Question about VXL Instruments Itona CE Windows CE VIA C3-1000 Flash: 32MB . RAM: 128MB Ports: 2 x S (TC3941) Network Terminal
How do i connect this terminal to windows 2003 server please give me the settings
    Scholar:
  • 47 Answers
Open Remote Desktop Connection loadTOCNode(2, 'summary'); To open Remote Desktop Connection, click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Create a Terminal Services Connection loadTOCNode(2, 'summary'); To create a Terminal Services connection, follow these steps:
  1. Open Remote Desktop Connection.
  2. In the Computer box, type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
    Note: To connect to the console session of the remote computer, type computername or IP address /console.
  3. Click Connect.
  4. In the Log On to Windows dialog box, type your user name, password, and domain (if necessary), and then click OK.
Save Connection Settings loadTOCNode(2, 'summary'); You can save a connection as a Remote Desktop protocol (.rdp) file. An .rdp file contains all the information for a connection to a terminal server, including the Options settings that were configured when the file was saved. You can customize any number of .rdp files, including files for connecting to the same server with different settings. For example, you can save a file that connects to MyServer in full screen mode and another file that connects to the same computer in 800×600 screen size.
To save your connection settings, follow these steps:
  1. Open Remote Desktop Connection, and then click Options.
  2. Specify the connection settings that you want for this connection.
  3. On the General tab, click Save As.
  4. In the File name box, type a file name for the saved connection file, and then click Save.
Note: To edit an .rdp file to change the connections settings it contains, click Start, click My Documents, right-click the file and then click Edit.
Open a Saved Connection loadTOCNode(2, 'summary'); To open a saved connection, follow these steps:
  1. Open Remote Desktop Connection, and then click Open.
  2. Double-click the .rdp file for the connection that you want to open.
Copy Files Between the Local Computer and the Remote Computer loadTOCNode(2, 'summary');
  2. Type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
  3. Click the Local Resources tab, select the Disk Drives check box, and then click Connect.
  4. Click Start on the task bar of the remote computer, and then click My Computer, or double-click the My Computer icon on the desktop of the remote computer.
    Note: The drives on the remote server appear with the drives on your local computer. Your local drives appear as driveletter on tsclient, where tsclient is the name assigned to your (local) computer.
  5. Locate the file that you want to copy, right-click the file, and then click Copy.
  6. Locate the folder where you want to paste the file, and then click Paste.
Log Off and End the Session loadTOCNode(2, 'summary'); To log off and end a session, follow these steps:
  1. In the Remote Desktop Connection window, click Start, and then click Shut Down.
  2. In the Shut Down Windows dialog box, click Log Off username, and then click OK.
Thankyou
Amit Bhardwaj
Skype Id:- amit.bhardwaj4
Posted on May 08, 2010
My n computing terminal server windows 2003 is getting restarted , i have connected around 15 users please help me to solve this problem.
It is getting restarted on it's own? If so, it sounds like you have a driver conflict and you've setup your system to simply restart when there is a crash. Enable the crash dump to capture the Blue Screen information the next time the server restarts. Please provide the version of vSpace you're using.
May 06, 2011 | NComputing L230 Network Terminal
Hi. I want to set up a server and run dumb terminals (thin clients) off of it. Can anyone give me a basic run-down about how I do that?
You would setup Windows Server. Windows Server 2003 and 2008 Small Business Server comes with a license of Terminal Services Server.
You would first need to setup your Windows Server. Install it according to at least minimum requirements.
Make sure you assign this server the correct role. If this is the primary server and if you intend on hosting dns and dhcp on this machine, then please make sure you are assigning this server these roles.
You will need to create user accounts so that you can log into from your thin clients.
Next you need to run the install for Terminal Server.
Next you need to configure each thin client.
Next try to access each thin client via Remote Desktop as well as the server.
This is the basic run down of the process. If you do not know how to setup a server then you will need to ask that question as this is very detailed. Also you will need to be more detailed in your question as to whether this is a linux based network or a windows based network.
Hope this helps. Please don't forget to give me a good rating as well as your vote.
Apr 02, 2010 | Network Computing Devices (NSH800S/A)...
How can i connect client computers to server where clients have no hard disk.How clients can boot and access hard drive of server?
u can connect with ur client through terminal server. for that u've to server 2003. u can see the steps that how to configure terminal server for that u've to go this link:
http://support.microsoft.com/kb/300847
Sep 25, 2009 | Microsoft Windows Xp Home Edition Sp2...
I've got 3 L230 Terminals all ask for a password I never set.
try to add users with password on your windows 2003 server first and test and see if this resolve your issue you c
Jun 28, 2009 | NComputing L230 Network Terminal
How to set up a network with 7 computers using a server with microsoft server 2003
You must need a router or a switch to connect each of your terminals to your server(Lan or Wifi), if you already install MS server software it will be easy, you must need to install client protocol in your terminals when plug to your swith MS software automatically detects and apply and "ip" address, this permit you to share files /printers or detect any other device in your switch. I recomend to use 10/100/1000 gigabit switch.
Thanks
Apr 28, 2009 | Microsoft Windows Server 2003 Enterprise...
Cannot find License Server
1. TS and TS licensing server are installed in the same 2003 server. The lsview doesn’t list any TS licensing server.
2. If you open the Terminal Server Licensing, it shows “Finding servers… Connecting to \\apps\chicagotech.net. It never finds the apps server. There is not apps server in the network (They might remove this server from the network). After finishing the finding, there are two activated licensing servers listed, one is Windows 2000 server as 2000 TS licensing server and another one is Windows 2003 (also TS) as 2003 TS Licensing server.
3. The 2003 TS Licensing shows they are using Temporary License.
4. We modified the 2003 TS registry to point Licenseserver to itself (TS and TS license are the same server). That fixes the logon screen slow showing issue but not TS licensing issue.
for further querry
post comment
Oct 16, 2008 | Sibelius Computers & Internet
TERMINAL USER SECURITY IN WINDOWS 2003
please define users & give him restrictions as well as rights,
make them as an standard user (dont define them as an administrators) if u have some applications which have to be use by terminal users then give them only that much of applications..
dont allow them to use anyother applications..
May 03, 2008 | Microsoft Windows Server Standard 2003 for...
Network and sql serivices failed during startup windows 2003 server os
Check all this----------
1-check the services (stop the service & start the service from the services)
2-check the firwall setting.
3-check the n/w card
4-Remoove the unwanted s/w
5-check pc for the viruses
I think this activity help you.
Mar 07, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft outlook web access
it's probably because yahoo doesn't recidnise the ip of the mail server, is it connected to a domain name?
but in yahoo you can probably set your server to be allowed in (on user level)
Dec 08, 2007 | Microsoft Office Outlook 2003 for PC
Terminal server not responding
Are you receiving errors in the "event viewer"? And if you are what are they?
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Oct 20, 2007 | Computers & Internet
VXL Instruments Itona CE Windows CE VIA C3-1000 Flash: 32MB . RAM: 128MB Ports: 2 x S (TC3941) Network Terminal Logo
288 people viewed this question
Top VXL Instruments Computers & Internet Experts
David Payne
David Payne
Are you a VXL Instruments Computer and Internet Expert? Answer questions, earn points and help others
