Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp aquos will not turn on. When I hit the power button, the tv comes on but promptly cuts back off. What's the problem?
  • 10,515 Answers
More likely it is Power Supply Board. You need to Open the TV. Make sure it would be Unplugged. You need to Take all the Precautions. Locate the Power Supply Board. Remove the Connectors and Pull out the Board. Once you Pull out the Board, with the Help of Magnifying Glass, locate Cold Solder Joint. If Everything is OK, then you would Locate Bulged / Leaked / Swelled Caps. They would have Ammonia kind of Odor. You need to De-Solder them. You could take the same to Radio Shack / Fry's / Order Online. Once you get the New Caps, Solder them and it is all set.You also need to Check Fuses around that.
Getting a Service Manual for this Model could be tough, but i would be able to ask few vendors, in case problem would not be resolved. Usually, you could easy repair the Power Supply Board, if you could catch Few Bad Caps.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 05, 2010
My Sharp tv remote will not turn on / off tv. It will turn on by the main power switch on tv but not by remote.
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
IMPORTANT:
IF THE UNIT DOES NOT POWER ON - UNPLUG THE AQUOS TELEVISION FROM THE OUTLET AND REPEAT THE INSTALLATION STEPS.
IF YOU STILL ENCOUNTER NO POWER, PLEASE CONTACT US AT 1-800-BE-SHARP
http://www.nemsworld.com/theater/LC46_52D62U_Manual.pdf
Dec 04, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Wont turn on
seems like a power issue.
u should have the power checked out on the tv
Oct 02, 2008 | Sharp LC-32D4U 32 in. HD-Ready LCD...
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aquos has the power light and OPC light flasing but nothing works
First turn on power light stable at all?Power and OPC lights well flash,but push on/off power button do this couple times after the Power and OPC flashes well backlight come back on well work.This problem very common is Sharp tv.
Jan 17, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Problem with my Aquos lc32d40u
Your inverter/lamps are bad. Those are only available with the LCD panel as an Assembly, and that is worth more than the TV.
Mar 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
76 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
