Question about Fuji FinePix A400 Digital Camera
Shut off on taking picture
It turns on normal but when you press the button to take a picture it shut's off the camera.I have always been very carefull with this thing and never been outside with it, just to take a picture of mij car , that's it. I think people shoot never buy a fujifilm camera again, this is realy ****!
  • Meglongshore Jun 05, 2008
    Camera has always worked fine but now when I push the button to take picture it shuts off. What do I do?
  • danvita2 Jul 22, 2008
    Same problem is occuring for me. Camera turns on but shuts off when trying to take a picture.
Tried that
Posted on Jul 16, 2008
  • 45 Answers
Use heavy duty batteries...
Posted on May 12, 2008
SOURCE:
It does not take pictures or videos when pressing the shutter button
may be you had placed the card wrong and inside the pin got pressed and only inner memory is getting used which gives less pic. due to less mb inner memory
Apr 26, 2013 | Kodak EasyShare C913 Digital Camera
Camera turns off when taking picture
Try changing the battery brand and see if this helps..I seem to have the same issue with my camera with certain battery brands..Solved my problem by switching brands..
Jun 21, 2008 | Fuji FinePix A345 Digital Camera
All photos I take have suddenly become blurred on my vivitar Vivicam 8225
The reasons why Photos get blurry might not always be an issue with the lens. Here are a few things you should consider -
1) Check if the Battery of the Camera is fully charged. This can hugely effect the outcome of your pictures.
2) Make sure the Memory Card is not full.
3) Check for the Macro or Normal mode. To do this, simply check the top of the LCD Screen. If you find a "Flower" Icon, then the camera is set into Macro mode. To change this, press the OK/Menu button. Find the Macro menu and press up/down to make Macro Off and Normal (Mountain Icon) to On. The camera is now changed into Normal Mode and a Mountain/Pyramid icon should be there at the top of your screen.
4) Try increasing the resolution. Again press the OK/Menu button and press Right/Left until you find a "Lines" icon. Press the Down/Up arrow to choose the resolution. 8M is the highest. Press OK to confirm.
Note - Higher the resolution, better the picture quality but lesser the number of pictures you can save.
5) Check if there is a Crossed Thunder Bolt icon on the LCD screen. If you find one, the flash has been turned off. To turn it on, press the Up/Thunder Bolt. A Crossed Arrow with an A should appear. This indicates the Camera has been set to auto Flash.
Hope the images get better with these tips. You can always call Sakar International at 877-397-8200
Aug 28, 2010 | Vivitar ViviCam 8025 Digital Camera
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at [email protected]
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
It just shut off....
it normally indicates a problem with the batteries. Try inserting disposable alkaline battieres in the camera and turn it on.
If the lense is still out at the moment try pressing the play button the back of the camera to view the pictures taken, even with a very low battery this normally close the lense properly and enables you to view the pictures.
Nov 15, 2008 | Kodak EasyShare C613 Digital Camera
Video mode
its not actually taking videos. its just set on burst mode.
1. turn unit on
2. press menu
3. search and highlight mode (rec mode)
4. select normal and press the center button
5. press menu to exit then try to take a picture.
avaya ****
maimai alovera
Jan 29, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Camara powers on but will not snap picture!
did you just try to press the shutter button halfway?if yes...press in all the way through...if still does not take a picture..master reset...
-press menu
-press right to go to setup
-go down to reset
-highlight yes then press menu to ok it
-turn off then on then try to take a picture
hope it will help...(",
Dec 26, 2007 | Samsung Digimax S500 Digital Camera
Using flash freezes up camera
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Camera
PRESS AND HOLD DOWN THAT BUTTON TILL IT TAKE PICTURES or PRESS IT FOR 2sec AND leave
Nov 26, 2007 | Sony Ericsson K750i Cellular Phone
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Fuji FinePix A400 Digital Camera Logo
259 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
