Question about Home
Dripping feed pipe
When I flush the toilet the tank does fill up to the proper level. But within about 15 minutes, the water level rises to the brink of the fill tube and it immediately starts dripping from the black feed tube. It then continues that way until the toilet is flushed again. We've had the thing for two years with no problems.
I took out the flapper and cleaned it. There wasn't much sediment; it was just a bit slimy. We do have a Rainsoft water softener in the house.
Thanks, Jeff Lowden
  • jeffrylowden May 05, 2010
    Thanks for your response. The problem is, this is a Toto toilet and the valve doesn't look the same. It's a more streamlined and sealed (I think) unit. I don't know if I can take it apart. I'll try this afternoon. Perhaps there's a manual online for the unit online. Could the original Toto valve be replaced with one of the ones pictured above? I've made that repair a few times before.
  • 43,501 Answers
Your problem is not with the flapper, although it is a good idea the change that periodically also... The prolem you are having is with the fill valve. There is dirt in the fill valve which does two things. It blocks the water flow into the toilet and it also prevents the valve from shutting off completely. Depending on what kind of valve you have, you can easily clean it out. But most vlaves need to be replaced if you start to have this problem.
If your valve looks like this then you can clean it by taking the top off and flushing out the valve...
If you do not have a cleanable fill valve then I would suggest looking for one of these fill valves and making the replacement. It really is not hard to do and you will have a better cleanable valve in your toilet.
heatman101
Posted on May 05, 2010
Why doesnt town water cut off and just keep filling the tanks till they overflow we have tryed everything
Troubleshoot Your Toilet Without a Plumber
www.popularmechanics.com/home/how-to/a4117/4303948/
Overflowing, constantly running and sweating toilets can test a home owner's sanity. ... take for granted--until we can't take a shower or make the toilet flush properly. ... If none of the above does the trick, you may have a misadjusted or faulty fill ... the waterlevel a half inch below the top of the overflow tube inside the tank." ...
Emergencies - Overflowing toilets - Toiletology 101
www.toiletology.com/emergenc.shtml
You can't just lower the water level in the tank; you need to displace some of ... and the ballcock and flapper are working properly and shut off when the tank is full. ... The bowl is filled with the water that goes into the overflow pipe. ... Unfortunately, when a toilet bowl is clogged and the water level rises and doesn't flush the ...
Nov 19, 2015 | Town Home
After a flush, water tank fills up but water will not shut off automatically, have to shut off the main water supply at the bottom of the toilet after each fill up.
There is a problem with your fill valve. The fill valve has a float connected to it, that rises up as the water level reaches its correct level, which then shuts off the water entering the tank.
Replace the fill valve. They run in the neighborhood of $10-15.
Feb 28, 2015 | Home
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
Toilet system will not completely stop dripping, resulting in constant drip from overflow. How do I stop it?
Is the drip comming from the small fill tube going into the overflow? If so you may need to raise it a little. The nost common leak is from the flapper or seal. On rare occasioms the flush valve itself has a defect that will cause it to leak. Take a close look at the problem and Im sure you will find it. I hope this helps.
May 14, 2010 | Home
Toiliet Drips in bowl for a while after you flush
Check flapper out and adjust water level in tank to proper level. If you get level right and it still does drip it sounds like the flapper is not sealing correctly to shut off water.
Toilet flappers are not to expensive and you can touch it with your hand and if you get a black residue off on your hands that a sign it needs replacing.
May 13, 2010 | Kallista Michael S Smith Loft One-Piece...
I've just fitted a Nabis breeze and am having flushing problems.
Well many toilets flush very high before flushing, they appear to almost overflow, but if that doesn't seem like your problem, I would recommend adjusting the float on the Fluid-master fill valve so that there is less water in the tank when it flushes.
Apr 16, 2010 | Hansgrohe E & S Accessories 40526000...
Constantantly dripping after tank is full
WHAT IS DRIPPING,?THE TANK ?OR IS STILL FILLING UP ?IT SOUNDS LIKE YOU NEED TO ADJUST THE WATER LEVEL TO THE PROPER 1.6 GALLONS PER FLUSH,WHICH IS MARKED ON THE INSIDE OF YOUR TANK SOMEWHERE,CAUSE WHAT YOUR HEARING IS THE WATER RUNNING DOWN THE OVERFLOW TUBE
Apr 09, 2010 | Toto Aquia II Dual Flush Toilet
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
Leak at water supply into tank.
Seams like you have a hair line crack in the intake pipe. I would recomend replaceing it to solve your problem.
Sep 07, 2009 | Home
Standard toilet will not flush
If this is a new development, then you have a partially clogged drain or maybe a crack in the bowl assembly. If the toilet always did this, then perhaps the drain pipe was not installed correctly.
I would remove the toilet and run a snake through to the main stack. If you find that is clear, check the bowl for cracks and check the tank water level to be sure that the tank is filling to the water line on the tank
May 09, 2009 | American Standard Colony 2388.012.222...
Home Logo
196 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
