Question about Car Audio & Video
A new battery was installed and i don't know the code to reprogram
  • Car Audio & ... Master
  • 4,874 Answers
Post the car and radio make+model plus all the letters+numbers found on any labels, barcodes or stamped in the metal casing
Posted on May 05, 2010
I changed the batteries now I can get anything to work. The temp is off by 10degrees, my day is reading DON. Help what did I do?
Your year--make--model didn't post for some reason? That info would help.
"my day is reading DON", I don't know what that means?
Some makes and models when battery voltage is lost, there could be some modules that may need to relearn or be reprogrammed. If it needs reprogrammed, you may need to take to dealership? Does the vehicle start and run?
Next time try using a memory saver when you unhook battery, see if it helps?
Jan 10, 2016 | Cars & Trucks
How do i change my code on an ademco m6673 without knowing the master code?
How to find the master or installer codes for an Ademco ...
security.livewatch.com/.../how-to-find-the-master-or-installer-codes-for-...
Aug 7, 2009 - ... Ademco ?€?Vista series?€ alarm system and you don?€™t knowwhat the codes are. ... The master code is the main user?€™s regular code, but different than the ... Be advised that an installing alarm company will not and should not... The master code can change or add the other SU?€™s as needed ...
Need to reprogram an ADT/ADEMCO system - DoItYourself.com ...
www.doityourself.com/.../295048-need-reprogram-adt-ademco-system.h...
Feb 17, 2007 - Purhased a condominium 2 years ago with an ADT/ADEMCO system. ... Received no manuals of any kind but MAY have gotten a "Security Code" from seller. ... To change the master code the system needs to be in regular run mode, .... myalarm system was working but i went and acted like Reset Master Code for Ademco 4111XM, Via30+ or VISTA 10 ...
Jul 8, 2007
Ademco vista 20P with FC and Comm. Failure
Nov 8, 2005
More results from www.doityourself.com
[PDF]VISTA-20SE, VISTA-20HWSE User Guide - Honeywell ...
Oct 11, 2013 | Vacuums
Present message error
Once you get the error light that means you are entering a user code that was deleted when the batteries went dead . Install new batteries then simply use the master code in your owners manual to open the safe. Reprogram new user code instructions bottom of this page.
Jan 16, 2013 | Sentry Fireproof Safe
How to change the battery on a Hyundai Sonata
When you remove the battery to install a new one then you need to enter a radio code to get your radio working again. This is an anti-theft locking system.
To avoid reprogramming your car/radio etc. connect another battery with jumper lead to the battery leads on your car to maintain your car's settings when you disconnect the old battery from your car.
Install the new battery and connect the car's battery leads to the new battery. now you can remove the jumper leads and the second battery.
WHEN YOU CONNECT THE JUMPER LEADS, MAKE SURE YOU CONNECT POSITIVE TO POSITIVE AND NEGATIVE TO NEGATIVE.ON BOTH BATTERIES.
Oct 19, 2012 | Hyundai 2006 Sonata GLS V6
I WANNA CHANGE MY PASS CODE BUT DON'T KNOW HOW
Reprogramming BE 365:
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Aug 05, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
H do I reset all the codes and establish a new one on a Kwikset 909 909-L03 Lifetime Polished Brass Smart Code SmartCode.
This link will take you to the PDF image of the installation and programming instructions:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
(PDF files require that you have Adobe Reader or similar installed on your computer
http://get.adobe.com/reader/ )
It's a good time to replace the batteries while you're reprogramming. Please review each step carefully, because it's easy to goof up this programming process, if you don't follow the procedure properly.
Jun 27, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Error E31 on Bushnell V2
Can you check that the new battery is an alkaline battery? If it is, and you are still getting the E31 error code, you will need to return your rangefinder to Bushnell to have it reprogrammed.
E31 is a programming error code. Most of the time this comes from using non-alkaline batteries or from letting a battery die in the unit. Non-alkaline batteries just don't generate enough current for the laser to operate properly.
Good luck.
Feb 28, 2011 | Bushnell Tour V2 Pinseeker Laser...
How to program 01 RX300 key remote?
Change your battery first, then try again. The codes don`t normally erase on their own.
I had a new master key programed this week and watched the process at the dealership. Mine was done with the same diagnostic code reader they use for the entire vehicle, attached under dash via cable,with the master key along side it is like a giant meter. It took about 7 minutes
Dec 10, 2009 | Lexus Cars & Trucks
Need to reprogram door locks for 2004 Toyota Camry
I recently replaced the battery on my 2004 Toyota Camry. When I installed new battery the door locks will not stay unlocked once opened with remote. How do I reprogram?
Feb 21, 2009 | 2005 Toyota Camry Solara
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
