Question about Gateway FPD2275W LCD Monitor
New computor, hp slimline new monitor soyo 19 inch
How ever the monitor say out of reach how do i fixs, the monitor worked great witht the dell would love to have my new monitor up and running don't know how to resolve this problem. it start to come on and then goes to out of reach,
  • sissyphean Apr 29, 2009
    I havbe a DYLM2286 22 wide TFTLCD it will start up fine then after a time, it either will have vertical lines on entire screen or it will just go black and say out of range. Do I do what you recommended here?
  • 33 Answers
You need to lower the resolution into the monitor's range. 1024x768 is the usual safe one. Now, if you could tell the operationg system you are running it would be a little easier to help. I'm going to assume it's xp for now.
You need to plug a different monitor into the computer, preferably a CRT, as they support a HUGE range of resolutions. Then you schould be able to see the screen.
Right click on the desktop and click properties.
Click on the settings tab on the far right of the new window.
Now you should see a resolution dropdown.
Change it to 1024x768 and click OK.
Go ahead and plug the LCD back in and you should be good to go.
Posted on Mar 28, 2008
I have a Soyo 19" TFT LCD Monitor MT-NI-DYLM1998 when i power on the computer the monitor come on then after a very short time (less than 10 seconds) the display goes off but the power and signal are still...
medproducts, Nothing new here. Check internal "switch-mode-power-supply board" only after devoting about 1-2 hours of viewing "lcd monitor disassembly" and "lcd monitor repair" video clips at YOUTUBE!!! Then you will need to make big decision!!! Let me and all who read this know what your plan of action is.
12fixlouie
Sep 16, 2010 | Soyo 19" LCD Flat Panel Monitor
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
Screen Too Bright
Do a factory reset on All Settings:
http://support.dell.com/support/edocs/monitors/se197FP/EN/ug/setup.htm#Using_the_OSD
Dec 06, 2009 | Dell SE197FP 19 inch LCD Monitor
It did not display horizontally. part is hiding
try to reinstall the video card driver and see if that works
Oct 10, 2009 | Soyo Computer Inc 19" LCD Monitor, Black
Very dark screen
Hi yes it looks like the inverter has failed and will need replacing, or if your compitent enough you can fix it at board level. The usual suspecs are a small SMD fuse on the inverter board / power supply board and/or buldging capacitors which look like blue or black cans.
hope this helps.
jonno
Feb 10, 2009 | Soyo 19" LCD Flat Panel Monitor
24" DOA Soyo Monitor
What size monitor were you using before? If you were using a smaller monitor and everything was fine maybe this new monitor is out of range for the graphics card. I've found that not all graphics cards, especially older ones, will not run a monitor as large as 24 inches. If you can, connect this new 24 inch monitor to a computer with a more powerful graphics card. If it works then you will know that the problem is with your computer. Also connect your old monitor and go into control panel and see what range and resolution your graphics card will support. You may need a more powerful card to run the new monitor.
Jan 11, 2009 | Soyo Computers & Internet
My HP vs 19 desktop monitor is on, but the screen is blank. It flashes on for less than a second when I turn the monitor off, and then back on -- but then goes blank. What is the solution?
If you are handy at fixing things.
Here is a link of how to fix your monitor. I had the same problem, and found this link, followed the instructions and it cost me $5.13
to fix my HP vs19 LCD monitor, and its still working great.
HP vs19 LCD Monitor fix
http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html
Don't drag out your soldering gun these are too high wattage and will melt the board. Use a 40 to 25 watt soldering iron.
Dec 13, 2008 | HP vs19 (Silver) 19" LCD Monitor
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
79 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
