Question about Casio Exilim Zoom EX-Z80 Digital Camera
Memory card problem
Every time i put in a memory card the camera says its locked I have tried loads of different cards
  • Casio Master
  • 4,738 Answers
If you've already tried other cards, AND made sure the tiny slide switch on these cards were all in the unlock position, then see this link for additional troubleshooting tips for this problem. Consider trying Fix #4 or 4A.
Posted on May 05, 2010
How do i unlock the card on my exilim.casio camera
if you put the camera on view and scroll through them does it give you any options , such as save ,delete etc,etc.
Feb 27, 2015 | Casio Exilim Cameras
Why does my camera sate "no memory card"
There are a couple of things you can try: first use a different memory card. The camera is not seeing the one you are putting in it. Also make sure the card is seated all the way in. It is spring loaded and will press down against a spring and lock in place. To remove it you press down and it will come back out as you lift your finger tip. If the card does not want to go in easily you probably have it turned over and are putting it is incorrectly. It only goes in one way.
Jul 02, 2014 | Canon PowerShot SX160 IS Digital Camera
Canon SD1300IS memory card is locked. I have used this card for 3 years I don't get it?
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
The position of the switch doesn't affect reading the card, hence no problems loading the pictures from the card to the printer.
Aug 28, 2012 | Canon PowerShot SD1300 IS IXUS 105...
Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Memory card locked
Use the camera to try to format the card. If this doesn't work use a computer to format the card. efore the camera can use the card, format the card in the camera. If this doesn't work, gently slide the lock back and forth several times and try this again. If this doesn't work, see if your friend can format it in his camera. If he can, then try formating it in your camera. At some point it will either work or it is compromised (toast).
May 29, 2009 | SanDisk Ultra 4GB Secure Digital High...
Camera does not recognize memory card
It appears the SD card the retailer sold is not compatible with the camera. Put in a different memory card and camera works fine.
Dec 28, 2008 | Nikon COOLPIX L18 Digital Camera
The memory card is locked and I cant figure out how to unlock it...the camera wont take pictures and cant even erase the pictures
remove the memory card and look on the side of it their should be a little tab move it to the other possion and try the camera again. if that does not work with the card out gently tap the camera on the card side. and reinsert it their is a sensor that tells the camera their is a card inserted in it. it might be stuck. hope this helps.
Apr 24, 2008 | Cameras
Memory Card Locked
:'( i'm in the same situation right now! :(((( I want my pictires back! i don't know what to do!
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
Memory Card Error
The SD card has a lock switch to prevent existing data from being erased. To record images or movies this switch must be in the normal (non lock) position. Different brands of SD memory cards may identify this switch differently. Regardless the procedure should be the same. Try removing the card from the camera and be sure that the switch is not in the locked position.
Jan 01, 2008 | Canon PowerShot A450 Digital Camera
Memory Card Locked
I had to replace two memory cards. Of course I tried the Lock slider thing on the side with no success. The card is cheaply made. I bought a different brand this time, Lexar. I think my old brand was Dane something. It seemed to happen whenever my battery got low. The card looked like a piece of cardboard and acts like one too!
Nov 05, 2007 | Samsung Digimax S500 Digital Camera
Casio Exilim Zoom EX-Z80 Digital Camera Logo
101 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
