Question about Car Audio & Video
How to replace a burned out LED for the radio display, Ford/Merc
The radio station and clock display LED on my OEM Mercury radio is burned out. The vehicle is a 2000 Mercury Mountaineer. I understand that this is a chronic problem for this vintage Ford radio. The dealer wants $125 for the replacement. I am a mechanical engineer and have taken several electrical engineering courses as well as having been raised in our family repair shop. Can I make the repair, is there a STEP-BY-STEP available or should I seek out a local electronics repair guy?
  • kenw392
    kenw392 May 11, 2010
    are you any good at soldering small connection????????????? also, is this both a cd and cassette deck.
Yea here is a fix for u pay the $125.00 and be done with it!!!!!!
Posted on Mar 07, 2011
NO power to the radio or clock
Did you actually check the radio plug for power, or does the display just not illuminate? I ask because this radio has a little bulb inside that burns out that illuminates the clock, and radio station. You can confirm this by trying to use the radio normally, and trying to 'seek' a station. If you can get it to tune in, it is definitely the bulb. Another way is to shine a nice bright flashlight into the clock face. You should be able to see the stations and clock, that at least will tell you that the radio is working. - Hope this helps =)
Oct 05, 2015 | 1993 Ford Taurus
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
How do i replace burned out lightbulb in my in my cambridge soundworks cd - 740 clock radio ?
I believe the problem is either a faulty light sensor the unit has to dim the display when the lights dim since it was designed for bedroom use with alrms and snooze button. or it is simply a failure in the circuit that drives the LCDs. Mine has been dim for a long time but I can still see just enough to adjust the sound settings. I tune and set stations by sound. so the display has not been an issue since we do not use it for a clock or alarm. I doubt there is a fix for the dim display.
Mar 10, 2014 | Cambridge Soundworks CD-740 Clock Radio
How to reset a Seth thomas weather station wall clock
what do the boxes in the clock desplay mean and also i do not have an outside temp reading on the clock just inside temp and i do not know what all the buttons on the back of the clock mean and hou to use them the clock is a seth thomas sade weather station
Oct 12, 2010 | Seth Thomas Radio-Controlled Howard Wall...
Manual stolen when car was vandalized, need to know how to set clock and radio stations in 1994 Ford Tempo please
setting stations on Fords are easy,put it on the station you want to program and push the channel button in and hold for about 2 seconds then it should flash,now the channel is set..now for the clock,with the key on and radio turned off,press the clock button,then press the seek or scan forward or reverse to adjust the time,then hit the clock button again to make sure it sets.
Oct 22, 2009 | 1994 Ford Tempo
1999 Cougar radio display works sometimes
the radio display is lighted from the back by a miniature bulb, this is the problem, the filament is almost burned out or the bulb is loose in the socket, to replace this bulb u must remove the radio (requires special radio removal tool kit, about $6.00) and then the top cover off the radio, the bulb socket twists into the back of the display, you can buy the bulb at any parts store for about $2.00
Jun 16, 2009 | 1999 Mercury Cougar
No radio display
u must pull the radio out and remove the top cover of the radio, under that u will find a tiny bulb socket just behind the display inside the radio, remove that twist in bulb socket and replace the miniature bulb, any parts store will have it.
Mar 17, 2009 | 2004 Ford Escape
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Car Audio & Video Logo
121 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
