Question about LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator
My LG refrigerator is making a noise - like it is sparking - what is the problem? It sounds like water hitting a hot pipe or something. It has me concerned that our frig might catch on fire. I can hear it even more when I open the freezer door. We have a side by side and it is only a couple of years old. Thank you, Concerned.
  • 112 Answers
SOURCE: Whirlpool Side by Side Refrigerator
You have a refrigerant loop that runs through the cabinet of the refrigerator and usually runs right under the door gasket seal. Usually, when you are getting too hot on the loop, it is because your refrigerator cannot shed the heat it is removing from inside the refrigerator. This is most likely caused my either a dirty condenser unit or a faulty condenser cooling fan. (both located underneath the unit). The fan should be running anytime the compressor is running.
Posted on Oct 14, 2008
SOURCE: Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Posted on Apr 30, 2009
  • 363 Answers
SOURCE: Loud compressor noise from lg frig...
The sound you hear is the Freezer Fan, this problem is hard to diagnose, because the fan spins but not fast enough to circulate chilled air thru the freezer and refrigerator. The minimum labor and material cost for the repair/replacement is around $300.00. But if you chose to make the repair yourself the motor alone costs around $80.00@appliancefactoryparts.com. But the repair is very labor because the electrical connection for this fan is at the rear of the unit
Posted on Jul 31, 2009
  • 6 Answers
SOURCE: our GE profile freezer/frig - frig side has ice on coils
The profile uses a motherboard instead of a defrost timer. you can remove the evaporator cover and you will see a glass defrost heater at the bottom and a white sensor and a defrost thermostat at the top of the coil. you can ohm out the thermostat and the heater. If the white sensors have a round end instead of a flat end replace any way.
Posted on Aug 22, 2009
ricsindy
  • 53 Answers
SOURCE: front end of divider between refrigerator and
The area you are describing is the breaker panel, inside is a heater called a mullion. The purpose of this heater is to control any moisture that may form due to the temp difference (Dew Point) inside and out. This excessive heat you are noticing is a for-warning of bad things to come (compressor damage, spoiled food). The most common reason is not keeping the condenser (different types, designs and locations depending on make and model) clean. Recommend inspect and service every 4 - 6 months. A condenser brush (looks like a over sized bottle brush) and a vacuum with a wand is used. If never done before, service front and back, mybe power clean with reverse blowing vacuum after getting the heavy stuff out. After cleaning, give 24 hours, if no major damage to compressor or condenser fan motor, the system should return to normal, breaker panel will cool to average 10 - 15 dgs above ambiant. Other issues that it could be; weak compressor, bad - intermittantly operating condenser fan, doors intermittantly left ajar, bad - low RPM evap fan motor, cavity lights on when doors closed.
Ric
Posted on Mar 10, 2010
I hear a knocking noise behind the wall when I use the hot water. What could it be and how do I get rid of it?
I had something similar, but I would call the noise more like 'ticking'. The problem was that hot water would heat up the plumbing vent piping (plastic) for that bathroom and it would expand and then contract (after shutting hot water off). As the pipe 'grew' it would make noise sliding through the opening in the ceiling header. It seems that builders had stuffed loose fiberglass around the pipe there that served to let the pipe move freely. The fiberglass had fallen out and the pipe was rubbing against the wood and making noise. Stuffing new fiberglass in the opening around the pipe fixed it.
Oct 29, 2014 | Water Heaters
Why does my bathroom hot water pipe make several thumping noises and then quit when I turn on the faucet in cold weather but makes no noise in hot weather
It is called expansion and contraction...
When you turn the water on and off the pipe will move just a bit....
When the pipe is warmer it is a bit longer and it does not hit whatever is causing the thumping...
When the pipe is colder it shrinks just enough to hit....
This causes the thumping when cold...
It is not hurting anything... just annoying...
heatman101
Feb 12, 2011 | Plumbing
At the bottom of the freezer behind the drawer...there is a unusual sound like water hitting something hot
thats probably the defrost water hitting the defrost heater (the heater comes on about every 8 hours and melts the frost on the evaporator coils which drips down on the heater
which is normal
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | LG LSC27910 (265 cu ft) Side by Side...
When our new LG washer starts its cycle, the water seems to do quick bursts into the washer making the pipes make a bad noise. Any advice?
The quick burst of water is normal for the LG washing machines, its the way the water valves work. The noise you hear, sounds like the water lines jerking, and hitting against the wall, or the cabinet itself. You may need to get some tape, and tape the lines to the unit itself.
Mar 22, 2010 | LG Washing Machines
Loud buzzing noise coming from the freezer motor like something is stuck or hitting...possibly a fan...possibly the compressor...
Sounds like pipe vibration, you will need to take a cover off if there is one to get to the compressor. Check to make sure no pipes are rubbing against each other first, you can bend them apart carefullt, watch out for a hot pipe from the compressor. Also check to see if there is a cooling fan for the compressor, make sure all fittings are tight etc, If the noise is still there call a refrigeration technician.
Regs,
Hawk
Jan 16, 2010 | Kenmore 54622 / 54624 Side by Side...
Loud / annoying noise when in defrost mode...
it depends on the kind of noise that it is making, creaks and groans are normal, a sizzling sounds like water hitting a hot surface is normal. Can you be more specific about the noises?
Jun 15, 2009 | Refrigerators
Our new LG dishwasher makes loud clunking noise
I believe this is a brand new dishwasher. Please listen carefully to determine of the sound you hear (clunk) is being made inside the dishwasher or is it being made near by. Most times, the problem is that the hot water pipe is baking the noise when the dishwasher closes the water inlet valve ... and the pipe goes "clunk"
I have not had an LG dishwasher make a clunking sound inside itself when the cycle changes. Also, because this dishwasher is so very quiet (well insulated) the pipe banging would be louder than something inside the Dishwasher.
If you have access to the hot water pipe, listen very near it when the cycle changes for the sound. Follow that pipe (hot water) pipe back and insulate it at the point it is banging. (or get a plumber to evaluate and resolve.)
Please get back to me with what you find, OK?
Good Luck!
Apr 06, 2009 | LG LDF6920ST Stainless Steel 24 in....
GE Refrigerator Stoped making ice
the small pipe in side the freezer the one that supplies water to it, it builds ice in side, you can melt the ice by getting some hot water and a towel and wet the pipe with it intel ice melts , or you can unplug the frige with the door open over night.first solution is better.
Dec 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Mar 27, 2008 | Refrigerators
Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Jul 13, 2007 | KitchenAid Superba Architect KSCS25IN Side...
LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator Logo
73 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
