Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer wont defrost on my Jenn Air side by side.
    Problem Solver:
  • 13 Answers
Check out ACMEHowTo.com for troubleshooting the defroster problem
Posted on Jun 03, 2010
Have a jenn air fridge freezer the frrezer is dripping water and causing snow throghout freezer not just on back wall
It sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
May 23, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
I have a Jenn Air JS48FSDBFA. The freezer works fine but the fridge wont get below 46-47 degrees. What could it be.
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
May 21, 2010 | Jenn-Air JCB2280HES Side by Side...
I have a Jenn-Air JCD2389G Side by Side Refrigerator. The bottom of the freezer keeps things frozen, though the top of freezer & refrigerator remain mild to warm. There is not an excessive amount of...
Apr 25, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn Air freezer does not 'automatically defrost-side by side
Nov 29, 2009 | Jenn-Air JCD2295HES Side by Side...
I have a jenn air side by side. the freezer is
This is usually a sign of a defrost problem. I will need you model number to help you better. Sea Breeze
Jun 26, 2009 | Jenn-Air Refrigerators
Jenn air JCD2290HES Refrigerator not cooling
Try defrosting ther could be an ice buildup in the channel between the fridge and freezer.
Feb 22, 2008 | Jenn-Air JCD2290HES Side by Side...
Jenn air refrigerator problem
Couple things to check first is that your evaporator fan motor is running, located in the back of your freezer. open the door and listen for the fan some work on the door switch make sure you depress the switch to check it. If the fan is not running more than likely you need a new fan. The second thing is just look at the back of the freezer compartment and look for a layer of heavey frost if there is heavey frost then your defrost is not working, will need to manually defrost and probably replace the defrost terminator part of the heater assymbly
Feb 10, 2008 | Jenn-Air JCD2389G Side by Side...
Icemaker is not freezing ice, freezer not freezing food,
The ice maker won't work if the freezer is warmer than 17 degrees so that's not an issue till you get the freezer cold again. I would guess that your unit is stuck in the defrost cycle. This could be the defrost timer failing. See if you can find the defrost timer in your unit and advance it by hand if possible. http://www.partselect.com/PartSearchResults.aspx?modelnum=jcd2295hes&mfgmodelnum=&fkmfgid=1&hint=defrost
Dec 01, 2006 | Jenn-Air JCD2295HES Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
78 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
