Question about Acer Aspire 4720 Notebook
Replaced hard drive and can't get the machine to recognize it. It is SATA drive the machine will not recognize the new 160 GB. I'm using XP Pro. Any help would be appreciated.
  • 560 Answers
Go to BIOS setting and change harddisk/SATA mode from "AHCI" to "Compatible" or "IDE".
Posted on May 05, 2010
    Problem Solver:
  • 17 Answers
Reset your bios setting to default
this will solve the problem
How do i fix it?
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 02, 2012 | E-Machines eMachines Desktop PC
Toshiba 320GB MK3265GSX SATA hard drive don't recognize by the bios... it's broken... help me recover my files
If BIOS doesn't detect it either the data/power cables are bad or not making a good connection, or the drive has failed.
Nov 20, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
Apr 20, 2011 | Abit AV8 Motherboard
Hard drive replaced. But does not recognize hard drive. Old hard drive but back But does not recognize hard drive.
open the CPU and check whether it properly connected (both the wires sata cable and power cable)
then check in BIOS. is it detected if it is then change the boot device priority..
if its not detected then try to swap the wires with optical drive..
still not then change the HDD
Mar 28, 2011 | HP m7170n PC Desktop
I bought a Hitachi z5k320 hard drive trying to install it, and windows, but my computer won't recognize hard drive. how can i get it to recognize the new drive. can't do anything until that happens.
As long as you are sure the hard drive is connected properly with SATA cables to the motherboard and has power from the power supply unit, and that the drive is working, you can enter the BIOS on computer startup and modify the "boot device" look in "primary boot device" for a name matching that of your hard drive (probably "HITACHI .....) If it is there select it as the primary device and hopefully it will boot and ask you to install windows. If it is not there the drive may not be connected or it may need to be replaced. Hope this helps!
Mar 15, 2011 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
How to download the driver of Hitachi Travelstar 5K100 HTS541060G9SA00 ? plz plz help me
I am not familiar with Linux but have you checked your Bios to see if Sata Hard Drive is recognized in there??? Most of the time you have to set the bios to recognize a Sata drive because 90% of Hard Drives are still IDE and most bios software is still recognizing the IDE drives. I know I had to reset everything on my Motherboard and Bios when I changed over from an IDE to SATA Hard Drive.
Nov 01, 2010 | Hitachi Travelstar 5K100 HTS541060G9SA00...
Not recognized
G'day mate , as i have found in older computers the drives these days are not recognized by the motherboard/ system / is only for smaller drives , i have had to build a new machine and now gone to the SATA drive, hope this helps
Apr 07, 2010 | Quantum Fireball 1.2 GB SCSI Hard Drive
My hard drive just crashed on my Sony Vaio VGC-LS30e so I replaced the hard drive with a WD SATA HD and the computer is not recognizing it, neither is BIOS. Any suggestions? I went to put the old HD in as...
A bit of research revealed that the system came with a 250GB SATA drive, and the BIOS should have recognized either drive. Check the cable from the Hard Drive to the Mother Board if possible, including the Power connectors.
Sep 21, 2009 | Sony VAIO VGC-LS30E Desktop PC
SATA 2 HDD
I think, one possible way is to manually force sata 2 (there is no such thing as sata 2) to sata 1 by using a jumper for the hard drive. For exact details, please consult the sticker on the hdd or contact the hdd manufacturer for firmware updates. And please report back, especially if it's a success. (Damn, the VT8237)
Jun 05, 2009 | MSI K8MM-V (MS7142-010) Socket 754 Micro...
I dropped my WD External and now it is not recognized by my pc, how to recover?
Since you're most likely beyond warranty anyway, why not try opening up the case and connecting the hard drive inside to a SATA port inside your machine, or, alternatively, to a different SATA/USB enclosure. The chances are that the hard drive inside is still okay, but having opened these enclosures up, I can see how a fall could damage the SATA/USB card inside the enclosure.
Mar 22, 2009 | Western Digital My Book Essential Edition...
Acer Aspire 4720 Notebook Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
