Question about Dacor Integrated Ventilation System - IVS1 Kitchen Hood
Problems changing a light bulb :)
Hi I have tried a number of different ways to get the darn light bulb out, but I am afraid I am going to break something else. I have a dacor model # IVs1. Any help would be greatly appreciated.
Thanks,
Alicia
  • Anonymous Jun 07, 2008
    I have the same hood and will also need to suction cup. Does anyone know the part number for the light bulb as I cannot locate a bulb to fit this hood either?
You need the suction bulb that came with the unit.  In case you do not have it, it is part #62408 and is about $2.00.  I am trying to figure out for myself how to get the lens cover off in order to access the bulb, and how to replace it when the new bulb is put in.
Posted on Apr 26, 2008
SOURCE:
How can I change the light bulb?
It is a lot tougher than the bulb. It will not break.
Apr 27, 2014 | Kenmore Refrigerators
Camry 2000 center console box too hard to remove
buy a short subscription to alldatadiy.com and print out the step by step with diagrams of where the fastener clips are.
Jan 27, 2018 | 2000 Toyota Camry
All my lamp indicator lights keep flashing. blickers work. when you step on break the break lights work. but when driving no tail lights
First replace the tail light bulbs. The tail light and brake lights are different filaments in the same bulb. it is very possible for the tail lights to go out while brake lights still work. And somtimes the tail lights can blow out together.
If you change the bulbs and still dont work then look for other problems.
May 22, 2011 | 1992 Buick Park Avenue
Whrn i hit the breaks break lights do not turn on fuse is good so is the bulbs and switch what else can it be
Hi, the brake light circuit runs through the 4 way switch, and this switch can go bad, there was a recall on them at one point, try wiggling the 4 way switch, and see if this makes a difference. If you see it does, you should contact a dealer to see if it is subject to the recall. Good luck...Coop
Dec 02, 2010 | 1994 GMC Sonoma
I need to change the fog light bulb on my 2000 Beetle
I read somewhere that you change the complete module. Check with parts store to see if this is correct.
Mar 19, 2010 | 2000 Volkswagen Beetle
How can I change the light bulb in this fan. The
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Feb 07, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
Change burned bulb
No I'm afraid this is probably best left to professionals.You basically have to disassemble the entire TV to get to the lamp.Poorest design I've ever seen!! They built it that way because they assumed it would never go out so it wouldn't have to be replaced. Also there are some voltage measurements that have to be made to determine whether it is the lamp or other failure. I don't recall right off where or what they are,sorry.
Apr 30, 2009 | Televison & Video
2000 Saturn sl2 tail lights
If the 2000 Saturn SL2 is the same as the '99 SL2, then your tail lights bulb is the same bulb as your break light bulb. Now they are dual bulbs, just like your head lights. So just the same way that your brights can work, but your headlight lamp be out, or vice versa, is the same with your break lights. So replace both bulbs and you should be good to go. I just had to replace both mine, one was a tail light out, and the other's break light was out, either way, same bulb. Also, check your manual for the light, or take the light out when you go in to get new ones. I found that for some reason there is some confusion on the bulb in this make in model.
Feb 20, 2009 | 1999 Saturn SL
Changing the light bulb in the oven
the light bulb is screw type so turn only. with heat, bulb can jammmed over time so you may have to break it and get a pair of plyers on the cap. turn off power to do this
Apr 21, 2007 | Stoves Premier 720GRa Gas Double Oven
Kitchen Ranges Logo
703 people viewed this question
Top Dacor Kitchen Ranges Experts
Steve Allison
Steve Allison
Jaime Hernandez
Ekse
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
