Question about Riso RZ220 Duplicator
What is a T11 error code mean on a Risograph GR3750?
    Problem Solver:
  • 6 Answers
This problem is on pressure motor, stay in rear part machine,i don´t remember of the code for testing. after i put here, if you need pass e- mail for luizalexdias@hotmail.com
Posted on May 06, 2010
  • Courier NEWS Apr 23, 2011
    The T11 error could be the pressure control motor, but I found that the problem was the adjustment screw and gear. If it is sticky (or in my case, stuck) from years of grime, it will stop adjusting and you will get a T11 error.
How to solve e13 error in risograph ks 800
E13 Cutter motor Lock
• If the Cutter home position switch is not turned OFF within 500 ms after the Cutter motor is activated.
• If the Cutter end position switch is not pressed within 2000 ms after the Cutter motor is activated. http://printcopy.info/?l=en&mod=free&chap=erc&brand=Riso&model=KS800
Apr 17, 2015 | Washing Machines
Riso graph GR3750 marca falla t11 necesito asesoria para solucionar este problema. O es necesario llamar a soporte tecnico ??
"Risograph GR3750 marks to fault T11. I need consultation to solve this problem. Or it is necessary to call to technical support?"
Error T11 means: Call service.
Here some details of the error which may help to solve it: Pressure Control Motor Lock • In 100ms from turning ON of the pressure control motor, the encoder sensor cannot detect a pulse. • In 5 seconds from turning ON of the pressure control motor, the pressure centering sensor is not turned ON/OFF. • When the fuse of the main power board is gone.
Feb 28, 2011 | Riso RZ220 Duplicator
Risograph RA4050 diplaying error code E11, anyone know what that means? Has recently been putting masters on the drum crooked and making grinding noise.
E11 is the pressure control motor encoder has nothing to do with the master problem it is most likely out of time. (grinding noise)
May 03, 2010 | Riso RZ220 Duplicator
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Mar 11, 2009 | Riso Office Equipment & Supplies
Risograph rp 3100 ui
Reset machine... and check connectors to the boards... its a communications error to the digitizer cpu
Oct 13, 2008 | Riso RZ220 Duplicator
Risograph 5800 repair
This is a cutter moter lock. you would have to replace the cutter unit.
Nov 10, 2007 | Office Equipment & Supplies
863 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
