discharge line (the skinny one) from the compressor it should be hot really hot if not suspect compressor has faulty relay/capacitor/overload defective.
hope that i can be of assistance
Apr 22, 2008 | Refrigerators
U-Line Icemaker Logo
51 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
