Question about Kitchen Ranges
I have a zanussi zcm 5200 mixed fuel cooker. Could you tell me how to fit a new oven gasket and a new control panel.
  • 790 Answers
Hello ,
Do u have manual ????
Posted on Mar 26, 2008
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Official Zanussi Site Parts Accessories for Appliances
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
Will Details about Zanussi ZCG7901XN Cooker Top Oven Glass Door fit my ZCM7901XN oven?
I think yes, because spare part number 311407328/5 of outer glass door is the same for both oven.
Dado
Mar 03, 2015 | Zanussi Ovens
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
How do I remove glass from the door to clean it ?
They may be rivet holes. On my Zanusi the thin panel that goes across the top of the glass to hold it in just slides off forwards toward the cooker.
Then the glass slides out upwards.
Apr 15, 2012 | Zanussi ZHQ575 Electric Double Oven
I have a zanussi built in oven model no zbf 860b which the fan is still working but the oven is no longer heating up?? Thanks
If the red light is coming on when you turn on the oven control then the thermostat is ok.You will need to remove the grids from inside the oven then remove the inside rear panel 4 screws, be carreful not to damage the thermostat as you remove the panel.When you have removed panel you will see the ring element,now remove the 3 screws holding in the element and gently pull it towards you,remove the 2 cables off element but do not let them fall into the back of cooker or you will have to remove the cooker and gain access to the rear of the cooker.Once you have element check with a multi-meter for continuity and replace if blown. Relacement is a reverse of removal.
Hope this helps.
Aug 04, 2010 | Zanussi Ovens
Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
we should be able to help if you contact the office
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Ovens
Zanussi Electric Cooker and Hob don't work properly
it will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
Feb 17, 2009 | Zanussi ZHQ575 Electric Double Oven
Oven keeps tripping the electrics
I would suspect that the fan oven element is faulty. what I think is happening , is as the element gets hotter, the insulation is breaking down and causing the trip to operate, it is quite a common problem
You will need to fit a new element.
If it is a fan assisisted oven you will find the element behind a removable cover at the rear of the oven compartment..
Plz rate my solution.
Thankyou.
Jan 06, 2009 | Zanussi ZBF360 Electric Single Oven
Oven not working
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 19, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi Oven Fan ''Ringing''
Your fan blade is probably touching the metal shroud around it or the blade is loose. You can check this by gaining access to the fan and visually looking at it. Please do not do this with the unit plugged in, electricity kills. I hope this helps.
Nov 23, 2008 | Zanussi ZCM900X Dual Fuel (Electric and...
Kitchen Ranges Logo
85 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
