Question about JVC Boom Box Boombox
No Power, just dead,Model RV-B55LTB
Is there a reset or a fuse somewhere I can change or check, Or where is there a good place to send it to repair
  • 55 Answers
You have to open the unit to change its fuse
Posted on May 06, 2010
My 2000 crown Victoria keeps popping my dashbord light fuse!!!
If the fuse keeps blowing, you have a short circuit to a ground somewhere. The fuse protects the wiring from burning up. They, tool companies, make a short tester that takes the place of the fuse and buzzes when the short is present and stops buzzing when you move or locate the wire that is "shorted". Repair the wire that is touching a ground an the harness somewhere and then replace the fuse. Good luck, could be obvious like a coin stuck in the cigarette lighter or just some wiring someone has done recently.
Oct 15, 2014 | 2000 Ford Crown Victoria
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
Why does my clock and radio have to be reset when i turn the ignition off and then back on? my radio goes to safe mode and the clock reads 12.00
Hi. Please recheck the fuses. There should be ( I think a 5 amp) fuse that supplies the dash cluster and radio power to keep the clock and preset channels active when the ignition is off.
Aug 26, 2014 | 2002 Volkswagen Cabrio
I have a 2007 dodge caliber it will turn over but wont start i pulled the fuel ine off at the engine and turned it to start position and it did not spert out does this mean im not getting power to my fuel...
I would start by checking for blown fuses first then move on to removing, checking and possibly replacing the fuel filter, if still no fuel delivery then I would say that the fuel pump is likely bad or not getting a good connection somewhere along the wiring harness. Connectors are always a good place to start. You may also check for bad spots in the wiring like ripped, torn, or cut places. Fuses, wiring repairs, and fuel filters are all a lot cheaper than a new fuel pump in most cases.
Sep 14, 2011 | Dodge Caliber Cars & Trucks
Fuses are incorrectly installed. I need the order of sequence.
You probably put lower amp fuses in places needing higher current ones - no big deal. The fuse box cover should have the size and location of fuses. If not get a Chilton repair book or look online - it's free this way. If you don't have a meter to check your fuses just buy new ones and replace them. Make sure car is off before replacing. Disconnect the positive battery lead for about 30 seconds and reconnect to reset check engine light. Then go somewhere where you can floor it a few times and go through the gears. This will establish a new acceleration curve.
Mar 27, 2009 | 2004 Nissan Sentra
04 pontiac grand am battery light
Try disconnecting battery for about 10 mins. or have vehicle scanned and codes cleared
Jan 25, 2009 | 2004 Pontiac Grand Am
Wiring on plug for fule sending unit
one wire usually to sending unit (which is a rheostat ) from inside it is soldered then up and out to plug....repair anyplace you can get a length of wire to work with or solder a new one in place where old exists now and out to your torn wire..good luck
Jan 13, 2009 | 1990 Ford Probe
GPX DVD player w/surround sound
Have you opened it first and looked for a blown fuse. I suggest you unplug the unit and first look for a blown fuse. If this does not help, go to the retailer or the store where you purchaced the unit and see who they send them to for repair. Good Luck
Mar 19, 2007 | GPX DV-1010 DVD Player
129 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
