Question about Sennheiser MKH-416T Professional Microphone
The 416 is inherently hissy. Does anyone know the rough frequency of this hiss so I can notch it out in post?
    New Friend:
I have two Sennheiser 416 mics and neither of them is inherently hissy. The problem that you're experiencing is almost certainly with the preamps providing the phantom power. I got a Sound Devices MP-1 preamp to link my 416 with my H4n and got beautiful clean sound.
These days I have a Sound Devices 664 and the only audible hiss on my recordings is from the source or the environment. I still use the 416 for external recording.
Posted on Nov 22, 2016
  • 74 Answers
You might be better off increasing the pre amp gain before notching out frequencies. The area of hiss will be in the area of 5k to 8k which will harm the sound of your vocal recordings as that is also the area of clarity and intelligibility. Try the Triton Audio FetHead that will fix it for you. linkd is here: http://www.zenproaudio.com/tritonaudiofethead.aspx
Posted on May 06, 2010
Hissing noise when i accelerate
I doubt its the clutch, more like there is a hose not fitted correctly on rebuild. If you didn't fit the clutch get back to the garage and have them check their work.
Oct 09, 2014 | Kia Sportage Cars & Trucks
42PFL9900D/10 Philips LCD Television Hissing Speakers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
LCD Television Philips 42PFL9900D/10 Hissing Speakers
Loud hiss on one channel
could be a bad cable or could be the high frequency control is turned up too high and the speaker without the hiss has a blown tweeter (high frequency driver), and you're trying to compensate for the lack of highs on the bad speaker by turning up the high frequency on the EQ, which makes the other speaker hiss.
Jun 05, 2012 | Audio Players & Recorders
I have the Behringer Xenyx 502 mixer, it's brand-new, and for some reason there's a weird buzzing/hissing sound in the main mix that will just not go away no matter what I do. I've unplugged everything,...
Is the sound a low frequency buzz or high frequency hiss? With all the input level controls at the minimum position and the output level controls at the maximum is the sound audible?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 31, 2011 | Behringer Xenyx 502 Audio Live Music Mixer...
No code for radio in rover 416
post the serial number found stamped in the metal casing
May 05, 2010 | Car Audio & Video
My Korg PA800 suddenly started making hissy noise. I usually switch it on a few hours every day. It was ok until about 8 pm on the day. When I started to play about 11pm on the same day (the keyboard was...
That does not sound good!
Possibilities:
The D-A convertor is going bad. The hiss could be digitizing noise or noise in the conversion network within the chip.
Noise in a preamp op=amp chip.
Noise in a passive component such as resistor or diode.
Bad plated through hole in circuit board.
The power supply is NOT very likely and since volume affects loudness, teh power amp is NOT suspect..
Troubleshoot this IMMEDIATELY using circuit cooler to isolate bad part.
A tiny squirt on suspect components till you hear a change... then gentle warming with hair dryer till you home in on the part...
I SUSPECT you will find the parts are mostly surface mounted... IF you have not had experience in replacing these before, better take it ot a shop that is equipped to do this.
Mar 03, 2010 | Music
Jag diesel o5 engine fault
Hi Without seeing exactly what your looking at ,you need to try and find the vacumn pipes going to the control valve and carefully lok to see they are conected and that there are no splits in the pipes,if the pipes and mechanically sound then you probably have a fault valve,try running your finger around the valve to see if the hissing noise changes.
Hope this helps
Darren DCS BristolLtd Master tech
Jul 10, 2009 | 2005 Jaguar X-Type
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
Sennheiser MKH-416T Professional Microphone Logo
661 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
