Question about Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator
Where is the defrost heater timer located on an Amana ABB1924DEQ refrigerator?
It is located behind the lights under the light cover
Posted on Jul 03, 2010
Where is the defrost timer / does my fridge even have one?
Most often the defrost thermostat fails there should be a diagram or small manual hidden under the kick panel or taped on the back of the refrigerator. I believe this model uses a computer to control all functions including defrost . There should be a way to run diagnostics on this to tell you your problem if you can find the hidden manual.
Aug 06, 2014 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
What causes the refrigerator freezer to turn into snow?
I'm Leo
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Fans keeps running and the freezer is cold but not enough to harden ice cream
Look inside the back wall inside freezer and if you see ice building up then your Amana needs either a defrost timer=> 67001036 Defrost Timer or you may be having problems with the defrost heater=> 67002493 Defrost Heater Here are some large pictures to help you locate your parts that may be defective=> Amana_ARB9058CS_Evaporator_Components item location number 15 in lower left side of photo. In this case I think your refrigerator may need the defrost timer below but I would like you to manually turn the clock on the time clockwise slowly until compressor and fans stop running. The defrost timer is located inside the fresh food compartment and just behind the controls for adjusting temps inside fresh food compartment location=> Amana ARB9058CS Controls That is my most likely guess the timer but sometimes it will be the defrost heater or defrost thermostat affect these also here=> 12001937 Defrost Thermostat
I will be here if you have questions please ask, Thanks Sea Breeze
May 09, 2011 | Amana ARB9058CS Bottom Freezer...
Temperature inside refridgerator is not very cold even at higher cold settings??
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 24, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Amana ssd21sw stop cooling freezer side frost in rear wall any sugestions
Defrost cycling problem which will affect cooling the fridge compartment by struck the freezer fan's function.To solve defrost problem:
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Feb 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Bottom freezer is working fine. refrigerator is warm(does not get any colder no matter how i set the controls) what is the problem?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 19, 2010 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Freezer has accumulated frost along top of door. Refrigerator isn't cold although it is at its coldest setting.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Freezer is working refrigerator is not.
The freezer is not defrosting. Look at the back wall of the freezer section and see if it is frosted. Locate the defrost timer and advance it till it clicks once. This should advance the freezer to the defrost cycle. Check to see if the defrost heater is on. If the defrost heater is glowing behind the freezer rear panel the you know you have to replace the defrost timer. If the heater is not glowing then you have to check if the defrost heater or defrost timer is in default.
Dec 27, 2009 | Amana ABB1927DE Bottom Freezer...
Amana side by freezer fan frozen will not run
Fan not operating could be caused by the excess frost buildup in the freezer coil. Defrost problems are related to a failure of the timer, heater, or defrost thermostat. Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 18-22 minutes your problem is in the heater circuit. Heater and defrost thermostat is located behind the back wall of the freezer section.
Jun 29, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ Bottom Freezer Refrigerator Logo
292 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
